Guidance on constructing an RTEMS6 BSP
groups at chichak.ca groups at chichak.ca
Tue Aug 10 06:31:03 UTC 2021
Hi Sebastian,
So far there is no code. The BSP won’t build. The only code is:
../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 --target=arm-rtems6 --with-rtems-bsp=stm32f4 --with-rtems-tests=yes 6/rtems-kernel
Andrei
> On 2021-August-10, at 00:20, Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello Andrei,
> sorry, I am a bit busy at the moment. I would try to share as much code as possible (not easy with the STM source code organization) and use BSP options to customize for the variants.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/ <https://embedded-brains.de/datenschutzerklaerung/>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210810/f7fd39d3/attachment-0001.html>
