[PATCH] display/disp_hcms29xx fix string turncation warning
Mon Sep 7 06:38:28 UTC 2020
On 03/09/2020 16:46, Aschref Ben-Thabet wrote:
> From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
> strncpy
Please use the strncpy() style for functions in commit messages and
comments.
> is unsafe if the terminating NULL
There are NULL pointers and NUL characters, see
https://www.man7.org/linux/man-pages/man7/ascii.7.html
>   is missing, as it may copy
> more characters than fit in the destination area
No, the strncpy() does not overwrite the destination area if the size
parameter is valid. I doesn't terminate the destination string if the
source is too long.
> Replace it by the safer strlcpy() and fix the string
> turncation warnings.
>   bsps/shared/dev/display/disp_hcms29xx.c | 3 +--
>   1 file changed, 1 insertion(+), 2 deletions(-)
> diff --git a/bsps/shared/dev/display/disp_hcms29xx.c b/bsps/shared/dev/display/disp_hcms29xx.c
> index 5730b36ea9..fb88f66343 100644
> --- a/bsps/shared/dev/display/disp_hcms29xx.c
> +++ b/bsps/shared/dev/display/disp_hcms29xx.c
> @@ -589,10 +589,9 @@ static rtems_task disp_hcms29xx_update_task
>   				    RTEMS_WAIT,RTEMS_NO_TIMEOUT);
>         if (rc == RTEMS_SUCCESSFUL) {
> -	strncpy(softc_ptr->disp_param.disp_buffer,
> +  	strlcpy(softc_ptr->disp_param.disp_buffer,
>   		softc_ptr->disp_param.trns_buffer,
>   		sizeof(softc_ptr->disp_param.disp_buffer));
> -	softc_ptr->disp_param.disp_buffer[sizeof(softc_ptr->disp_param.disp_buffer)-1] = '\0';
>   	softc_ptr->disp_param.disp_buf_cnt =
>   	  (int) strlen(softc_ptr->disp_param.disp_buffer);
Please check what strlcpy() returns and use it to get rid of the
strlen() call.
