[PATCH] Avoid ISR_LOCK_MEMBER() since it confuses Doxygen
Thu Dec 9 12:46:09 UTC 2021
If RTEMS_SMP is not defined, then Doxygen adds the comments intended for
conditional the lock member to the next member.
 cpukit/include/rtems/rtems/partdata.h    | 4 +++-
 cpukit/include/rtems/rtems/ratemondata.h | 4 +++-
 cpukit/include/rtems/score/percpu.h      | 4 +++-
 cpukit/include/rtems/score/scheduler.h   | 4 ++--
 cpukit/include/rtems/score/thread.h      | 4 +++-
 cpukit/include/rtems/score/userextimpl.h | 4 +++-
 6 files changed, 17 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partdata.h b/cpukit/include/rtems/rtems/partdata.h
index 196c2142ae..a6bcee229a 100644
--- a/cpukit/include/rtems/rtems/partdata.h
+++ b/cpukit/include/rtems/rtems/partdata.h
@@ -41,11 +41,13 @@ typedef struct {
   Objects_Control Object;
+#if defined(RTEMS_SMP)
    * @brief This lock protects the chain of unallocated buffers and the number
    *   of allocated buffers.
-  ISR_LOCK_MEMBER( Lock )
+  ISR_lock_Control Lock;
+#endif
    * @brief This member contains the base address of the buffer area.
diff --git a/cpukit/include/rtems/rtems/ratemondata.h b/cpukit/include/rtems/rtems/ratemondata.h
index f35fa7eb61..700285c7b4 100644
--- a/cpukit/include/rtems/rtems/ratemondata.h
+++ b/cpukit/include/rtems/rtems/ratemondata.h
@@ -71,10 +71,12 @@ typedef struct {
   /** This field is the object management portion of a Period instance. */
    * @brief Protects the rate monotonic period state.
+#endif
   /** This is the timer used to provide the unblocking mechanism. */
   Watchdog_Control                        Timer;
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 0794f15f69..1dfa7f628d 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -465,10 +465,12 @@ typedef struct Per_CPU_Control {
    * @brief Watchdog state for this processor.
   struct {
      * @brief Protects all watchdog operations on this processor.
+#endif
      * @brief Watchdog ticks on this processor used for monotonic clock
diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
index 95b4414bea..55be638a8d 100644
--- a/cpukit/include/rtems/score/scheduler.h
+++ b/cpukit/include/rtems/score/scheduler.h
@@ -297,12 +297,12 @@ typedef struct {
  * this structure at the begin of its context structure.
 typedef struct Scheduler_Context {
    * @brief Lock to protect this scheduler instance.
-#if defined(RTEMS_SMP)
    * @brief The set of processors owned by this scheduler instance.
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index c3c37eb160..adde98f9bf 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -673,10 +673,12 @@ typedef struct {
   RBTree_Control Key_value_pairs;
    * @brief Lock to protect the tree operations.
+#endif
 } Thread_Keys_information;
diff --git a/cpukit/include/rtems/score/userextimpl.h b/cpukit/include/rtems/score/userextimpl.h
index fd075a94ec..649d191b18 100644
--- a/cpukit/include/rtems/score/userextimpl.h
+++ b/cpukit/include/rtems/score/userextimpl.h
@@ -60,11 +60,13 @@ typedef struct {
   Chain_Iterator_registry Iterators;
    * @brief Lock to protect User_extensions_List::Active and
    * User_extensions_List::Iterators.
+#endif
 } User_extensions_List;
2.31.1
