microblaze build failure
Fri Mar 13 17:22:27 UTC 2020
On 13/03/2020 14:53, Joel Sherrill wrote:
> Based on conversations with Chris, I don't think this is the same as
> his failure mode (on FreeBSD?) and this isn't a critical target but I
> am perplexed at this failure in common code. crt0.c should just
> compile. This is with everything off the master but I get the same
> failure on CentOS 7 with the RSB. Any ideas?
https://sourceware.org/pipermail/newlib/2020/017571.html
