[PATCH] tests: Add and use <rtems/testopts.h>
Wed Sep 30 05:57:48 UTC 2020
On 30/9/20 3:55 pm, Sebastian Huber wrote:
> On 30/09/2020 07:52, Chris Johns wrote:
>> On 29/9/20 11:31 pm, Sebastian Huber wrote:
>>> Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
>>> test suites using the RTEMS test framework.
>> Does this create another build variant?
> Each build option creates variants.
Yes I am rather aware of this. I am wondering if we need to capture in the spec
files which options needs to be regression tested?
>> Why would I play with this option?
> For normal tests runs you can use a verbosity of normal. If you need a more
> detailed output, then you can set it to verbose. For example, in case a
> regression ocurred.
This makes sense. Has this been captured somewhere?
