[PATCH 1/3] Remove duplicate GRETH driver
Sun Oct 25 23:20:33 UTC 2020
On 26/10/20 9:56 am, Jiri Gaisler wrote:
> On 10/25/20 6:35 PM, Joel Sherrill wrote:
>> Is the code deleted referenced in the new build system?
> Good question! I don't really know how the new systems works to answer that. I
> could only remove the references from the .am files...
Sebastian has done a great job and I find it intuitive to use. He has provided
documentation here:
https://docs.rtems.org/branches/master/eng/build-system.html
The build YAML files can be found under `spec` in `rtems.git`. Is this the file:
https://git.rtems.org/rtems/tree/spec/build/bsps/objgrlibnet.yml
? And if that file is now empty maybe these links can be removed:
https://git.rtems.org/rtems/tree/spec/build/bsps/objgrlib.yml#n74
I hope this helps.
