microblaze build failure
Fri Mar 13 18:23:54 UTC 2020
On 13/03/2020 19:02, Joel Sherrill wrote:
> On Fri, Mar 13, 2020 at 12:22 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 13/03/2020 14:53, Joel Sherrill wrote:
>     > Based on conversations with Chris, I don't think this is the
>     same as
>     > his failure mode (on FreeBSD?) and this isn't a critical target
>     but I
>     > am perplexed at this failure in common code. crt0.c should just
>     > compile. This is with everything off the master but I get the same
>     > failure on CentOS 7 with the RSB. Any ideas?
>     https://sourceware.org/pipermail/newlib/2020/017571.html
> Awesome! Good spot! I knew it had to be something small. It just had not
> jumped out at me. I wonder how this builds on other targets at all.
I guess somehow <assert.h> got included via a microblaze specific
include chain.
> Once this is merged and propagates to our github mirror, will you be
> bumping
> the rtems5 tools?
I currently don't have access to my sourceware SSH key, could you push
this for me to Newlib?
> What about rtems6 tools? Are those being paused until a release is
> done?
We have to first update the GCC mirror to use the new GCC Git repository.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200313/56a69ba6/attachment.html>
