[PATCH 1/1] zynq-uart: Fix set_attributes implementation
Jan Sommer jan.sommer at dlr.de
Tue Feb 9 12:42:32 UTC 2021
The zynq-uart set_attributes implementation was configured to always
return false which causes spconsole01 to fail. This restores the
disabled implementation which sets the baud rate registers
appropriately and allows spconsole01 to pass. This also expands the
set_attributes functionality to allow setting of the stop bits,
character width, and parity.
 bsps/arm/include/bsp/zynq-uart.h          |  7 +++
 bsps/arm/shared/serial/zynq-uart-polled.c |  2 +-
 bsps/arm/shared/serial/zynq-uart.c        | 56 +++++++++++++++++++++--
 3 files changed, 59 insertions(+), 6 deletions(-)
diff --git a/bsps/arm/include/bsp/zynq-uart.h b/bsps/arm/include/bsp/zynq-uart.h
index 20c3c9b653..5a6c926bec 100644
--- a/bsps/arm/include/bsp/zynq-uart.h
+++ b/bsps/arm/include/bsp/zynq-uart.h
@@ -71,6 +71,13 @@ void zynq_uart_write_polled(
 void zynq_uart_reset_tx_flush(zynq_uart_context *ctx);
+int zynq_cal_baud_rate(
+  uint32_t  baudrate,
+  uint32_t* brgr,
+  uint32_t* bauddiv,
+  uint32_t  modereg
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/bsps/arm/shared/serial/zynq-uart-polled.c b/bsps/arm/shared/serial/zynq-uart-polled.c
index e6f478ee07..7fc9590832 100644
--- a/bsps/arm/shared/serial/zynq-uart-polled.c
+++ b/bsps/arm/shared/serial/zynq-uart-polled.c
@@ -40,7 +40,7 @@ uint32_t zynq_uart_input_clock(void)
   return ZYNQ_CLOCK_UART;
-static int zynq_cal_baud_rate(uint32_t  baudrate,
+int zynq_cal_baud_rate(uint32_t  baudrate,
                               uint32_t* brgr,
                               uint32_t* bauddiv,
                               uint32_t  modereg)
diff --git a/bsps/arm/shared/serial/zynq-uart.c b/bsps/arm/shared/serial/zynq-uart.c
index fc670441b8..a0dfc0c929 100644
--- a/bsps/arm/shared/serial/zynq-uart.c
+++ b/bsps/arm/shared/serial/zynq-uart.c
@@ -142,25 +142,71 @@ static bool zynq_uart_set_attributes(
   const struct termios *term
-#if 0
-  volatile zynq_uart *regs = zynq_uart_get_regs(minor);
+  zynq_uart_context *ctx = (zynq_uart_context *) context;
+  volatile zynq_uart *regs = ctx->regs;
   uint32_t brgr = 0;
   uint32_t bauddiv = 0;
+  uint32_t mode = 0;
   int rc;
   rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
   if (rc != 0)
     return rc;
+   * Configure the mode register
+  mode |= ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL);
+   * Parity
+  mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_NONE);
+  if (term->c_cflag & PARENB) {
+    if (!(term->c_cflag & PARODD)) {
+      mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_ODD);
+    } else {
+      mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_EVEN);
+   * Character Size
+  switch (term->c_cflag & CSIZE)
+  case CS5:
+    return false;
+  case CS6:
+    mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_6);
+    break;
+  case CS7:
+    mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_7);
+    break;
+  case CS8:
+  default:
+    mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8);
+    break;
+   * Stop Bits
+  if (term->c_cflag & CSTOPB) {
+    /* 2 stop bits */
+    mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_2);
+  } else {
+    /* 1 stop bit */
+    mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_1);
   regs->control &= ~(ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN);
+  regs->mode = mode;
   regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
   regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
   regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
   return true;
-#else
-  return false;
-#endif
 const rtems_termios_device_handler zynq_uart_handler = {
2.17.1
