[PATCH 1/2] validation: Improve task construct error tests
Fri Feb 26 13:46:20 UTC 2021
 .../validation/tc-task-construct-errors.c     | 1874 ++++++++++++-----
 1 file changed, 1353 insertions(+), 521 deletions(-)
diff --git a/testsuites/validation/tc-task-construct-errors.c b/testsuites/validation/tc-task-construct-errors.c
index 420497df5f..cb8106e270 100644
--- a/testsuites/validation/tc-task-construct-errors.c
+++ b/testsuites/validation/tc-task-construct-errors.c
@@ -80,6 +80,12 @@ typedef enum {
   RtemsTaskReqConstructErrors_Pre_Name_NA
 } RtemsTaskReqConstructErrors_Pre_Name;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_SysTsk_Yes,
+  RtemsTaskReqConstructErrors_Pre_SysTsk_No,
+  RtemsTaskReqConstructErrors_Pre_SysTsk_NA
+} RtemsTaskReqConstructErrors_Pre_SysTsk;
 typedef enum {
   RtemsTaskReqConstructErrors_Pre_Prio_Valid,
   RtemsTaskReqConstructErrors_Pre_Prio_Zero,
@@ -111,12 +117,6 @@ typedef enum {
   RtemsTaskReqConstructErrors_Pre_Ext_NA
 } RtemsTaskReqConstructErrors_Pre_Ext;
-typedef enum {
-  RtemsTaskReqConstructErrors_Pre_Preempt_Yes,
-  RtemsTaskReqConstructErrors_Pre_Preempt_No,
-  RtemsTaskReqConstructErrors_Pre_Preempt_NA
-} RtemsTaskReqConstructErrors_Pre_Preempt;
 typedef enum {
   RtemsTaskReqConstructErrors_Post_Status_Ok,
   RtemsTaskReqConstructErrors_Post_Status_InvAddr,
@@ -140,12 +140,24 @@ typedef enum {
   RtemsTaskReqConstructErrors_Post_IdValue_NA
 } RtemsTaskReqConstructErrors_Post_IdValue;
+typedef enum {
+  RtemsTaskReqConstructErrors_Post_CreateExt_Yes,
+  RtemsTaskReqConstructErrors_Post_CreateExt_No,
+  RtemsTaskReqConstructErrors_Post_CreateExt_NA
+} RtemsTaskReqConstructErrors_Post_CreateExt;
 typedef enum {
   RtemsTaskReqConstructErrors_Post_DelExt_Yes,
   RtemsTaskReqConstructErrors_Post_DelExt_No,
   RtemsTaskReqConstructErrors_Post_DelExt_NA
 } RtemsTaskReqConstructErrors_Post_DelExt;
+typedef enum {
+  RtemsTaskReqConstructErrors_Post_StoFree_Yes,
+  RtemsTaskReqConstructErrors_Post_StoFree_No,
+  RtemsTaskReqConstructErrors_Post_StoFree_NA
+} RtemsTaskReqConstructErrors_Post_StoFree;
  * @brief Test context for spec:/rtems/task/req/construct-errors test case.
@@ -160,8 +172,12 @@ typedef struct {
   bool create_extension_status;
+  uint32_t create_extension_calls;
   uint32_t delete_extension_calls;
+  uint32_t storage_free_calls;
   size_t stack_size;
   rtems_id extension_id;
@@ -195,6 +211,12 @@ static const char * const RtemsTaskReqConstructErrors_PreDesc_Name[] = {
   "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_SysTsk[] = {
+  "Yes",
+  "No",
+  "NA"
 static const char * const RtemsTaskReqConstructErrors_PreDesc_Prio[] = {
   "Valid",
   "Zero",
@@ -226,21 +248,15 @@ static const char * const RtemsTaskReqConstructErrors_PreDesc_Ext[] = {
   "NA"
-static const char * const RtemsTaskReqConstructErrors_PreDesc_Preempt[] = {
-  "Yes",
-  "No",
-  "NA"
 static const char * const * const RtemsTaskReqConstructErrors_PreDesc[] = {
   RtemsTaskReqConstructErrors_PreDesc_Id,
   RtemsTaskReqConstructErrors_PreDesc_Name,
+  RtemsTaskReqConstructErrors_PreDesc_SysTsk,
   RtemsTaskReqConstructErrors_PreDesc_Prio,
   RtemsTaskReqConstructErrors_PreDesc_Free,
   RtemsTaskReqConstructErrors_PreDesc_TLS,
   RtemsTaskReqConstructErrors_PreDesc_Stack,
   RtemsTaskReqConstructErrors_PreDesc_Ext,
-  RtemsTaskReqConstructErrors_PreDesc_Preempt,
   NULL
@@ -271,6 +287,12 @@ static const rtems_task_config seize_task_config = {
   .attributes = RTEMS_DEFAULT_MODES
+static void StorageFree( void *ptr )
+  T_eq_ptr( ptr, task_storage );
+  ++RtemsTaskReqConstructErrors_Instance.storage_free_calls;
 static rtems_status_code Create( void *arg, uint32_t *id )
   Context          *ctx;
@@ -291,6 +313,7 @@ static bool ThreadCreate( rtems_tcb *executing, rtems_tcb *created )
   (void) executing;
   (void) created;
+  ++RtemsTaskReqConstructErrors_Instance.create_extension_calls;
   return RtemsTaskReqConstructErrors_Instance.create_extension_status;
@@ -349,6 +372,27 @@ static void RtemsTaskReqConstructErrors_Pre_Name_Prepare(
+static void RtemsTaskReqConstructErrors_Pre_SysTsk_Prepare(
+  RtemsTaskReqConstructErrors_Context   *ctx,
+  RtemsTaskReqConstructErrors_Pre_SysTsk state
+  switch ( state ) {
+    case RtemsTaskReqConstructErrors_Pre_SysTsk_Yes: {
+      ctx->config.attributes |= RTEMS_SYSTEM_TASK;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_SysTsk_No: {
+      /* Nothing to do */
+      break;
+    case RtemsTaskReqConstructErrors_Pre_SysTsk_NA:
+      break;
 static void RtemsTaskReqConstructErrors_Pre_Prio_Prepare(
   RtemsTaskReqConstructErrors_Pre_Prio state
@@ -459,29 +503,6 @@ static void RtemsTaskReqConstructErrors_Pre_Ext_Prepare(
-static void RtemsTaskReqConstructErrors_Pre_Preempt_Prepare(
-  RtemsTaskReqConstructErrors_Context    *ctx,
-  RtemsTaskReqConstructErrors_Pre_Preempt state
-  switch ( state ) {
-    case RtemsTaskReqConstructErrors_Pre_Preempt_Yes: {
-      ctx->config.initial_modes &= ~RTEMS_PREEMPT_MASK;
-      ctx->config.initial_modes |= RTEMS_PREEMPT;
-      break;
-    case RtemsTaskReqConstructErrors_Pre_Preempt_No: {
-      ctx->config.initial_modes |= RTEMS_NO_PREEMPT;
-      break;
-    case RtemsTaskReqConstructErrors_Pre_Preempt_NA:
-      break;
 static void RtemsTaskReqConstructErrors_Post_Status_Check(
   RtemsTaskReqConstructErrors_Post_Status state
@@ -578,6 +599,27 @@ static void RtemsTaskReqConstructErrors_Post_IdValue_Check(
+static void RtemsTaskReqConstructErrors_Post_CreateExt_Check(
+  RtemsTaskReqConstructErrors_Post_CreateExt state
+    case RtemsTaskReqConstructErrors_Post_CreateExt_Yes: {
+      T_eq_u32( ctx->create_extension_calls, 1 );
+      break;
+    case RtemsTaskReqConstructErrors_Post_CreateExt_No: {
+      T_eq_u32( ctx->create_extension_calls, 0 );
+      break;
+    case RtemsTaskReqConstructErrors_Post_CreateExt_NA:
+      break;
 static void RtemsTaskReqConstructErrors_Post_DelExt_Check(
   RtemsTaskReqConstructErrors_Post_DelExt state
@@ -599,6 +641,27 @@ static void RtemsTaskReqConstructErrors_Post_DelExt_Check(
+static void RtemsTaskReqConstructErrors_Post_StoFree_Check(
+  RtemsTaskReqConstructErrors_Post_StoFree state
+    case RtemsTaskReqConstructErrors_Post_StoFree_Yes: {
+      T_eq_u32( ctx->storage_free_calls, 1 );
+      break;
+    case RtemsTaskReqConstructErrors_Post_StoFree_No: {
+      T_eq_u32( ctx->storage_free_calls, 0 );
+      break;
+    case RtemsTaskReqConstructErrors_Post_StoFree_NA:
+      break;
 static void RtemsTaskReqConstructErrors_Setup(
@@ -611,7 +674,7 @@ static void RtemsTaskReqConstructErrors_Setup(
   tls_variable = var;
   sc = rtems_extension_create(
-    rtems_build_name( 'T', 'C', 'F', 'C' ),
+    rtems_build_name( 'T', 'E', 'X', 'T' ),
     &extensions,
     &ctx->extension_id
@@ -676,1934 +739,2695 @@ static T_fixture RtemsTaskReqConstructErrors_Fixture = {
   .initial_context = &RtemsTaskReqConstructErrors_Instance
-static const uint8_t RtemsTaskReqConstructErrors_TransitionMap[][ 4 ] = {
+static const uint8_t RtemsTaskReqConstructErrors_TransitionMap[][ 6 ] = {
     RtemsTaskReqConstructErrors_Post_Name_Valid,
     RtemsTaskReqConstructErrors_Post_IdValue_Assigned,
-    RtemsTaskReqConstructErrors_Post_DelExt_No
-#if defined(RTEMS_SMP)
-    RtemsTaskReqConstructErrors_Post_Status_Unsat,
-    RtemsTaskReqConstructErrors_Post_Name_Invalid,
-    RtemsTaskReqConstructErrors_Post_IdValue_Unchanged,
-    RtemsTaskReqConstructErrors_Post_DelExt_Yes
-#else
-    RtemsTaskReqConstructErrors_Post_Status_Ok,
-    RtemsTaskReqConstructErrors_Post_Name_Valid,
-    RtemsTaskReqConstructErrors_Post_IdValue_Assigned,
-#endif
+    RtemsTaskReqConstructErrors_Post_DelExt_No,
+    RtemsTaskReqConstructErrors_Post_DelExt_Yes,
     RtemsTaskReqConstructErrors_Post_Status_InvSize,
-    RtemsTaskReqConstructErrors_Post_Status_InvSize,
+    RtemsTaskReqConstructErrors_Post_Status_TooMany,
-    RtemsTaskReqConstructErrors_Post_Status_TooMany,
+    RtemsTaskReqConstructErrors_Post_Status_Ok,
+    RtemsTaskReqConstructErrors_Post_Name_Valid,
+    RtemsTaskReqConstructErrors_Post_IdValue_Assigned,
+    RtemsTaskReqConstructErrors_Post_Status_Unsat,
+    RtemsTaskReqConstructErrors_Post_Status_InvSize,
-    RtemsTaskReqConstructErrors_Post_Status_InvPrio,
     RtemsTaskReqConstructErrors_Post_Status_InvName,
@@ -2611,21 +3435,17 @@ static const struct {
   uint16_t Skip : 1;
   uint16_t Pre_Id_NA : 1;
   uint16_t Pre_Name_NA : 1;
+  uint16_t Pre_SysTsk_NA : 1;
   uint16_t Pre_Prio_NA : 1;
   uint16_t Pre_Free_NA : 1;
   uint16_t Pre_TLS_NA : 1;
   uint16_t Pre_Stack_NA : 1;
   uint16_t Pre_Ext_NA : 1;
-  uint16_t Pre_Preempt_NA : 1;
 } RtemsTaskReqConstructErrors_TransitionInfo[] = {
     0, 0, 0, 0, 0, 0, 0, 0, 0
-#else
-    0, 0, 0, 0, 0, 0, 0, 0, 0
-#endif
@@ -3403,13 +4223,17 @@ static void RtemsTaskReqConstructErrors_Prepare(
   ctx->id_value = INVALID_ID;
   memset( &ctx->config, 0, sizeof( ctx->config ) );
+  ctx->config.storage_area = task_storage,
+  ctx->config.storage_free = StorageFree;
 static void RtemsTaskReqConstructErrors_Action(
+  ctx->create_extension_calls = 0;
   ctx->delete_extension_calls = 0;
+  ctx->storage_free_calls = 0;
   ctx->config.storage_size = RTEMS_TASK_STORAGE_SIZE(
     ctx->config.maximum_thread_local_storage_size + ctx->stack_size,
@@ -3457,12 +4281,12 @@ T_TEST_CASE_FIXTURE(
       ctx->pcs[ 0 ] = RtemsTaskReqConstructErrors_Pre_Id_NA;
       index += ( RtemsTaskReqConstructErrors_Pre_Id_NA - 1 )
         * RtemsTaskReqConstructErrors_Pre_Name_NA
+        * RtemsTaskReqConstructErrors_Pre_SysTsk_NA
         * RtemsTaskReqConstructErrors_Pre_Prio_NA
         * RtemsTaskReqConstructErrors_Pre_Free_NA
         * RtemsTaskReqConstructErrors_Pre_TLS_NA
         * RtemsTaskReqConstructErrors_Pre_Stack_NA
-        * RtemsTaskReqConstructErrors_Pre_Ext_NA
-        * RtemsTaskReqConstructErrors_Pre_Preempt_NA;
+        * RtemsTaskReqConstructErrors_Pre_Ext_NA;
     for (
@@ -3473,87 +4297,87 @@ T_TEST_CASE_FIXTURE(
       if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Name_NA ) {
         ctx->pcs[ 1 ] = RtemsTaskReqConstructErrors_Pre_Name_NA;
         index += ( RtemsTaskReqConstructErrors_Pre_Name_NA - 1 )
       for (
-        ctx->pcs[ 2 ] = RtemsTaskReqConstructErrors_Pre_Prio_Valid;
-        ctx->pcs[ 2 ] < RtemsTaskReqConstructErrors_Pre_Prio_NA;
+        ctx->pcs[ 2 ] = RtemsTaskReqConstructErrors_Pre_SysTsk_Yes;
+        ctx->pcs[ 2 ] < RtemsTaskReqConstructErrors_Pre_SysTsk_NA;
         ++ctx->pcs[ 2 ]
-        if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Prio_NA ) {
-          ctx->pcs[ 2 ] = RtemsTaskReqConstructErrors_Pre_Prio_NA;
-          index += ( RtemsTaskReqConstructErrors_Pre_Prio_NA - 1 )
+        if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_SysTsk_NA ) {
+          ctx->pcs[ 2 ] = RtemsTaskReqConstructErrors_Pre_SysTsk_NA;
+          index += ( RtemsTaskReqConstructErrors_Pre_SysTsk_NA - 1 )
+            * RtemsTaskReqConstructErrors_Pre_Prio_NA
         for (
-          ctx->pcs[ 3 ] = RtemsTaskReqConstructErrors_Pre_Free_Yes;
-          ctx->pcs[ 3 ] < RtemsTaskReqConstructErrors_Pre_Free_NA;
+          ctx->pcs[ 3 ] = RtemsTaskReqConstructErrors_Pre_Prio_Valid;
+          ctx->pcs[ 3 ] < RtemsTaskReqConstructErrors_Pre_Prio_NA;
           ++ctx->pcs[ 3 ]
-          if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Free_NA ) {
-            ctx->pcs[ 3 ] = RtemsTaskReqConstructErrors_Pre_Free_NA;
-            index += ( RtemsTaskReqConstructErrors_Pre_Free_NA - 1 )
+          if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Prio_NA ) {
+            ctx->pcs[ 3 ] = RtemsTaskReqConstructErrors_Pre_Prio_NA;
+            index += ( RtemsTaskReqConstructErrors_Pre_Prio_NA - 1 )
+              * RtemsTaskReqConstructErrors_Pre_Free_NA
           for (
-            ctx->pcs[ 4 ] = RtemsTaskReqConstructErrors_Pre_TLS_Enough;
-            ctx->pcs[ 4 ] < RtemsTaskReqConstructErrors_Pre_TLS_NA;
+            ctx->pcs[ 4 ] = RtemsTaskReqConstructErrors_Pre_Free_Yes;
+            ctx->pcs[ 4 ] < RtemsTaskReqConstructErrors_Pre_Free_NA;
             ++ctx->pcs[ 4 ]
-            if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_TLS_NA ) {
-              ctx->pcs[ 4 ] = RtemsTaskReqConstructErrors_Pre_TLS_NA;
-              index += ( RtemsTaskReqConstructErrors_Pre_TLS_NA - 1 )
+            if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Free_NA ) {
+              ctx->pcs[ 4 ] = RtemsTaskReqConstructErrors_Pre_Free_NA;
+              index += ( RtemsTaskReqConstructErrors_Pre_Free_NA - 1 )
+                * RtemsTaskReqConstructErrors_Pre_TLS_NA
             for (
-              ctx->pcs[ 5 ] = RtemsTaskReqConstructErrors_Pre_Stack_Enough;
-              ctx->pcs[ 5 ] < RtemsTaskReqConstructErrors_Pre_Stack_NA;
+              ctx->pcs[ 5 ] = RtemsTaskReqConstructErrors_Pre_TLS_Enough;
+              ctx->pcs[ 5 ] < RtemsTaskReqConstructErrors_Pre_TLS_NA;
               ++ctx->pcs[ 5 ]
-              if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Stack_NA ) {
-                ctx->pcs[ 5 ] = RtemsTaskReqConstructErrors_Pre_Stack_NA;
-                index += ( RtemsTaskReqConstructErrors_Pre_Stack_NA - 1 )
+              if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_TLS_NA ) {
+                ctx->pcs[ 5 ] = RtemsTaskReqConstructErrors_Pre_TLS_NA;
+                index += ( RtemsTaskReqConstructErrors_Pre_TLS_NA - 1 )
+                  * RtemsTaskReqConstructErrors_Pre_Stack_NA
               for (
-                ctx->pcs[ 6 ] = RtemsTaskReqConstructErrors_Pre_Ext_Ok;
-                ctx->pcs[ 6 ] < RtemsTaskReqConstructErrors_Pre_Ext_NA;
+                ctx->pcs[ 6 ] = RtemsTaskReqConstructErrors_Pre_Stack_Enough;
+                ctx->pcs[ 6 ] < RtemsTaskReqConstructErrors_Pre_Stack_NA;
                 ++ctx->pcs[ 6 ]
-                if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Ext_NA ) {
-                  ctx->pcs[ 6 ] = RtemsTaskReqConstructErrors_Pre_Ext_NA;
-                  index += ( RtemsTaskReqConstructErrors_Pre_Ext_NA - 1 )
+                if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Stack_NA ) {
+                  ctx->pcs[ 6 ] = RtemsTaskReqConstructErrors_Pre_Stack_NA;
+                  index += ( RtemsTaskReqConstructErrors_Pre_Stack_NA - 1 )
                 for (
-                  ctx->pcs[ 7 ] = RtemsTaskReqConstructErrors_Pre_Preempt_Yes;
-                  ctx->pcs[ 7 ] < RtemsTaskReqConstructErrors_Pre_Preempt_NA;
+                  ctx->pcs[ 7 ] = RtemsTaskReqConstructErrors_Pre_Ext_Ok;
+                  ctx->pcs[ 7 ] < RtemsTaskReqConstructErrors_Pre_Ext_NA;
                   ++ctx->pcs[ 7 ]
-                  if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Preempt_NA ) {
-                    ctx->pcs[ 7 ] = RtemsTaskReqConstructErrors_Pre_Preempt_NA;
-                    index += ( RtemsTaskReqConstructErrors_Pre_Preempt_NA - 1 );
+                  if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Ext_NA ) {
+                    ctx->pcs[ 7 ] = RtemsTaskReqConstructErrors_Pre_Ext_NA;
+                    index += ( RtemsTaskReqConstructErrors_Pre_Ext_NA - 1 );
                   if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Skip ) {
@@ -3570,27 +4394,27 @@ T_TEST_CASE_FIXTURE(
                     ctx,
                     ctx->pcs[ 1 ]
-                  RtemsTaskReqConstructErrors_Pre_Prio_Prepare(
+                  RtemsTaskReqConstructErrors_Pre_SysTsk_Prepare(
                     ctx,
                     ctx->pcs[ 2 ]
-                  RtemsTaskReqConstructErrors_Pre_Free_Prepare(
+                  RtemsTaskReqConstructErrors_Pre_Prio_Prepare(
                     ctx,
                     ctx->pcs[ 3 ]
-                  RtemsTaskReqConstructErrors_Pre_TLS_Prepare(
+                  RtemsTaskReqConstructErrors_Pre_Free_Prepare(
                     ctx,
                     ctx->pcs[ 4 ]
-                  RtemsTaskReqConstructErrors_Pre_Stack_Prepare(
+                  RtemsTaskReqConstructErrors_Pre_TLS_Prepare(
                     ctx,
                     ctx->pcs[ 5 ]
-                  RtemsTaskReqConstructErrors_Pre_Ext_Prepare(
+                  RtemsTaskReqConstructErrors_Pre_Stack_Prepare(
                     ctx,
                     ctx->pcs[ 6 ]
-                  RtemsTaskReqConstructErrors_Pre_Preempt_Prepare(
+                  RtemsTaskReqConstructErrors_Pre_Ext_Prepare(
                     ctx,
                     ctx->pcs[ 7 ]
@@ -3607,10 +4431,18 @@ T_TEST_CASE_FIXTURE(
                     ctx,
                     RtemsTaskReqConstructErrors_TransitionMap[ index ][ 2 ]
-                  RtemsTaskReqConstructErrors_Post_DelExt_Check(
+                  RtemsTaskReqConstructErrors_Post_CreateExt_Check(
                     ctx,
                     RtemsTaskReqConstructErrors_TransitionMap[ index ][ 3 ]
+                  RtemsTaskReqConstructErrors_Post_DelExt_Check(
+                    ctx,
+                    RtemsTaskReqConstructErrors_TransitionMap[ index ][ 4 ]
+                  RtemsTaskReqConstructErrors_Post_StoFree_Check(
+                    ctx,
+                    RtemsTaskReqConstructErrors_TransitionMap[ index ][ 5 ]
                   RtemsTaskReqConstructErrors_Cleanup( ctx );
                   ++index;
2.26.2
