Sources to port fenv.h to ARM and AARCH64
Eshan Dhawan eshandhawan51 at gmail.com
Fri Mar 20 20:33:07 UTC 2020
thanks, dr Joel
I had gone through the musl-libc library but it doesn't have much
architecture specific support for ARM as well as AARCH64
It has support for s390x, m68k, powerpc64
On Sat, Mar 21, 2020 at 1:32 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 20, 2020 at 2:43 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> What would be the preferred source to port fenv.h to ARM and AARCH64
>> its implementation is present in both FreeBSD as well AS NetBSD
>> -> ARM
>> ---FreeBSD Source
>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>> ---NetBSD Source
>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>> ->AARCH64
>> ---FreeBSD Source
>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/aarch64
>> ---NetBSD Source
>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64
> Don't forget MUSL-C Library which has a lot of architectures and
> is appropriately licensed.
> https://git.musl-libc.org/cgit/musl/tree/src/fenv
> I think our the order is going to be FreeBSD, NetBSD, then other places.
> The code drops into newlib's libm in a particular way which may require
> some refactoring. fenv.h is shared across all ports and machine/fenv.h is
> where port code goes. There must be an architecture specific file for each
> method. But the entire implementation could go in one file and the others
> be stubs. The i386 does this.
> --joel
>> <https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64>
>> Thanks
>> -Eshan
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/9ab2301a/attachment.html>
