raspberrypi2 libbsd 5-freebsd-12 does not build
Sun Mar 8 00:40:08 UTC 2020
Hi,
An RSB build of libbsd is failing with ...
/opt/work/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:
./libbsd.a(rtems-kernel-nexus.c.18.o): in function `nexus_ofw_map_intr':
/opt/work/chris/rtems/rsb/rtems-source-builder.git/rtems/build/rtems-libbsd-v2b9172c9d42d056b6fb16d667091e2ee3ac64009-arm-rtems5-1/rtems-libbsd-2b9172c9d42d056b6fb16d667091e2ee3ac64009/build/arm-rtems5-raspberrypi2-default/../../rtemsbsd/rtems/rtems-kernel-nexus.c:359:
undefined reference to `bsp_fdt_map_intr'
I have raised a blocker ticket to track this ...
https://devel.rtems.org/ticket/3903
Thanks
