[PATCH] covoar/Target_aarch64: Swap QEMU taken/not taken bits
Fri Apr 16 21:47:55 UTC 2021
ok thanks for the context, go ahead--and do complain upstream :)
On Fri, Apr 16, 2021 at 3:34 PM Alex White <alex.white at oarcorp.com> wrote:
> On Fri, Apr 16, 2021 at 2:33 PM Gedare Bloom <gedare at rtems.org> wrote:
> > why this is needed?
> There was a patch a couple weeks ago that switched the taken/not taken bits in the `TargetBase` class:
> https://git.rtems.org/rtems-tools/commit/?id=e80fd3e75b25627b6b2be2c1c820895319a91f34
> That commit is being reverted. I guess it would have helped to send that along with this patch as part of a patch set.
> Without that context, this patch indeed looks like a do-nothing change.
> Alex
> > On Fri, Apr 16, 2021 at 1:25 PM Alex White <alex.white at oarcorp.com> wrote:
> > > This overrides the `TargetBase` behavior to allow branches to be marked
> > > correctly as either taken or not taken.
> > > Closes #4387
> > >  tester/covoar/Target_aarch64.cc | 11 +++++++++++
> > >  tester/covoar/Target_aarch64.h  |  6 ++++++
> > >  2 files changed, 17 insertions(+)
> > > diff --git a/tester/covoar/Target_aarch64.cc b/tester/covoar/Target_aarch64.cc
> > > index 64472d6..4d16456 100644
> > > --- a/tester/covoar/Target_aarch64.cc
> > > +++ b/tester/covoar/Target_aarch64.cc
> > > @@ -12,6 +12,7 @@
> > >  #include <rld.h>
> > > +#include "qemu-traces.h"
> > >  #include "Target_aarch64.h"
> > >  namespace Target {
> > > @@ -90,6 +91,16 @@ namespace Target {
> > > +  uint8_t Target_aarch64::qemuTakenBit()
> > > +    return TRACE_OP_BR1;
> > > +  uint8_t Target_aarch64::qemuNotTakenBit()
> > > +    return TRACE_OP_BR0;
> > >    TargetBase *Target_aarch64_Constructor(
> > >      std::string          targetName
> > > diff --git a/tester/covoar/Target_aarch64.h b/tester/covoar/Target_aarch64.h
> > > index 26fedb6..08bd1fb 100644
> > > --- a/tester/covoar/Target_aarch64.h
> > > +++ b/tester/covoar/Target_aarch64.h
> > > @@ -54,6 +54,12 @@ namespace Target {
> > >        const char* const instruction
> > > +    /* Documentation inherited from base class */
> > > +    uint8_t qemuTakenBit() override;
> > > +    uint8_t qemuNotTakenBit() override;
> > >    private:
> > > 2.27.0
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
