[PATCH] tester: Correct path
Richi Dubey richidubey at gmail.com
Thu Sep 10 18:59:10 UTC 2020
 user/tools/tester.rst | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index 5452856..1d10462 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -258,8 +258,7 @@ the directories under that path are searched for any file with a ``.exe`` extens
 This is the default extension for RTEMS executables built within RTEMS. You can
 pass more than one executable on the command line.
-To run the erc32 tests enter the following command from the top of the erc32
-BSP build tree:
+To run the erc32 tests enter the following command from the parent of bin folder:
 .. code-block:: none
2.17.1
