m2005 untar error on msys2 (tar01 directory)
Tue May 5 07:37:04 UTC 2020
On 05/05/2020 09:25, Chris Johns wrote:
>>> Oh OK, maybe keep it? Could you patch the RSB and see if it works?
>> I removed the GDB from the build set.
> I am pretty sure it would work with a patched windows.py.
Which patch?
>> It is currently busy building the 5/rtems-sparc build set (without
>> GDB) in a mingw64 shell. Is a build in the msys shell something
>> useful/supported?
> Yes, we have valid users. Plus building on Windows is valid for the
> same reasons we build from source on all hosts maybe more so.
If I install msys/mingw I get an msys, mingw32 and mingw64 shell. They
are all somewhat different. Are all of them supposed to be supported?
There is also this:
https://en.wikipedia.org/wiki/Windows_Subsystem_for_Linux
