[PATCH] c-user: Use new template for integer config opts
Fri Mar 27 17:41:16 UTC 2020
The documentation was generated by updated application configuration items
https://git.rtems.org/sebh/rtems-qual.git/tree/spec/acfg/opt
and the following generator:
https://git.rtems.org/sebh/rtems-qual.git/tree/rtemsqual/applconfig.py
The next step is to add new option types for the following options:
spec/acfg/opt/RTEMS-ACFG-OPT-APPLEXTRADRIVERS.yml
spec/acfg/opt/RTEMS-ACFG-OPT-APPLPREREQUISITEDRIVERS.yml
spec/acfg/opt/RTEMS-ACFG-OPT-IDLETASKBODY.yml
spec/acfg/opt/RTEMS-ACFG-OPT-INITIALEXTENSIONS.yml
spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKENTRYPOINT.yml
spec/acfg/opt/RTEMS-ACFG-OPT-MPMPCITABLEPOINTER.yml
spec/acfg/opt/RTEMS-ACFG-OPT-POSIXINITTHREADENTRYPOINT.yml
spec/acfg/opt/RTEMS-ACFG-OPT-TASKSTACKALLOCATOR.yml
spec/acfg/opt/RTEMS-ACFG-OPT-TASKSTACKALLOCATORINIT.yml
spec/acfg/opt/RTEMS-ACFG-OPT-TASKSTACKDEALLOCATOR.yml
