[PATCH] shell: Fixing bug in line editing of the shell with CTRL-U.
Frank Kuehndel frank.kuehndel at embedded-brains.de
Fri Sep 25 09:12:55 UTC 2020
This patch fixes a tiny bug in the command line editing of the RTEMS shell. Typing CTRL-U in the shell should remove all characters left of the cursor. After pressing CTRL-U, the current implementation does wrongly place the cursor at the end of the line instead at its beginning.
To reproduce the bug, start the shell and type 'abc123' (no <RETURN>):
> ~/src/rtems $ qemu-system-arm -net none -nographic -M realview-pbx-a9 -m 256M -kernel build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl10.exe
> *** BEGIN OF TEST libdl (RTL) 10 ***
> *** TEST VERSION: 6.0.0.d9bdf166644f612dd628fe4951c12c6f8e94ba5f
> *** TEST STATE: USER_INPUT
> *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 10.2.1 20200904 (RTEMS 6, RSB 31f936a7b74d60bda609a9960c6e1a705ba54974, Newlib a0d7982)
> RTL (libdl) commands: dl, rtl
> RTEMS Shell on /dev/foobar. Use 'help' to list commands.
> SHLL [/] # abc123
Then move the cursor onto the '1' by hitting three times the <ARROW-LEFT> key. Next type <CTRL>-U:
> SHLL [/] # 123
Note that the cursor is at the end of the line (after '3') instead of correctly at the beginning (on the '1'), now.
Continuing typing 'echo ' incorrectly results in the output:
> SHLL [/] # 123echo 123
The patch changes this behavior so that the cursor in the second last step will be on the '1' and typing 'echo ' will then correctly reflected as:
> SHLL [/] # echo 123
 cpukit/libmisc/shell/shell.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 13ae411f9c..ee65c1be36 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -621,11 +621,14 @@ static int rtems_shell_line_editor(
           if (col > 0)
             int clen = strlen (line);
+            int bs;
             strcpy (line, line + col);
             if (output) {
               fprintf(out,"\r%s%*c", prompt, clen, ' ');
               fprintf(out,"\r%s%s", prompt, line);
+              for (bs = 0; bs < strlen (line); bs++)
+                fputc('\b', out);
             col = 0;
2.26.2
