[PATCH] STM32 lwIP addition
Robin Müller robin.mueller.m at gmail.com
Wed Apr 28 10:00:14 UTC 2021
Small correction: I changed the ethernetif.c file to be usable by all three
major APIs.
Kind Regards
Robin
On Wed, 28 Apr 2021 at 11:55, Robin Müller <robin.mueller.m at gmail.com>
wrote:
> Should I provide the changes for the code review as a separate patch or
> should I squash them again?
> Using the upstream unchanged is tricky because the code was taken from the
> examples and these examples are always targeted towards a specific API.
> I changed the version to be usable by both APIs. I now applied the
> __rtems__ preprocessor defines where applicable and moved the preprocessor
> defines into a separate file.
> Kind Regards
> Robin
> On Tue, 27 Apr 2021 at 22:21, Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Apr 27, 2021 at 2:09 PM Gedare Bloom <gedare at rtems.org> wrote:
>> > On Tue, Apr 27, 2021 at 11:41 AM Robin Mueller
>> > <robin.mueller.m at gmail.com> wrote:
>> I'm not sure what happened, it looks like my email client garbled the
>> inline threaded reply. Hopefully my comments come through for you ok.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210428/64a3adf4/attachment-0001.html>
