[PATCH v2 2/8] spec: Add missing spintrcritical24 definition
Kinsey Moore kinsey.moore at oarcorp.com
Tue Sep 29 12:38:43 UTC 2020
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Tuesday, September 29, 2020 06:09
To: Kinsey Moore <kinsey.moore at oarcorp.com>; RTEMS <devel at rtems.org>
Subject: Re: [PATCH v2 2/8] spec: Add missing spintrcritical24 definition
On 28/09/2020 17:24, Kinsey Moore wrote:
>   spec/build/bsps/tstnointrcrit.yml | 1 +
>   1 file changed, 1 insertion(+)
> diff --git a/spec/build/bsps/tstnointrcrit.yml
> b/spec/build/bsps/tstnointrcrit.yml
> index 0460aaabb3..46f7d974c8 100644
> --- a/spec/build/bsps/tstnointrcrit.yml
> +++ b/spec/build/bsps/tstnointrcrit.yml
> @@ -24,6 +24,7 @@ actions:
>       spintrcritical21: exclude
>       spintrcritical22: exclude
>       spintrcritical23: exclude
> +    spintrcritical24: exclude
>   build-type: option
>   copyrights:
>   - Copyright (C) 2020 embedded brains GmbH
> (http://www.embedded-brains.de)
I changed the test support for critical sections recently. Now, this test framework part is used:
https://docs.rtems.org/branches/master/eng/test-framework.html#interrupt-tests
Could you please run the spintrcritical* tests also on the new port. My intention was to be able to run these tests on Qemu.
I'll make sure these are working before I push the next patch version.
Kinsey
