discussion related to source for porting headers and methods to RTEMS and newlib
Eshan Dhawan eshandhawan51 at gmail.com
Wed Mar 25 11:10:40 UTC 2020
On Wed, Mar 25, 2020 at 4:18 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 24, 2020 at 5:33 PM Gedare Bloom <gedare at rtems.org> wrote:
>> email subject can be shortened. almost everything is a discussion :)
>> On Tue, Mar 24, 2020 at 3:49 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>> > Hello everyone,
>> > I have identified sources to port headers and methods to RTEMS and
>> Newlib. I have given priority to FreeBSD for the choice of source. But
>> method not present in FreeBSD can be ported from alternative sources like
>> NetBSD and musl.
>> Considering the simplicity, you may want to compare musl vs freebsd as
>> well.
>> > -> Missing methods of math.h: I have compiled a list of methods and
>> their sources. Some need to be implemented from scratch.
>> > list: Math.h missing functions
>> > -> sys/ipc.h: This header and its function can be ported from FreeBSD.
>> > ipc.h : https://github.com/freebsd/freebsd/blob/master/sys/sys/ipc.h
>> > ftok.c:
>> https://github.com/freebsd/freebsd/blob/master/lib/libc/gen/ftok.c
> sys/ipc.h has a lot in it. If you head down the path of adding sys/ipc.h,
> you need to evaluate what else is in the file.
> Adding support for the System V style SHM, Semaphores, or Message Queues
> is possible (I think) but is definitely harder than the likely value to the
> community.
I would like to know missing headers and methods that would be more
valuable to the community
>> > ->fmtmsg.h: its implementation is also present in FreeBSD.
>> > https://github.com/freebsd/freebsd/blob/master/include/fmtmsg.h
>> > https://github.com/freebsd/freebsd/blob/master/lib/libc/gen/fmtmsg.c
> By my recollection, this would be a discrete thing to add to Newlib.
>> > ->spawn.h: Its implementation is in FreeBSD.
>> https://github.com/freebsd/freebsd/blob/master/lib/libc/gen/posix_spawn.c
>> I'm worried about the large number of includes there. It may easily
>> lead you to trouble chasing down transitive include headers, like what
>> happened with Vaibhav before with search.h support.
> posix_spawn() cannot be supported by RTEMS. It is a new safer way to do
> fork/exec. Don't spent any time on this. It will never work on RTEMS.
> It is also a HUGE amount of methods and constants. :(
Ok I will remove it from the proposal
>> > -> pselect() from <sys/select.h> : its implementation is also from
>> FreeBSD
>> > https://github.com/freebsd/freebsd/blob/master/lib/libc/sys/pselect.c
> This would be added to rtems-libbsd. There may be specific technical
> challenges
> why it is not present. Or it could just be an oversight.
I haven't dig that deep.
>> > -> confstr() from <unistd.h>: Its implementation is from FreeBSD
>> > https://github.com/udp/freebsd-libc/blob/master/gen/confstr.c.
> The implementation of this would go in RTEMS.
> It is possible that the FreeBSD code is a guide but this cannot be a direct
> copy to port. Each value defined by POSIX as fetchable must be properly
> defined for RTEMS. You would need to make a table of all the "names"
> that can be looked up in your proposal.
what would be better writing it from scratch of just doing minor tweaks in
the FreeBSD code
We also have an option to take code from musl
https://git.musl-libc.org/cgit/musl/tree/src/conf/confstr.c
> FWIW I think the FreeBSD version is more right than wrong for RTEMS
> but it can't be 100% right and needs analysis.
>> > I would like everyone to review it and provide your suggestions.
>> include details in your proposal also.
> +1
> I have already added these detatils to the proposal
> but will change spawn.h
>> > Thanks
>> > -Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200325/cab37496/attachment.html>
