[PATCH rtems-docs v2] legacy-networking: Add note with build instructions for rtems-net-legacy
Vijay Kumar Banerjee vijay at rtems.org
Mon Apr 26 14:31:56 UTC 2021
On Mon, Apr 26, 2021 at 8:23 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Apr 22, 2021 at 8:58 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>>  legacy-networking/index.rst       |  1 +
>>  legacy-networking/quick_start.rst | 33 +++++++++++++++++++++++++++++++
>>  2 files changed, 34 insertions(+)
>>  create mode 100644 legacy-networking/quick_start.rst
>> diff --git a/legacy-networking/index.rst b/legacy-networking/index.rst
>> index b85119d..acbfd35 100644
>> --- a/legacy-networking/index.rst
>> +++ b/legacy-networking/index.rst
>> @@ -22,6 +22,7 @@ RTEMS Legacy Network User Manual (|version|).
>>         :numbered:
>>         preface
>> +       quick_start
>>         network_task_structure
>>         networking_driver
>>         using_networking_rtems_app
>> diff --git a/legacy-networking/quick_start.rst b/legacy-networking/quick_start.rst
>> new file mode 100644
>> index 0000000..fc2fee5
>> --- /dev/null
>> +++ b/legacy-networking/quick_start.rst
>> @@ -0,0 +1,33 @@
>> +.. SPDX-License-Identifier: CC-BY-SA-4.0
>> +Quick Start
>> +This legacy networking is now a standalone repository and needs to be built
>> +separately.
>> +The repository can be found here: https://git.rtems.org/rtems-net-legacy/
>> +There's an RSB recipe to build rtems-net-legacy. Here's an example of building
>> +rtems-net-legacy using RSB for powerpc beatnik BSP with rtems version 6:
> I think we try to say CPU/BSP for powerpc/beatnik.
Pushed with this change. Does it look good?
https://git.rtems.org/rtems-docs/commit/?id=199cc8e5764881e3fd83966c842c25c055444b86
> Fix this and push it IMO.
>> +  .. code-block:: shell
>> +        ../source-builder/sb-set-builder \
>> +        --prefix=/path/to/rtems/prefix \
>> +        6/rtems-net-legacy \
>> +        --host=powerpc-rtems6 \
>> +        --with-rtems-bsp=beatnik
>> +Manually building the rtems-net-legacy repo:
>> +        git submodule init
>> +        git submodule update
>> +        ./waf configure --prefix=/path/to/rtems/prefix
>> +        ./waf
>> +        ./waf install
>> +Please refer to README.waf in rtems-net-legacy repository for more details on
>> +using waf with legacy networking.
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
