[PATCH rtems-tools 5/6] ObjdumpProcessor.h: Fix formatting
Ryan Long ryan.long at oarcorp.com
Mon Dec 13 16:09:32 UTC 2021
 tester/covoar/ObjdumpProcessor.h | 22 ++++++++++------------
 1 file changed, 10 insertions(+), 12 deletions(-)
diff --git a/tester/covoar/ObjdumpProcessor.h b/tester/covoar/ObjdumpProcessor.h
index 0ca14b8..b3c7262 100644
--- a/tester/covoar/ObjdumpProcessor.h
+++ b/tester/covoar/ObjdumpProcessor.h
@@ -91,7 +91,7 @@ namespace Coverage {
      *  This method constructs an ObjdumpProcessor instance.
     ObjdumpProcessor(
-      DesiredSymbols&     symbolsToAnalyze,
+      DesiredSymbols&                      symbolsToAnalyze,
       std::shared_ptr<Target::TargetBase>& targetInfo
@@ -100,24 +100,24 @@ namespace Coverage {
     virtual ~ObjdumpProcessor();
-    uint32_t determineLoadAddress(
-      ExecutableInfo* theExecutable
+    uint32_t determineLoadAddress( ExecutableInfo* theExecutable );
      *  This method fills a tempfile with the .text section of objdump
      *  for the given file name.
-    void getFile( std::string fileName,
-                  rld::process::tempfile& dmp,
-                  rld::process::tempfile& err );
+    void getFile(
+      std::string             fileName,
+      rld::process::tempfile& dmp,
+      rld::process::tempfile& err
      *  This method fills the objdumpList list with all the
      *  instruction addresses in the object dump file.
     void loadAddressTable (
-      ExecutableInfo* const executableInformation,
+      ExecutableInfo* const   executableInformation,
@@ -150,9 +150,7 @@ namespace Coverage {
      *  the given line in the objdmp file is a branch instruction,
      *  otherwise it returns false.
-    bool isBranchLine(
-      const std::string& line
+    bool isBranchLine( const std::string& line );
      * This method sets the targetInfo_m variable.
@@ -167,7 +165,7 @@ namespace Coverage {
      *  This variable consists of a list of all instruction addresses
      *  extracted from the obj dump file.
-    objdumpFile_t       objdumpList;
+    objdumpFile_t objdumpList;
      *  This method determines whether the specified line is a
1.8.3.1
