Alternative download paths for RSB?
Tue Dec 21 19:37:22 UTC 2021
On Tue, Dec 21, 2021, 12:45 PM Chris Johns <chrisj at rtems.org> wrote:
> On 22/12/21 1:45 am, Joel Sherrill wrote:
> > On Tue, Dec 21, 2021 at 12:33 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 20/12/2021 22:52, Chris Johns wrote:
> >>> On 21/12/21 2:33 am, Joel Sherrill wrote:
> >>>> On Mon, Dec 20, 2021 at 8:54 AM Joel Sherrill <joel at rtems.org> wrote:
> >>>>> On Mon, Dec 20, 2021 at 6:59 AM Sebastian Huber
> >>>>>> Hello,
> >>>>>> it seems the GNU web server is down:
> >>>>> Yep. Still down.
> >>>>> i reached out to the sourceware admins to see if they knew who to
> >>>>> contact. I couldn't find a gnu.org address.
> >>>> Social media post from FSF forwarded by one of the sourceware admins
> >>>> about a general outage at the FSF:
> >>>> https://hostux.social/@fsfstatus/107479476196064925
> >>>> Looks to be up now. RSB handling mirrors would be good. Although
> >>>> it would seem to be complex to ensure that all entries and mirrors are
> >>>> correct.
> >>>>>> download: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2 ->
> >>>>>> sources/mpfr-3.1.4.tar.bz2
> >>>>>> download: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2: error:
> >>>>>> <urlopen error [Errno 101] Network is unreachable>
> >>>>>> error: downloading https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2:
> all
> >>>>>> paths have failed, giving up
> >>>>>> Build FAILED
> all
> >>>>>> Build Set: Time 0:04:23.318509
> >>>>>> Build FAILED
> >>>>>> The error message suggests that it is possible to add alternative
> >>>>>> download sources. How can I do this? This didn't work:
> >>>>>> diff --git a/source-builder/config/gcc-9.cfg
> >>>>>> b/source-builder/config/gcc-9.cfg
> >>>>>> index f8cf69b..1d7c716 100644
> >>>>>> --- a/source-builder/config/gcc-9.cfg
> >>>>>> +++ b/source-builder/config/gcc-9.cfg
> >>>>>> @@ -21,4 +21,8 @@
> >>>>>>    %source set gmp
> https://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
> >>>>>>    %source set mpfr
> https://ftp.gnu.org/gnu/mpfr/mpfr-%{mpfr_version}.tar.bz2
> >>>>>> +%source set mpc
> https://ftp.mpi-inf.mpg.de/pub/mirrors/gnu/mirror/gcc.gnu.org/pub/gcc/infrastructure/mpc-%{mpc_version}.tar.gz
> >>>>>> +%source set gmp
> https://ftp.mpi-inf.mpg.de/pub/mirrors/gnu/mirror/gcc.gnu.org/pub/gcc/infrastructure/gmp-%{gmp_version}.tar.bz2
> >>>>>> +%source set mpfr
> https://ftp.mpi-inf.mpg.de/pub/mirrors/gnu/mirror/gcc.gnu.org/pub/gcc/infrastructure/mpfr-%{mpfr_version}.tar.bz2
> >>>>>>    %include %{_configdir}/gcc-common-1.cfg
> >>>>> This would be Chris' department. Sorry
> >>> I would update the `%source` keyword to accept:
> >>> %source mirror mpc 1
> https://ftp.mpi-inf.mpg.de/../mpc-%{mpc_version}.tar.gz
> >>> where `1` is an integer priority and 1 is highest. The code is here:
> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/sources.py#n55
> >>> There is no such thing as a list in the macros so I suspect you would
> need to
> >>> dereference the source where the results of `_make_key` would
> reference another
> >>> series of macro keys that are the mirrors.
> >>> Do we want to start maintaining lists of mirrors in RSB
> configurations? I am
> >>> undecided. As developers we do not notice the online status due to the
> RSB
> >>> cache. For sites and users would deployment be a better long term
> solution?
> >> Thanks for the hints. I added a ticket for this:
> >> https://devel.rtems.org/ticket/4573
> > How can we ensure that all mirrors listed work?
> They would need to be tested and that means more code in the RSB to do it.
And another thing to check. Worries me.
> Chris
