[PATCH v3 2/2] Add AArch64 documentation
Kinsey Moore kinsey.moore at oarcorp.com
Mon Oct 5 15:28:18 UTC 2020
-----Original Message-----
Sent: Monday, October 5, 2020 10:19
To: Kinsey Moore <kinsey.moore at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH v3 2/2] Add AArch64 documentation
On Mon, Oct 5, 2020 at 9:13 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Oct 3, 2020 at 10:23 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> >  cpu-supplement/aarch64.rst | 134
> >  user/bsps/aarch64/a53.rst  |  26 +++++++
> >  user/bsps/bsps-aarch64.rst |   2 +-
> >  3 files changed, 161 insertions(+), 1 deletion(-)  create mode
> > 100644 cpu-supplement/aarch64.rst  create mode 100644
> > diff --git a/cpu-supplement/aarch64.rst b/cpu-supplement/aarch64.rst
> > new file mode 100644 index 0000000..178ea10
> > --- /dev/null
> > +++ b/cpu-supplement/aarch64.rst
> > @@ -0,0 +1,134 @@
> > +.. SPDX-License-Identifier: CC-BY-SA-4.0
> > +.. Copyright (C) 1988, 2020 On-Line Applications Research
> > +Corporation (OAR)
> > +AArch64 Specific Information
> > +This chapter discusses the dependencies of the *ARM AArch64
> > +architecture*
> > +(https://en.wikipedia.org/wiki/ARM_architecture#AArch64_features)
> > +in this port of RTEMS.  The ARMv8-A versions are supported by
> > +RTEMS.  Processors with a MMU use a static configuration which is
> > +set up during system start.  SMP is not supported.
> > +**Architecture Documents**
> > +For information on the ARM AArch64 architecture refer to the *ARM
> > +Infocenter* (http://infocenter.arm.com/).
> > +CPU Model Dependent Features
> > +This section presents the set of features which vary across ARM
> > +AArch64 implementations and are of importance to RTEMS.  The set of
> > +CPU model feature macros are defined in the file
> > +:file:`cpukit/score/cpu/aarch64/rtems/score/aarch64.h`
> > +based upon the particular CPU model flags specified on the
> > +compilation command line.
> > +CPU Model Name
> > +The macro ``CPU_MODEL_NAME`` is a string which designates the
> > +architectural level of this CPU model.  See in
> > +for the values.
> > +Floating Point Unit and SIMD
> > +The Advanced SIMD (NEON) and Floating-point instruction set
> > +extension is supported and expected to be present since all ARMv8-A
> > +CPUs are expected to support it as per the *ARMv8-A Programmer's
> > +Guide Chapter 7 introduction*
> > +(https://developer.arm.com/docs/den0024/a/aarch64-floating-point-and-neon). As such, ``CPU_HARDWARE_FP`` will always be set to ``TRUE``.
> > +Multilibs
> > +The following multilib variants are available:
> > +#. ``ILP32``: AArch64 instruction set and registers using 32bit
> > +long int and pointers
> > +#. ``LP64``: AArch64 instruction set and registers using 64bit long
> > +int and pointers
> > +Use for example the following GCC options:
> > +.. code-block:: shell
> > +    -mcpu=cortex-a53 -mabi=ilp32
> > +to build an application or BSP for the ARMv8-A architecture and
> > +tune the code for a Cortex-A53 processor.  It is important to select the correct ABI.
> > +Calling Conventions
> > +Please refer to the *Procedure Call Standard for the ARM 64-bit
> > +Architecture* (https://github.com/ARM-software/abi-aa/releases/download/2019Q4/aapcs64.pdf).
> > +Memory Model
> > +A flat 64-bit or 32-bit memory model is supported depending on the
> > +selected multilib variant.  All AArch64 CPU variants support a
> > +built-in MMU for which basic initialization for a flat memory model is handled.
> > +Interrupt Processing
> > +The Reset Vector is determined using RVBAR and is Read-Only. RVBAR
> > +is set using configuration signals only sampled at reset.  The
> > +ARMv8 architecture has four exception types:
> > +- Synchronous Exception
> > +- Interrupt (IRQ)
> > +- Fast Interrupt (FIQ)
> > +- System Error Exception
> > +Of these types only the synchronous and IRQ exceptions have
> > +explicit operating system support.  It is intentional that the FIQ
> > +is not supported by the operating system.  Without operating system
> > +support for the FIQ it is not necessary to disable them during critical sections of the system.
> > +Interrupt Levels
> > +There are exactly two interrupt levels on ARMv8 with respect to
> > +RTEMS.  Level zero corresponds to interrupts enabled.  Level one
> > +corresponds to interrupts disabled.
> > +Interrupt Stack
> > +The board support package must initialize the interrupt stack. The
> > +memory for the stacks is usually reserved in the linker script.
> > +Default Fatal Error Processing
> > +The default fatal error handler for this architecture performs the
> > +following
> > +actions:
> > +- disables operating system supported interrupts (IRQ),
> > +- places the error code in ``x0``, and
> > +- executes an infinite loop to simulate a halt processor instruction.
> > +Symmetric Multiprocessing
> > +SMP is not currently supported on ARMv8-A.
> > +Thread-Local Storage
> > +Thread-local storage (TLS) is supported. AArch64 uses unmodified
> > +TLS variant I which is not explcitly stated, but can be inferred
> > +from the behavior of GCC and *Addenda to, and Errata in, the ABI
> > +for the Arm® Architecture*
> > +(https://developer.arm.com/documentation/ihi0045/g). This alters
> > +expectations for the size of the TLS Thread Control Block (TCB) such that, under the LP64 multilib variant, the the TCB is 16 bytes in size instead of 8 bytes.
> s/the the/the
I missed that you sent v4, but this is still in it too.
I'll include this change in v5, thanks.
Kinsey
