[PATCH] Patch attempt two to avoid nameclash of PAGESIZE define
Robin Müller robin.mueller.m at gmail.com
Wed Apr 21 08:57:22 UTC 2021
I just resent the patch and I hope this can be applied properly.
Like already mentioned, when loading this file in Ubuntu 20.04, something
was done to the line endings automatically..
But maybe this is the reason the patch could not be applied before, because
I had the same issue of not being able to apply my patch file.
Kind Regards
Robin
On Wed, 21 Apr 2021 at 10:55, Robin Mueller <robin.mueller.m at gmail.com>
wrote:
> This commit excludes the PAGESIZE legacy define
> because there is a nameclash with a define of the same name
> coming from the RTEMS header limits.h.
>  .../stm32h7/include/Legacy/stm32_hal_legacy.h | 172 +++++++++---------
>  1 file changed, 88 insertions(+), 84 deletions(-)
> diff --git a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> index c311c1618e..804a4c87da 100644
> --- a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> +++ b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> @@ -31,7 +31,7 @@
>  /* Exported constants
>  /** @defgroup HAL_AES_Aliased_Defines HAL CRYP Aliased Defines maintained
> for legacy purpose
> -  * @ingroup RTEMSBSPsARMSTM32H7
> +  * @ingroup RTEMSBSPsARMSTM32H7
>  #define AES_FLAG_RDERR                  CRYP_FLAG_RDERR
> @@ -45,7 +45,7 @@
>  /** @defgroup HAL_ADC_Aliased_Defines HAL ADC Aliased Defines maintained
> for legacy purpose
>  #define ADC_RESOLUTION12b               ADC_RESOLUTION_12B
> @@ -105,7 +105,7 @@
>  /** @defgroup HAL_CEC_Aliased_Defines HAL CEC Aliased Defines maintained
> for legacy purpose
> @@ -116,7 +116,7 @@
>  /** @defgroup HAL_COMP_Aliased_Defines HAL COMP Aliased Defines
> maintained for legacy purpose
>  #define COMP_WINDOWMODE_DISABLED       COMP_WINDOWMODE_DISABLE
> @@ -208,7 +208,7 @@
>  /** @defgroup HAL_CORTEX_Aliased_Defines HAL CORTEX Aliased Defines
>  #define __HAL_CORTEX_SYSTICKCLK_CONFIG HAL_SYSTICK_CLKSourceConfig
> @@ -217,7 +217,7 @@
>  /** @defgroup HAL_CRC_Aliased_Defines HAL CRC Aliased Defines maintained
> for legacy purpose
> @@ -229,7 +229,7 @@
>  /** @defgroup HAL_DAC_Aliased_Defines HAL DAC Aliased Defines maintained
> for legacy purpose
> @@ -258,7 +258,7 @@
>  /** @defgroup HAL_DMA_Aliased_Defines HAL DMA Aliased Defines maintained
> for legacy purpose
>  #define HAL_REMAPDMA_ADC_DMA_CH2                DMA_REMAP_ADC_DMA_CH2
> @@ -392,7 +392,7 @@
>  /** @defgroup HAL_FLASH_Aliased_Defines HAL FLASH Aliased Defines
> @@ -420,7 +420,11 @@
>  #define TYPEPROGRAMDATA_FASTBYTE      FLASH_TYPEPROGRAMDATA_FASTBYTE
>  #define TYPEPROGRAMDATA_FASTHALFWORD  FLASH_TYPEPROGRAMDATA_FASTHALFWORD
>  #define TYPEPROGRAMDATA_FASTWORD      FLASH_TYPEPROGRAMDATA_FASTWORD
> +#ifndef __rtems__
> +/* Commented out for the RTEMS BSP because there can be nameclashes with
> another
> +similar defininition in limits.h */
>  #define PAGESIZE                      FLASH_PAGE_SIZE
> +#endif /* __rtems__ */
>  #define TYPEPROGRAM_FASTBYTE          FLASH_TYPEPROGRAM_BYTE
>  #define TYPEPROGRAM_FASTHALFWORD      FLASH_TYPEPROGRAM_HALFWORD
>  #define TYPEPROGRAM_FASTWORD          FLASH_TYPEPROGRAM_WORD
> @@ -490,7 +494,7 @@
>  /** @defgroup HAL_JPEG_Aliased_Macros HAL JPEG Aliased Macros maintained
> for legacy purpose
> @@ -508,7 +512,7 @@
>  /** @defgroup HAL_SYSCFG_Aliased_Defines HAL SYSCFG Aliased Defines
> @@ -534,7 +538,7 @@
>  /** @defgroup LL_FMC_Aliased_Defines LL FMC Aliased Defines maintained
> for compatibility purpose
>  #if defined(STM32L4) || defined(STM32F7) || defined(STM32H7) ||
> defined(STM32G4)
> @@ -553,7 +557,7 @@
>  /** @defgroup LL_FSMC_Aliased_Defines LL FSMC Aliased Defines maintained
> for legacy purpose
> @@ -564,7 +568,7 @@
>  /** @defgroup HAL_GPIO_Aliased_Macros HAL GPIO Aliased Macros maintained
> for legacy purpose
>  #define GET_GPIO_SOURCE                           GPIO_GET_INDEX
> @@ -631,7 +635,7 @@
>  /** @defgroup HAL_HRTIM_Aliased_Macros HAL HRTIM Aliased Macros
>  #define HRTIM_TIMDELAYEDPROTECTION_DISABLED
>  HRTIM_TIMER_A_B_C_DELAYEDPROTECTION_DISABLED
> @@ -836,7 +840,7 @@
>  /** @defgroup HAL_I2C_Aliased_Defines HAL I2C Aliased Defines maintained
> for legacy purpose
>  #define I2C_DUALADDRESS_DISABLED                I2C_DUALADDRESS_DISABLE
> @@ -860,7 +864,7 @@
>  /** @defgroup HAL_IRDA_Aliased_Defines HAL IRDA Aliased Defines
>  #define IRDA_ONE_BIT_SAMPLE_DISABLED
> @@ -871,7 +875,7 @@
>  /** @defgroup HAL_IWDG_Aliased_Defines HAL IWDG Aliased Defines
>  #define KR_KEY_RELOAD                   IWDG_KEY_RELOAD
> @@ -883,7 +887,7 @@
>  /** @defgroup HAL_LPTIM_Aliased_Defines HAL LPTIM Aliased Defines
> @@ -912,7 +916,7 @@
>  /** @defgroup HAL_NAND_Aliased_Defines HAL NAND Aliased Defines
>  #define HAL_NAND_Read_Page              HAL_NAND_Read_Page_8b
> @@ -932,7 +936,7 @@
>  /** @defgroup HAL_NOR_Aliased_Defines HAL NOR Aliased Defines maintained
> for legacy purpose
>  #define NOR_StatusTypedef              HAL_NOR_StatusTypeDef
> @@ -948,7 +952,7 @@
>  /** @defgroup HAL_OPAMP_Aliased_Defines HAL OPAMP Aliased Defines
> @@ -988,7 +992,7 @@
>  /** @defgroup HAL_I2S_Aliased_Defines HAL I2S Aliased Defines maintained
> for legacy purpose
>  #define I2S_STANDARD_PHILLIPS      I2S_STANDARD_PHILIPS
> @@ -1009,7 +1013,7 @@
>  /** @defgroup HAL_PCCARD_Aliased_Defines HAL PCCARD Aliased Defines
> @@ -1040,7 +1044,7 @@
>  /** @defgroup HAL_RTC_Aliased_Defines HAL RTC Aliased Defines maintained
> for legacy purpose
> @@ -1087,7 +1091,7 @@
>  /** @defgroup HAL_SMARTCARD_Aliased_Defines HAL SMARTCARD Aliased Defines
>  #define SMARTCARD_NACK_ENABLED                  SMARTCARD_NACK_ENABLE
> @@ -1109,7 +1113,7 @@
>  /** @defgroup HAL_SMBUS_Aliased_Defines HAL SMBUS Aliased Defines
>  #define SMBUS_DUALADDRESS_DISABLED      SMBUS_DUALADDRESS_DISABLE
> @@ -1128,7 +1132,7 @@
>  /** @defgroup HAL_SPI_Aliased_Defines HAL SPI Aliased Defines maintained
> for legacy purpose
>  #define SPI_TIMODE_DISABLED             SPI_TIMODE_DISABLE
> @@ -1160,7 +1164,7 @@
>  /** @defgroup HAL_TIM_Aliased_Defines HAL TIM Aliased Defines maintained
> for legacy purpose
>  #define CCER_CCxE_MASK                   TIM_CCER_CCxE_MASK
> @@ -1255,7 +1259,7 @@
>  /** @defgroup HAL_TSC_Aliased_Defines HAL TSC Aliased Defines maintained
> for legacy purpose
>  #define TSC_SYNC_POL_FALL        TSC_SYNC_POLARITY_FALLING
> @@ -1265,7 +1269,7 @@
>  /** @defgroup HAL_UART_Aliased_Defines HAL UART Aliased Defines
>  #define UART_ONEBIT_SAMPLING_DISABLED   UART_ONE_BIT_SAMPLE_DISABLE
> @@ -1297,7 +1301,7 @@
>  /** @defgroup HAL_USART_Aliased_Defines HAL USART Aliased Defines
> @@ -1311,7 +1315,7 @@
>  /** @defgroup HAL_WWDG_Aliased_Defines HAL WWDG Aliased Defines
>  #define CFR_BASE                    WWDG_CFR_BASE
> @@ -1321,7 +1325,7 @@
>  /** @defgroup HAL_CAN_Aliased_Defines HAL CAN Aliased Defines maintained
> for legacy purpose
>  #define CAN_FilterFIFO0             CAN_FILTER_FIFO0
> @@ -1340,7 +1344,7 @@
>  /** @defgroup HAL_ETH_Aliased_Defines HAL ETH Aliased Defines maintained
> for legacy purpose
> @@ -1401,7 +1405,7 @@
>  /** @defgroup HAL_DCMI_Aliased_Defines HAL DCMI Aliased Defines
>  #define HAL_DCMI_ERROR_OVF      HAL_DCMI_ERROR_OVR
> @@ -1421,7 +1425,7 @@
>    || defined(STM32F429xx) || defined(STM32F439xx) || defined(STM32F469xx)
> || defined(STM32F479xx) \
>    || defined(STM32H7)
>  /** @defgroup HAL_DMA2D_Aliased_Defines HAL DMA2D Aliased Defines
>  #define DMA2D_ARGB8888          DMA2D_OUTPUT_ARGB8888
> @@ -1447,7 +1451,7 @@
>  #endif  /* STM32L4 ||  STM32F7 ||  STM32F4 ||  STM32H7 */
>  /** @defgroup HAL_PPP_Aliased_Defines HAL PPP Aliased Defines maintained
> for legacy purpose
> @@ -1458,7 +1462,7 @@
>  /* Exported functions
>  /** @defgroup HAL_CRYP_Aliased_Functions HAL CRYP Aliased Functions
>  #define HAL_CRYP_ComputationCpltCallback
>  HAL_CRYPEx_ComputationCpltCallback
> @@ -1467,7 +1471,7 @@
>  /** @defgroup HAL_HASH_Aliased_Functions HAL HASH Aliased Functions
>  #define HAL_HASH_STATETypeDef        HAL_HASH_StateTypeDef
> @@ -1518,7 +1522,7 @@
>  /** @defgroup HAL_Aliased_Functions HAL Generic Aliased Functions
>  #define HAL_EnableDBGSleepMode HAL_DBGMCU_EnableDBGSleepMode
> @@ -1548,7 +1552,7 @@
>  /** @defgroup HAL_FLASH_Aliased_Functions HAL FLASH Aliased Functions
>  #define FLASH_HalfPageProgram      HAL_FLASHEx_HalfPageProgram
> @@ -1564,7 +1568,7 @@
>  /** @defgroup HAL_I2C_Aliased_Functions HAL I2C Aliased Functions
>  #define HAL_I2CEx_AnalogFilter_Config         HAL_I2CEx_ConfigAnalogFilter
> @@ -1602,7 +1606,7 @@
>  /** @defgroup HAL_PWR_Aliased HAL PWR Aliased maintained for legacy
> purpose
> @@ -1660,7 +1664,7 @@
>  /** @defgroup HAL_SMBUS_Aliased_Functions HAL SMBUS Aliased Functions
>  #define HAL_SMBUS_Slave_Listen_IT          HAL_SMBUS_EnableListen_IT
> @@ -1671,7 +1675,7 @@
>  /** @defgroup HAL_SPI_Aliased_Functions HAL SPI Aliased Functions
>  #define HAL_SPI_FlushRxFifo                HAL_SPIEx_FlushRxFifo
> @@ -1680,7 +1684,7 @@
>  /** @defgroup HAL_TIM_Aliased_Functions HAL TIM Aliased Functions
>  #define HAL_TIM_DMADelayPulseCplt
> @@ -1700,7 +1704,7 @@
>  /** @defgroup HAL_UART_Aliased_Functions HAL UART Aliased Functions
>  #define HAL_UART_WakeupCallback HAL_UARTEx_WakeupCallback
> @@ -1709,7 +1713,7 @@
>  /** @defgroup HAL_LTDC_Aliased_Functions HAL LTDC Aliased Functions
>  #define HAL_LTDC_LineEvenCallback HAL_LTDC_LineEventCallback
> @@ -1722,7 +1726,7 @@
>  /** @defgroup HAL_PPP_Aliased_Functions HAL PPP Aliased Functions
> @@ -1733,7 +1737,7 @@
>  /* Exported macros
>  /** @defgroup HAL_AES_Aliased_Macros HAL CRYP Aliased Macros maintained
> for legacy purpose
>  #define AES_IT_CC                      CRYP_IT_CC
> @@ -1744,7 +1748,7 @@
>  /** @defgroup HAL_Aliased_Macros HAL Generic Aliased Macros maintained
> for legacy purpose
>  #define __HAL_GET_BOOT_MODE                   __HAL_SYSCFG_GET_BOOT_MODE
> @@ -1774,7 +1778,7 @@
>  /** @defgroup HAL_ADC_Aliased_Macros HAL ADC Aliased Macros maintained
> for legacy purpose
>  #define __ADC_ENABLE                                     __HAL_ADC_ENABLE
> @@ -1859,7 +1863,7 @@
>  /** @defgroup HAL_DAC_Aliased_Macros HAL DAC Aliased Macros maintained
> for legacy purpose
>  #define __HAL_DHR12R1_ALIGNEMENT
> DAC_DHR12R1_ALIGNMENT
> @@ -1872,7 +1876,7 @@
>  /** @defgroup HAL_DBGMCU_Aliased_Macros HAL DBGMCU Aliased Macros
>  #define __HAL_FREEZE_TIM1_DBGMCU __HAL_DBGMCU_FREEZE_TIM1
> @@ -1945,7 +1949,7 @@
>  /** @defgroup HAL_COMP_Aliased_Macros HAL COMP Aliased Macros maintained
> for legacy purpose
>  #if defined(STM32F3)
> @@ -2123,7 +2127,7 @@
>  #if defined(STM32L0) || defined(STM32L4)
>  /** @defgroup HAL_COMP_Aliased_Functions HAL COMP Aliased Functions
>  #define HAL_COMP_Start_IT       HAL_COMP_Start /* Function considered as
> legacy as EXTI event or IT configuration is done into HAL_COMP_Init() */
> @@ -2134,7 +2138,7 @@
>  #endif
> for legacy purpose
> @@ -2147,7 +2151,7 @@
>  /** @defgroup HAL_FLASH_Aliased_Macros HAL FLASH Aliased Macros
> @@ -2163,7 +2167,7 @@
>  /** @defgroup HAL_I2C_Aliased_Macros HAL I2C Aliased Macros maintained
> for legacy purpose
> @@ -2191,7 +2195,7 @@
>  /** @defgroup HAL_I2S_Aliased_Macros HAL I2S Aliased Macros maintained
> for legacy purpose
> @@ -2207,7 +2211,7 @@
>  /** @defgroup HAL_IRDA_Aliased_Macros HAL IRDA Aliased Macros maintained
> for legacy purpose
> @@ -2228,7 +2232,7 @@
>  /** @defgroup HAL_IWDG_Aliased_Macros HAL IWDG Aliased Macros maintained
> for legacy purpose
>  #define __HAL_IWDG_ENABLE_WRITE_ACCESS  IWDG_ENABLE_WRITE_ACCESS
> @@ -2239,7 +2243,7 @@
>  /** @defgroup HAL_LPTIM_Aliased_Macros HAL LPTIM Aliased Macros
> @@ -2253,7 +2257,7 @@
>  /** @defgroup HAL_OPAMP_Aliased_Macros HAL OPAMP Aliased Macros
>  #define __OPAMP_CSR_OPAXPD                OPAMP_CSR_OPAXPD
> @@ -2276,7 +2280,7 @@
>  /** @defgroup HAL_PWR_Aliased_Macros HAL PWR Aliased Macros maintained
> for legacy purpose
>  #define __HAL_PVD_EVENT_DISABLE
> __HAL_PWR_PVD_EXTI_DISABLE_EVENT
> @@ -2334,7 +2338,7 @@
>  /** @defgroup HAL_RCC_Aliased HAL RCC Aliased maintained for legacy
> purpose
> @@ -3428,7 +3432,7 @@
>  /** @defgroup HAL_RNG_Aliased_Macros HAL RNG Aliased Macros maintained
> for legacy purpose
>  #define  HAL_RNG_ReadyCallback(__HANDLE__)
> HAL_RNG_ReadyDataCallback((__HANDLE__), uint32_t random32bit)
> @@ -3438,7 +3442,7 @@
>  /** @defgroup HAL_RTC_Aliased_Macros HAL RTC Aliased Macros maintained
> for legacy purpose
>  #if defined (STM32G0) || defined (STM32L5) || defined (STM32L412xx) ||
> defined (STM32L422xx) || defined (STM32L4P5xx) || defined (STM32L4Q5xx) ||
> defined (STM32G4)
> @@ -3499,7 +3503,7 @@
>  /** @defgroup HAL_SD_Aliased_Macros HAL SD Aliased Macros maintained for
> legacy purpose
> @@ -3581,7 +3585,7 @@
>  /** @defgroup HAL_SMARTCARD_Aliased_Macros HAL SMARTCARD Aliased Macros
> @@ -3602,7 +3606,7 @@
>  /** @defgroup HAL_SMBUS_Aliased_Macros HAL SMBUS Aliased Macros
>  #define __HAL_SMBUS_RESET_CR1           SMBUS_RESET_CR1
> @@ -3618,7 +3622,7 @@
>  /** @defgroup HAL_SPI_Aliased_Macros HAL SPI Aliased Macros maintained
> for legacy purpose
> @@ -3631,7 +3635,7 @@
>  /** @defgroup HAL_UART_Aliased_Macros HAL UART Aliased Macros maintained
> for legacy purpose
> @@ -3651,7 +3655,7 @@
>  /** @defgroup HAL_USART_Aliased_Macros HAL USART Aliased Macros
> @@ -3668,7 +3672,7 @@
>  /** @defgroup HAL_USB_Aliased_Macros HAL USB Aliased Macros maintained
> for legacy purpose
>  #define USB_EXTI_LINE_WAKEUP
>  USB_WAKEUP_EXTI_LINE
> @@ -3719,7 +3723,7 @@
>  /** @defgroup HAL_TIM_Aliased_Macros HAL TIM Aliased Macros maintained
> for legacy purpose
>  #define __HAL_TIM_SetICPrescalerValue   TIM_SET_ICPRESCALERVALUE
> @@ -3749,7 +3753,7 @@
>  /** @defgroup HAL_ETH_Aliased_Macros HAL ETH Aliased Macros maintained
> for legacy purpose
> @@ -3769,7 +3773,7 @@
>  /** @defgroup HAL_LTDC_Aliased_Macros HAL LTDC Aliased Macros maintained
> for legacy purpose
>  #define __HAL_LTDC_LAYER LTDC_LAYER
> @@ -3779,7 +3783,7 @@
>  /** @defgroup HAL_SAI_Aliased_Macros HAL SAI Aliased Macros maintained
> for legacy purpose
>  #define SAI_OUTPUTDRIVE_DISABLED          SAI_OUTPUTDRIVE_DISABLE
> @@ -3801,7 +3805,7 @@
>  /** @defgroup HAL_SPDIFRX_Aliased_Macros HAL SPDIFRX Aliased Macros
>  #if defined(STM32H7)
> @@ -3814,7 +3818,7 @@
>  /** @defgroup HAL_HRTIM_Aliased_Functions HAL HRTIM Aliased Functions
>  #if defined (STM32H7) || defined (STM32G4) || defined (STM32F3)
> @@ -3830,7 +3834,7 @@
>  /** @defgroup HAL_QSPI_Aliased_Macros HAL QSPI Aliased Macros maintained
> for legacy purpose
>  #if defined (STM32L4) || defined (STM32F4) || defined (STM32F7) ||
> defined(STM32H7)
> @@ -3841,7 +3845,7 @@
>  /** @defgroup HAL_PPP_Aliased_Macros HAL PPP Aliased Macros maintained
> for legacy purpose
> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210421/b8735751/attachment-0001.html>
