Issues when adding a multi-port PCI serial card
Peter Dufault dufault at hda.com
Thu Mar 12 20:44:56 UTC 2020
I've added an 8-port RS232 PCI Mezzanine Card to the "beatnik" BSP.  The console (aka serial port) code is confusing.
I decided I should use what is in "bsp/console-termios.h"  as opposed to the "legacy console" approach, *even though* "legacy console" is used in many recent BSPS.
* Is that correct?
That approach went well, I created a replacement shared PowerPC console in "bsps/powerpc/shared/console/console-config.c" with only 129 lines of code and half of it comments.
Where does the driver go:  Next I had to add the PCI multi-port serial card driver.  I put it in "bsps/shared/dev/pci/mp_serial.c".  The other directory choice was "bsps/shared/dev/serial".  I didn't like either, the "dev/pci" is very associated with PCI discovery and the "dev/serial" is very associated with the generic low-level serial driver support, even thought it has the "legacy-console" cruft in it.
* Where should it go?
Difficulty in assigning common TTY names: Since my new shared PowerPC "console-config.c" created "/dev/ttyS0" and "/dev/ttyS1" I wanted to name the new serial devices with a number that started at 2, i.e., "/dev/ttyS2".
* Is there a way in the "console-termios" framework to know what the highest "minor number" for a serial port is?  I searched, gave up, and made it a configuration item.
Next I had to figure out the best way to probe and discover the board.
* I wanted to add an RTEMS_SYSINIT_ITEM that would call a probe routine to discover the multiport cards at the appropriate time, after "/dev/console" was discovered but before I wanted to spawn my shell.  I had trouble figuring out what level and order I should use for the probe routine.  I never got this working, my probe routine kept getting called much later then I expected it to.  I need a pointer to the documentation to RTEMS_SYSINIT_ITEM ordering.
Finally, after initial successful loop-back testing, I tried to start an RTEMS shell on one of the new ports.
*Here I'm trying hard to avoid all-caps because this took the most time of all (it should have been easiest), and I gave up!*
* HOW (sorry) do you spawn a shell on a serial port?  The documentation, at https://docs.rtems.org/branches/master/shell/configuration_and_init.html that suggests just setting the shell device name to "/dev/console", or in my case "/dev/ttyS9", is incorrect.  The shell startup is intent on using "stdin" and "stdout".
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
