[PATCH 2/2] testsuites: Edited tests for sig2str/str2sig methods
Wed Jul 7 14:26:12 UTC 2021
Do not submit base patches and then edited patches. Merge these two
into a single patch which adds the test and resubmit
>From the world's perspective, this is all new so it should be a single patch.
I notice there is no newline at the end of the scn file. Watch the
style on spacing
and ){ based on the other code.
On Wed, Jul 7, 2021 at 5:56 AM Matt Joyce <mfjoyce2004 at gmail.com> wrote:
> Added additional tests to init.c and added psxsignal09.scn and
> psxsignal09.doc to conform to RTEMS standards.
>  testsuites/psxtests/Makefile.am               |   2 +
>  testsuites/psxtests/psxsignal09/init.c        | 207 +++++++++++++-----
>  .../psxtests/psxsignal09/psxsignal09.doc      |  34 +++
>  .../psxtests/psxsignal09/psxsignal09.scn      |  31 +++
>  4 files changed, 223 insertions(+), 51 deletions(-)
>  create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
>  create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index b50c9b97cb..b62d5cab59 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -927,6 +927,8 @@ endif
>  if HAS_POSIX
>  if TEST_psxsignal09
>  psx_tests += psxsignal09
> +psx_screens += psxsignal09/psxsignal09.scn
> +psx_docs += psxsignal09/psxsignal09.doc
>  psxsignal09_SOURCES = psxsignal09/init.c
>  psxsignal09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal09) \
>         $(support_includes) -I$(top_srcdir)/include
> diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
> index 02ad8a9e45..7025b471aa 100644
> --- a/testsuites/psxtests/psxsignal09/init.c
> +++ b/testsuites/psxtests/psxsignal09/init.c
> @@ -48,7 +48,7 @@
>  //#include <sys/signal.h>
> -const char rtems_test_name[] = "SIG2STR AND STR2SIG TEST";
> +const char rtems_test_name[] = "SIG2STR AND STR2SIG";
>  static rtems_task Init(
>    rtems_task_argument ignored
> @@ -56,72 +56,177 @@ static rtems_task Init(
>    rtems_print_printer_fprintf_putc(&rtems_test_printer);
>    TEST_BEGIN();
> -  printf( "SIG2STR AND STR2SIG TEST\n" );
>    char test1[SIG2STR_MAX];
>    char test2[SIG2STR_MAX];
>    char test3[SIG2STR_MAX];
>    char test4[SIG2STR_MAX];
> +  char test5[SIG2STR_MAX];
> +  char test6[SIG2STR_MAX];
> +  char test7[SIG2STR_MAX];
> +  char test8[SIG2STR_MAX];
> +  char test9[SIG2STR_MAX];
>    int res1;
>    int res2;
>    int res3;
>    int res4;
> +  int res5;
> +  int res6;
> +  int res7;
> +  int res8;
> +  int res9;
>    int retval1;
>    int retval2;
>    int retval3;
>    int retval4;
> +  int retval5;
> +  int retval6;
> +  int retval7;
> +  int retval8;
> +  int retval9;
>    int min = SIGRTMIN;
>    int max = SIGRTMAX;
> -  printf( "sigrtmin is %d and sigrtmax is %d\n", min, max );
> -  printf("Calling sig2str: \n");
> -  sig2str(31, test1);
> -  sig2str(9, test2);
> -  sig2str(29, test3);
> -  sig2str(2147483647, test4);
> -  printf("test1 is now: %s\n", test1);
> -  printf("test2 is now: %s\n", test2);
> -  printf("test3 is now: %s\n", test3);
> -  printf("test4 is now: %s\n", test4);
> -  printf("Calling str2sig: \n");
> -  retval1 = str2sig("19", &res1);
> -  retval2 = str2sig("TSTP", &res2);
> -  retval3 = str2sig("RTMIN+12", &res3);
> -  retval4 = str2sig("RTMAX-2", &res4);
> -  printf("The result of the first call is: %d\n", res1);
> -  printf("The second result of the second call is: %d\n", res2);
> -  printf("The second result of the third call is: %d\n", res3);
> -  printf("The second result of the fourth call is: %d\n", res4);
> -  // T_TEST_CASE(a_test_case)
> -  //   T_eq_int(res1, 19);
> -  printf("retval1 is %d\n", retval1);
> -  printf("retval2 is %d\n", retval2);
> -  printf("retval3 is %d\n", retval3);
> -  printf("retval4 is %d\n", retval4);
> -  /* Testing a call to str2sig using a previously successful call to sig2str.
> -  * value in pnum should equal signum*/
> -  printf("\n");
> -  str2sig(test1, &res1);
> -  str2sig(test2, &res2);
> -  str2sig(test3, &res3);
> -  rtems_test_assert(res1 == 31);
> -  printf("res1 should equal 31. It is: %d\n", res1);
> -  rtems_test_assert(res2 == 9);
> -  printf("res2 should equal 9. It is: %d\n", res2);
> -  rtems_test_assert(res3 == 29);
> -  printf("res3 should equal 29. It is: %d\n", res3);
> +  printf( "\n" );
> +  printf( "SIGRTMIN is %d and SIGRTMAX is %d\n", min, max );
> +  printf( "\n" );
> +  printf( "Calling sig2str: \n" );
> +  /* Expected pass */
> +  retval1 = sig2str( 1, test1 );
> +  rtems_test_assert( retval1 == 0 );
> +  rtems_test_assert( strcmp( test1, "HUP" )==0 );
> +  printf( "The string test1 is: %s\n", test1 );
> +  retval2 = sig2str( 3, test2 );
> +  rtems_test_assert( retval2 == 0 );
> +  rtems_test_assert( strcmp( test2, "QUIT" )==0);
> +  printf( "The string test2 is: %s\n", test2 );
> +  retval3 = sig2str( 27, test3 );
> +  rtems_test_assert( retval3 == 0 );
> +  rtems_test_assert( strcmp( test3, "RTMIN" )==0 );
> +  printf( "The string test3 is: %s\n", test3 );
> +  retval4 = sig2str( 29, test4 );
> +  rtems_test_assert( retval4 == 0 );
> +  rtems_test_assert( strcmp( test4, "RTMIN+2" )==0 );
> +  printf( "The string test4 is: %s\n", test4 );
> +  retval5 = sig2str( 31, test5 );
> +  rtems_test_assert( retval5 == 0 );
> +  rtems_test_assert( strcmp( test5, "RTMAX" )==0);
> +  printf( "The string test5 is: %s\n", test5 );
> +  retval6 = sig2str( 30, test6 );
> +  rtems_test_assert( retval6 == 0 );
> +  rtems_test_assert( strcmp( test6, "RTMAX-1" )==0);
> +  printf( "The string test6 is: %s\n", test6 );
> +  retval7 = sig2str( 9, test7 );
> +  rtems_test_assert( retval7 == 0 );
> +  rtems_test_assert(strcmp( test7, "KILL" )==0);
> +  printf( "The string test7 is: %s\n", test7 );
> +  /* Expected fail, invalid signal number */
> +  retval8 = sig2str( 200, test8 );
> +  rtems_test_assert( retval8 == -1);
> +  rtems_test_assert( strcmp( test8, "Unknown signal 200" )==0);
> +  printf( "The string test8 is: %s\n", test8 );
> +  /* Expected fail, if signum is 0 the output is unspecified */
> +  retval9 = sig2str( 0, test9 );
> +  rtems_test_assert( retval9 == -1 );
> +  printf( "The string test9 is: %s\n", test9 );
> +  printf( "\n" );
> +  printf( "Calling str2sig: \n" );
> +  retval1 = str2sig( "PIPE", &res1 );
> +  rtems_test_assert( retval1 == 0);
> +  rtems_test_assert( res1 == 13 );
> +  printf( "Result 1 is: %d\n", res1 );
> +  retval2 = str2sig( "TSTP", &res2 );
> +  rtems_test_assert( retval2 == 0);
> +  rtems_test_assert( res2 == 18 );
> +  printf( "Result 2 is: %d\n", res2 );
> +  retval3 = str2sig( "KILL", &res3 );
> +  rtems_test_assert( retval3 == 0);
> +  rtems_test_assert( res3 == 9 );
> +  printf( "Result 3 is: %d\n", res3 );
> +  /* Expected pass, String representation of integer */
> +  retval4 = str2sig( "10", &res4 );
> +  rtems_test_assert( retval4 == 0);
> +  rtems_test_assert( res4 == 10 );
> +  printf( "Result 4 is: %d\n", res4 );
> +  retval5 = str2sig( "RTMIN", &res5 );
> +  rtems_test_assert( retval5 == 0);
> +  rtems_test_assert( res5 == 27 );
> +  printf( "Result 5 is: %d\n", res5 );
> +  retval6 = str2sig( "RTMIN+1", &res6 );
> +  rtems_test_assert( retval6 == 0);
> +  rtems_test_assert( res6 == 28 );
> +  printf( "Result 6 is: %d\n", res6 );
> +  retval7 = str2sig( "RTMAX-2", &res7 );
> +  rtems_test_assert( retval7 == 0);
> +  rtems_test_assert( res7 == 29 );
> +  printf( "Result 7 is: %d\n", res7 );
> +  /* Expected fail, invalid signal name */
> +  retval8 = str2sig( "BOSS", &res8 );
> +  printf( "Result 8 is: %d\n", res8 );
> +  retval9 = str2sig( "RTMIN+1000", &res9 );
> +  rtems_test_assert( retval9 == -1);
> +  printf( "Result 9 is: %d\n", res9 );
> +  printf( "\n" );
> +  printf( "Calling str2sig using the result from previous call to sig2str\n" );
> +  retval1 = str2sig( test1, &res1 );
> +  rtems_test_assert( res1 == 1 );
> +  retval2 = str2sig( test2, &res2 );
> +  rtems_test_assert( res2 == 3 );
> +  retval3 = str2sig( test3, &res3 );
> +  rtems_test_assert( res3 == 27 );
> +  /* Expected fail, calling using string from invalid sig2str call */
> +  retval4 = str2sig( test8, &res4 );
> +  rtems_test_assert( retval4 == -1 );
>    TEST_END();
>    rtems_test_exit( 0 );
> diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
> new file mode 100644
> index 0000000000..0f11061c4d
> --- /dev/null
> +++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
> @@ -0,0 +1,34 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @brief Test of sig2str and str2sig methods
> + * This test file is used to verify that the methods sig2str and str2sig
> + * are functioning as expected
> + * Copyright (C) 2021 Matthew Joyce
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
> index 0000000000..632e152e9b
> --- /dev/null
> +++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
> @@ -0,0 +1,31 @@
> +*** BEGIN OF TEST SIG2STR AND STR2SIG ***
> +SIGRTMIN is 27 and SIGRTMAX is 31
> +Calling sig2str:
> +The string test1 is: HUP
> +The string test2 is: QUIT
> +The string test3 is: RTMIN
> +The string test4 is: RTMIN+2
> +The string test5 is: RTMAX
> +The string test6 is: RTMAX-1
> +The string test7 is: KILL
> +The string test8 is: Unknown signal 200
> +The string test9 is: Unknown signal 0
> +Calling str2sig:
> +Result 1 is: 13
> +Result 2 is: 18
> +Result 3 is: 9
> +Result 4 is: 10
> +Result 5 is: 27
> +Result 6 is: 28
> +Result 7 is: 29
> +Result 8 is: 0
> +Result 9 is: 0
> +Calling str2sig using the result from previous call to sig2str
> +Result 1 is: 1
> +Result 2 is: 3
> +Result 3 is: 27
> +*** END OF TEST SIG2STR AND STR2SIG ***
> 2.31.1
> devel mailing list
> devel at rtems.org
