[PATCH v3] bsps/shared/ofw: Fix coverity reported defects
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Feb 5 08:58:51 UTC 2021
Am 05.02.21 um 09:45 schrieb Niteesh G. S.:
> On Fri, Feb 5, 2021 at 12:22 AM Christian Mauderer
> <contact at c-mauderer.de <mailto:contact at c-mauderer.de>> wrote:
>     On 04/02/2021 17:34, Gedare Bloom wrote:
>      > On Thu, Feb 4, 2021 at 1:58 AM Niteesh G. S.
>     <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>
>      > <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>> wrote:
>      >     On Thu, Feb 4, 2021 at 1:21 AM Gedare Bloom <gedare at rtems.org
>     <mailto:gedare at rtems.org>
>      >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
>      >         On Wed, Feb 3, 2021 at 2:48 AM G S Niteesh Babu
>      >             Fixed use after free and null pointer dereference defects
>      >             FIXES:
>      >             1) CID 1472601 (NULL_RETURNS)
>      >             2) CID 1472600 (USE_AFTER_FREE)
>      >             3) CID 1472599 (USE_AFTER_FREE)
>      >             4) CID 1472598 (USE_AFTER_FREE)
>      >             5) CID 1472596 (USE_AFTER_FREE)
>      >             6) CID 1472597 (ARRAY_VS_SINGLETON)
>      >             7) CID 1472595 (ARRAY_VS_SINGLETON)
>      >               bsps/shared/ofw/ofw.c | 36
>      >               1 file changed, 18 insertions(+), 18 deletions(-)
>      >             diff --git a/bsps/shared/ofw/ofw.c
>     b/bsps/shared/ofw/ofw.c
>      >             index 82924b2600..ccd57e36af 100644
>      >             --- a/bsps/shared/ofw/ofw.c
>      >             +++ b/bsps/shared/ofw/ofw.c
>      >             @@ -313,7 +313,7 @@ ssize_t rtems_ofw_get_prop_alloc(
>      >                   if (rtems_ofw_get_prop(node, propname, *buf,
>     len) == -1) {
>      >             -      rtems_ofw_free(buf);
>      >             +      rtems_ofw_free(*buf);
>      >                     *buf = NULL;
>      >                     return -1;
>      >             @@ -344,7 +344,7 @@ ssize_t
>     rtems_ofw_get_prop_alloc_multi(
>     len) == -1) {
>      >                     *buf = NULL;
>      >                     return -1;
>      >             @@ -373,7 +373,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc(
>      >                   if (rtems_ofw_get_enc_prop(node, propname,
>     *buf, len)
>      >             == -1) {
>      >                     *buf = NULL;
>      >                     return -1;
>      >             @@ -404,7 +404,7 @@ ssize_t
>     rtems_ofw_get_enc_prop_alloc_multi(
>     *buf, len)
>      >             == -1) {
>      >                     *buf = NULL;
>      >                     return -1;
>      >         The above all look fine to me.
>      >             @@ -500,21 +500,21 @@ static phandle_t
>      >             rtems_ofw_get_effective_phandle(
>      >                 phandle_t child;
>      >             -  phandle_t ref;
>      >             +  phandle_t ref[1];
>      >         I don't like this. I know this was suggested, but I think
>     it is
>      >         a little ridiculous. This is a false positive since we
>     know that
>      >         sizeof(*buf) == len. I don't know if we can make that an
>      >         assertion. Otherwise, we can just mark this as a false
>     positive
>      >         in coverity. We know the array dereference in this case won't
>      >         overwrite past the bounds of ref.
>      >         Instead of using hard-coded values of 4
>      >         in rtems_ofw_get_enc_prop() you might make it more explicitly
>      >         using sizeof(pcell_t), since that is what you mean.
>      >     Done.
>      >         I would also agree to change the strncpy as Christian
>     identified
>      >         before in rtems_ofw_get_prop().
>      >     Is the reason to avoid strncpy that it ignores the null byte if
>      >     len(dst) <= len(src)?
>      >     If so can I do an explicit null byte append?
>      >     Or is there any other reason?
>      > The reason is that it passes void* pointers. If these are
>     strings, you
>      > should use char* type. Otherwise, memcpy is more suitable.
>      > It also would be generally safer to overwrite with the NIL
>     character to
>      > guarantee it is a null-terminated string, if that is expected.
>     That was not the only reason. Let me pull the relevant lines together
>     (reordered and pulled from multiple files):
>     typedef uint32_t  pcell_t;
>         phandle_t    node,
>         const char  *prop,
>         pcell_t     *buf,
>         size_t       len
>         rv = rtems_ofw_get_prop(node, prop, buf, len);
>     rtems_ofw_get_prop(
>         phandle_t    node,
>         const char  *propname,
>         void        *buf,
>         size_t       bufsize
>           strncpy(buf, prop, bufsize);
>     Let's say I do the following call:
>     rtems_ofw_get_enc_prop(node, "name", &foo, sizeof(foo));
>     In that case the code is using a strncpy to copy into a uint32_t.
>     That's
>     not a good idea. What if there is (for example) a value of
>     0x00110011 in
>     the property? strncpy will find one of these two 0 bytes and stop
>     there.
>     I'm not sure which one because endianess will have an influence on that
>     too. Note that I'm not sure whether using rtems_ofw_get_enc_prob with
>     these parameters is a useful call. But it's possible and it's a bad
>     idea
>     if it results in an undefined behavior.
> OK.
> Summarizing changes since the last posted patch (v3)
> 1) Using a variable instead of an array for CID 1472597, 1472595
>      so this has to be marked as a false positive in Coverity since we
>      guarantee that we don't overflow.
> 2) rtems_ofw_get_effective_phandle is now iterative instead of recursive.
> 3) Using memcpy instead of strncpy
> 4) I have also fixed another bug, should I post it as part of this patch
> or a
> separate patch?
I would suggest to create a separate patch or a patch set. This one is
quite Coverity related. 2, 3 and 4 are improvements or bug fixes and
don't have to do anything with Coverity.
> Thanks,
> Niteesh.
>     Best regards
>     Christian
>      >                 for (child = rtems_ofw_child(node); child != 0;
>     child =
>      >             rtems_ofw_peer(child)) {
>      >             -    ref = rtems_ofw_get_effective_phandle(child, xref);
>      >             -    if (ref != -1)
>      >             -      return ref;
>      >             +    ref[0] = rtems_ofw_get_effective_phandle(child,
>     xref);
>      >         I didn't notice before, but is this recursion
>     bounded (yes, it
>      >         is a tree, but it might be better to rewrite this function
>      >         non-recursively).
>      >     Just curious why is it better? Is it because it might use a
>     lot of
>      >     stack frames?
>      >     I can only think of using stack or queue to implement it
>      >     non-recursively. Is there
>      >     any other way?
>      > Recursion causes two potential problems: large stack usage and
>      > hard-to-analyze execution times. These are generally important
>     for an
>      > RTOS to be wary of.
>      > This looks like a depth-first search to find xref? But the tree
>      > traversal order doesn't matter. In fact, I would check if the FDT
>     can be
>      > iterated directly. I don't know enough about the FDT structure to
>     say
>      > whether that is simple to do. If you start at the root and
>     repeatedly
>      > call fdt_next_node()  do you traverse all the nodes?
>      > You can implement non-recursive tree searches using nested loops
>     when
>      > you have sibling, child, and parent pointers. Probably, you can find
>      > code examples of how to do this. The basic idea is pretty simple
>     though,
>      > here is a DFS:
>      > node = root
>      > do {
>      >    visit(node)
>      >    next_node = child_of(node)
>      >    if ( ! next_node ) {
>      >      while ( !has_sibling(node) && node != root) {
>      >          node = parent_of(node) /* back up */
>      >      next_node = sibling_of(node)
>      >    node = next_node;
>      > } while (node)
>      > This pseudocode assumes the root has a NULL-value sibling and leaves
>      > have NULL-value children. I also didn't test it, but the rough idea
>      > should work. You can do something similar with BFS.
>      >             +    if (ref[0] != -1)
>      >             +      return ref[0];
>      >             -    if (rtems_ofw_get_enc_prop(child, "phandle", &ref,
>      >             sizeof(ref)) == -1 &&
>      >             -        rtems_ofw_get_enc_prop(child, "ibm,phandle",
>     &ref,
>      >             -        rtems_ofw_get_enc_prop(child, "linux,phandle",
>      >             &ref, sizeof(ref)) == -1
>      >             +    if (rtems_ofw_get_enc_prop(child, "phandle", ref,
>      >             +        rtems_ofw_get_enc_prop(child, "ibm,phandle",
>     ref,
>     "linux,phandle", ref,
>      >             sizeof(ref)) == -1
>      >                     continue;
>      >             -    if (ref == xref)
>      >             +    if (ref[0] == xref)
>      >                     return child;
>      >             @@ -533,16 +533,16 @@ phandle_t rtems_ofw_node_from_xref(
>      >             phandle_t xref )
>      >               phandle_t rtems_ofw_xref_from_node( phandle_t node )
>      >             -  phandle_t ref;
>      >             +  phandle_t ref[1];
>      >             -    if (rtems_ofw_get_enc_prop(node, "phandle", &ref,
>      >             -        rtems_ofw_get_enc_prop(node, "ibm,phandle",
>     &ref,
>     "linux,phandle", &ref,
>      >             sizeof(ref)) == -1)
>      >             +    if (rtems_ofw_get_enc_prop(node, "phandle", ref,
>      >             +        rtems_ofw_get_enc_prop(node, "ibm,phandle", ref,
>      >             sizeof(ref)) == -1)
>      >                     return node;
>      >             -    return ref;
>      >             +    return ref[0];
>      >               phandle_t rtems_ofw_instance_to_package( ihandle_t
>     instance )
>      >             @@ -614,7 +614,7 @@ int rtems_ofw_get_reg(
>      >                   offset = rtems_fdt_phandle_to_offset(parent);
>      >                   ptr = fdt_getprop(fdtp, offset, "ranges", &len);
>      >             -    if (len < 0) {
>      >             +    if (ptr == NULL) {
>      >                     break;
>      >             2.17.1
>      >             _______________________________________________
>      >             devel mailing list
>      > devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org
>     <mailto:devel at rtems.org>>
>      > http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
>     <http://lists.rtems.org/mailman/listinfo/devel>>
>      > devel mailing list
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
