[rtems/rsb]: Error while building and Adding Netinet cfg (dependency of PTP) [GSoC 2020]
Tue May 26 19:10:54 UTC 2020
Although the last few lines tell you to look somewhere else for details,
the error is pretty clear from your log.
+ cd netinet
/home/mritunjay/development/rtems/rsb/rtems/build/netinet--sparc-rtems5-1/do-build:
90: cd: can't cd to netinet
shell cmd failed: /bin/sh -ex
error: building netinet--sparc-rtems5-1
  See error report: rsb-report-netinet--sparc-rtems5-1.txt
The "cd netinet" does not match the directory created when the code was
fetched and unzipped earlier.
+ /bin/rm -rf netinet
+ /usr/bin/unzip -u
/home/mritunjay/development/rtems/rsb/rtems/sources/master.zip
Archive:  /home/mritunjay/development/rtems/rsb/rtems/sources/master.zip
17bc2a77248344c8f686cfda95d491b78fc92c85
   creating: netinet-master/
  inflating: netinet-master/.gitignore
  inflating: netinet-master/README.md
  inflating: netinet-master/accf_data.c
The "rm -rf" and "cd" commands are using the wrong directory name for the
source contents.
--joel
On Tue, May 26, 2020 at 1:22 PM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello everyone,
> As advised I tried adding Netinet package which
> is a dependency to add PTP and was causing an error
> earlier, I have encountered another error as mentioned below
> while testing the build for netinet.
> Build Set: Time 0:00:00.667194
> Attaching trace file as well.
> Thanks,
> Mritunjay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200526/0d8cbf77/attachment.html>
