[PATCH v3 05/10] bsps/shared: Add PSCI-based bspreset implementation
Kinsey Moore kinsey.moore at oarcorp.com
Sun Oct 4 04:18:49 UTC 2020
This adds a bsp_reset implementation based on the ARM PSCI
specification often present in ARMv8 systems.
 bsps/shared/start/bspreset-arm-psci.c | 56 +++++++++++++++++++++++++++
 1 file changed, 56 insertions(+)
 create mode 100644 bsps/shared/start/bspreset-arm-psci.c
diff --git a/bsps/shared/start/bspreset-arm-psci.c b/bsps/shared/start/bspreset-arm-psci.c
new file mode 100644
index 0000000000..215be5c9b5
--- /dev/null
+++ b/bsps/shared/start/bspreset-arm-psci.c
@@ -0,0 +1,56 @@
+ * @file
+ * @ingroup RTEMSBSPsShared
+ * @brief PSCI-based BSP reset hook.
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+void bsp_reset(void)
+	uint32_t PSCI_FN_SYSTEM_RESET = 0x84000009;
+	__asm__ volatile(
+#if defined(AARCH64_MULTILIB_ARCH_V8) || defined(AARCH64_MULTILIB_ARCH_V8_ILP32)
+		"mov x0, %0\n"
+#else
+		"mov r0, %0\n"
+#endif
+#ifdef BSP_RESET_SMC
+		"smc #0\n"
+#else
+		"hvc #0\n"
+#endif
+		: : "r" (PSCI_FN_SYSTEM_RESET)
2.20.1
