[RTEMS 5 PATCH] bsp/motorola_powerp: Print RTEMS_VERSION from the bootloader
Mon Feb 8 21:45:32 UTC 2021
On Mon, Feb 8, 2021 at 2:04 PM Chris Johns <chrisj at rtems.org> wrote:
> On 9/2/21 5:18 am, Gedare Bloom wrote:
> > If you put this on master/6, you can switch that align to use
> > RTEMS_ALIGN_UP(addr, PAGE_SIZE) -- not PAGE_MASK
> Sorry, I had already pushed the patch.
> A quick grep shows there are a few of these ...
>  $ grep -r PAGE_MASK *
> 0001-bsp-motorola_powerp-Print-RTEMS_VERSION-from-the-boo.patch: #define
> PAGE_ALIGN(addr)       (((addr) + PAGE_MASK) & ~PAGE_MASK)
> 0002-bsp-motorola_powerp-Print-RTEMS_VERSION-from-the-boo.patch: #define
> bsps/powerpc/motorola_powerpc/bootloader/mm.c:#define PAGE_ALIGN(addr)
> (((addr)
> bsps/powerpc/motorola_powerpc/bootloader/mm.c:                  rpn =
> (vaddr&PAGE_MASK)-area->base+area->firstpte;
> bsps/powerpc/motorola_powerpc/bootloader/mm.c:  if (mask&PAGE_MASK) {
> bsps/powerpc/motorola_powerpc/bootloader/misc.c:#define PAGE_ALIGN(addr)
> bsps/powerpc/include/libcpu/pgtable.h:#define _PAGE_CHG_MASK    (PAGE_MASK
> _PAGE_ACCESSED | _PAGE_DIRTY)
> bsps/powerpc/shared/start/pgtbl_setup.c:#define PAGE_ALIGN(addr)
> (((addr)
> cpukit/libnetworking/vm/vm_param.h:     ((vm_offset_t)((((vm_offset_t)(x))
> PAGE_MASK) >> PAGE_SHIFT))
> cpukit/posix/src/mmap.c:    if ((uintptr_t)addr & PAGE_MASK) {
> Do all these needs to be looked at as well?
> Probably should. This is only for 6+ version, to help with consistency.
Some of those appear to be actual PAGE_MASK uses, but the alignment macros
should use the shared RTEMS_ALIGN* for easier validation.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210208/9e178014/attachment.html>
