select call on a UDP socket with BSD library?
Tue Sep 1 04:47:32 UTC 2020
On 01/09/2020 04:48, Chris Johns wrote:
>> The fd in this instance is 77 and I have RTEMS setup for 200 file descriptors.
>> Are there any other LibBSD configuration parameters I should be aware of?
> I am sorry but 77 is to high because newlib by default limits the fd set size to
> 64...
> #  ifndef       FD_SETSIZE
> #       define  FD_SETSIZE      64
> #  endif
> I suggest you define `FD_SETSIZE` on the command line to the compiler to 256 and
> see what happens. It should be fine to do this.
The FD_SETSIZE limit in Newlib also applies to the old network stack.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
