[PATCH] user: Add a Languages section
Fri Oct 9 05:58:25 UTC 2020
On 9/10/20 4:48 pm, Sebastian Huber wrote:
> I think API descriptions should go into the RTEMS Classic API Guide.
Which bit or the whole thing?
The patch is more about an example of threading in C++ and the standards
addition I have added than more formal API documentation. I can add a more
formal API section if we think there is a need but the thread class itself is
documented in the standard already. I think we need a languages section.
The scheduling bits can be (re)moved if needed. I could not find anything in the
POSIX manual I could reference.
> Maybe we should rename this manual.
Do you have a name in mind?
