[PATCH 09/41] rtems: Add rtems_interrupt_is_pending()
Wed Jul 21 18:02:47 UTC 2021
On Mon, Jul 12, 2021 at 6:51 AM Sebastian Huber
> Update #3269.
>  cpukit/include/rtems/irq-extension.h | 54 ++++++++++++++++++++++++++++
>  1 file changed, 54 insertions(+)
> diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
> index 4a8f0b7879..c96dfd7d5c 100644
> --- a/cpukit/include/rtems/irq-extension.h
> +++ b/cpukit/include/rtems/irq-extension.h
> @@ -453,6 +453,60 @@ rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector );
>  rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector );
> +/* Generated from spec:/rtems/intr/if/is-pending */
> + * @ingroup RTEMSAPIClassicIntr
> + * @brief Checks if the interrupt is pending.
> + * @param vector is the interrupt vector number.
> + * @param[out] pending is the pointer to a ``bool`` object.  When the directive
> + *   call is successful, the pending status of the interrupt associated with
> + *   the interrupt vector specified by ``vector`` will be stored in this
> + *   object.  When the interrupt was pending for the processor executing the
> + *   directive call at some time point during the call, the object value will
> + *   be set to true, otherwise to false.
> + * The directive checks if the interrupt associated with the interrupt vector
> + * specified by ``vector`` was pending for the processor executing the
> + * directive call at some time point during the call.
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``pending`` parameter was NULL.
> + * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
> + *   number specified by ``vector``.
> + * @retval ::RTEMS_UNSATISFIED The request to get the pending status has not
> + *   been satisfied.
> + * @par Notes
> + * Interrupts may be made pending by calling the rtems_interrupt_cause() or
> + * rtems_interrupt_cause_on() directives or due to exernal signals or messages.
external
> + * The pending state may be cleared by rtems_interrupt_clear().
> + * @par Constraints
> + * @parblock
> + * The following constraints apply to this directive:
> + * * The directive may be called from within interrupt context.
> + * * The directive may be called from within device driver initialization
> + *   context.
> + * * The directive may be called from within task context.
> + * * The directive will not cause the calling task to be preempted.
> + * @endparblock
> +rtems_status_code rtems_interrupt_is_pending(
> +  rtems_vector_number vector,
> +  bool               *pending
>  /* Generated from spec:/rtems/intr/if/get-affinity */
> 2.26.2
> devel mailing list
> devel at rtems.org
