[PATCH v3 5/5] Use CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Wed Nov 25 07:12:23 UTC 2020
Update #4181.
 testsuites/validation/ts-default.h | 109 +++++++++++------------------
 1 file changed, 40 insertions(+), 69 deletions(-)
diff --git a/testsuites/validation/ts-default.h b/testsuites/validation/ts-default.h
index 0f7db65a8e..0385587beb 100644
--- a/testsuites/validation/ts-default.h
+++ b/testsuites/validation/ts-default.h
@@ -35,12 +35,23 @@
 #include <rtems/bspIo.h>
 #include <rtems/chain.h>
-#include <rtems/sysinit.h>
 #include <rtems/test-info.h>
 #include <rtems/testopts.h>
 #include <rtems/test.h>
+#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
+#define MAX_TASKS 32
+#define TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define TASK_STORAGE_SIZE \
+  RTEMS_TASK_STORAGE_SIZE( \
+    MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE, \
+    TASK_ATTRIBUTES \
 static char buffer[ 512 ];
 static const T_action actions[] = {
@@ -70,12 +81,28 @@ static const T_config test_config = {
   .actions = actions
-static void runner_task( rtems_task_argument arg )
+static rtems_chain_control free_task_storage =
+  RTEMS_CHAIN_INITIALIZER_EMPTY( free_task_storage );
+static union {
+  RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT ) char
+    storage[ TASK_STORAGE_SIZE ];
+  rtems_chain_node node;
+} task_storage[ MAX_TASKS ];
+static void Init( rtems_task_argument arg )
   int exit_code;
   (void) arg;
+  rtems_chain_initialize(
+    &free_task_storage,
+    task_storage,
+    RTEMS_ARRAY_SIZE( task_storage ),
+    sizeof( task_storage[ 0 ] )
   rtems_test_begin( rtems_test_name, TEST_STATE );
   T_register();
   exit_code = T_main( &test_config );
@@ -87,40 +114,6 @@ static void runner_task( rtems_task_argument arg )
   rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
-#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
-#define ATTRIBUTES RTEMS_FLOATING_POINT
-#define TASK_STORAGE_SIZE \
-  RTEMS_TASK_STORAGE_SIZE( \
-    MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE, \
-    ATTRIBUTES \
-#define MAX_TASKS 32
-RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
-static char runner_task_storage[ TASK_STORAGE_SIZE ];
-static const rtems_task_config runner_task_config = {
-  .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
-  .initial_priority = 1,
-  .storage_area = runner_task_storage,
-  .storage_size = sizeof( runner_task_storage ),
-  .maximum_thread_local_storage_size = MAX_TLS_SIZE,
-  .initial_modes = RTEMS_DEFAULT_MODES,
-  .attributes = ATTRIBUTES
-static rtems_chain_control free_task_storage =
-  RTEMS_CHAIN_INITIALIZER_EMPTY( free_task_storage );
-static union {
-  RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT ) char
-    storage[ TASK_STORAGE_SIZE ];
-  rtems_chain_node node;
-} task_storage[ MAX_TASKS ];
 static void *task_stack_allocate( size_t size )
   if ( size > sizeof( task_storage[ 0 ] ) ) {
@@ -138,35 +131,6 @@ static void task_stack_deallocate( void *stack )
-static void init_runner_task( void )
-  rtems_id id;
-  rtems_status_code sc;
-  rtems_chain_initialize(
-    &free_task_storage,
-    task_storage,
-    RTEMS_ARRAY_SIZE( task_storage ),
-    sizeof( task_storage[ 0 ] )
-  sc = rtems_task_construct( &runner_task_config, &id );
-  if ( sc != RTEMS_SUCCESSFUL ) {
-    rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
-  sc = rtems_task_start( id, runner_task, 0 );
-RTEMS_SYSINIT_ITEM(
-  init_runner_task,
-  RTEMS_SYSINIT_CLASSIC_USER_TASKS,
-  RTEMS_SYSINIT_ORDER_MIDDLE
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_MAXIMUM_PROCESSORS 4
@@ -183,7 +147,8 @@ RTEMS_SYSINIT_ITEM(
 #define CONFIGURE_MAXIMUM_TASKS ( 1 + MAX_TASKS )
-#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE 1
+#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE \
+  CONFIGURE_MAXIMUM_TASKS
 #define CONFIGURE_MAXIMUM_TIMERS 3
@@ -197,9 +162,7 @@ RTEMS_SYSINIT_ITEM(
 #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
-#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
-#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
+#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE MAX_TLS_SIZE
 #define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
@@ -207,6 +170,14 @@ RTEMS_SYSINIT_ITEM(
 #define CONFIGURE_TASK_STACK_DEALLOCATOR task_stack_deallocate
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES TASK_ATTRIBUTES
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE TASK_STORAGE_SIZE
 #if defined(RTEMS_SMP)
 #define CONFIGURE_SCHEDULER_EDF_SMP
2.26.2
