[PATCH] covoar: Fix single-byte uncovered ranges
Wed Jun 2 15:20:28 UTC 2021
ok
On Wed, Jun 2, 2021 at 8:29 AM Alex White <alex.white at oarcorp.com> wrote:
> This fixes a bug where covoar reports uncovered ranges of size 1. When a
> NOP instruction is encountered at the end of a function, the remaining
> non-instruction bytes are marked as executed. The loop that marks the
> remaining bytes as executed was not considering the last address of the
> function.
> Closes #4448
>  tester/covoar/DesiredSymbols.cc | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
> index 2866dbe..75ec76f 100644
> --- a/tester/covoar/DesiredSymbols.cc
> +++ b/tester/covoar/DesiredSymbols.cc
> @@ -252,7 +252,7 @@ namespace Coverage {
>                do {
>                  theCoverageMap->setWasExecuted( ha );
>                  ha++;
> -                if ( ha >= endAddress )
> +                if ( ha > endAddress )
>                    break;
>                } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
>                          theCoverageMap->isNop( ha ) );
> 2.27.0
> devel mailing list
> devel at rtems.org
