[PATCH rtems-libbsd v3 1/4] rtemsbsd: Added original TTCP code
Stephen Clark stephen.clark at oarcorp.com
Wed Jun 16 17:46:11 UTC 2021
Added the original Test TCP (TTCP) program in unmodified form.
Also added the original README for TTCP. Both the README and the
TTCP program were sourced from the first commit in the RTEMS
network demos repository.
 rtemsbsd/ttcp/README |  27 ++
 rtemsbsd/ttcp/ttcp.c | 841 +++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 868 insertions(+)
 create mode 100644 rtemsbsd/ttcp/README
 create mode 100644 rtemsbsd/ttcp/ttcp.c
diff --git a/rtemsbsd/ttcp/README b/rtemsbsd/ttcp/README
new file mode 100644
index 00000000..215ddacc
--- /dev/null
+++ b/rtemsbsd/ttcp/README
@@ -0,0 +1,27 @@
+TTCP is a benchmarking tool for determining TCP and UDP performance
+between 2 systems.
+The program was created at the US Army Ballistics Research Lab (BRL)
+and is in the public domain. Feel free to distribute this program
+but please do leave the credit notices in the source and man page intact.
+Contents of this directory:
+ttcp.c          Source that runs on IRIX 3.3.x and 4.0.x systems
+                and BSD-based systems.  This version also uses getopt(3)
+                and has 2 new options: -f and -T.
+ttcp.c-brl      Original source from BRL.
+ttcp.1          Manual page (describes ttcp.c options, which are a
+                superset of the other version).
+How to get TCP performance numbers:
+        receiver                                sender
+host1%  ttcp -r -s                      host2% ttcp -t -s host1
+-n and -l options change the number and size of the buffers.
diff --git a/rtemsbsd/ttcp/ttcp.c b/rtemsbsd/ttcp/ttcp.c
index 00000000..305a7c7d
--- /dev/null
+++ b/rtemsbsd/ttcp/ttcp.c
@@ -0,0 +1,841 @@
+ *	T T C P . C
+ * Test TCP connection.  Makes a connection on port 5001
+ * and transfers fabricated buffers or data copied from stdin.
+ * Usable on 4.2, 4.3, and 4.1a systems by defining one of
+ * BSD42 BSD43 (BSD41a)
+ * Machines using System V with BSD sockets should define SYSV.
+ * Modified for operation under 4.2BSD, 18 Dec 84
+ *      T.C. Slattery, USNA
+ * Minor improvements, Mike Muuss and Terry Slattery, 16-Oct-85.
+ * Modified in 1989 at Silicon Graphics, Inc.
+ *	catch SIGPIPE to be able to print stats when receiver has died
+ *	for tcp, don't look for sentinel during reads to allow small transfers
+ *	increased default buffer size to 8K, nbuf to 2K to transfer 16MB
+ *	moved default port to 5001, beyond IPPORT_USERRESERVED
+ *	make sinkmode default because it is more popular,
+ *		-s now means don't sink/source
+ *	count number of read/write system calls to see effects of
+ *		blocking from full socket buffers
+ *	for tcp, -D option turns off buffered writes (sets TCP_NODELAY sockopt)
+ *	buffer alignment options, -A and -O
+ *	print stats in a format that's a bit easier to use with grep & awk
+ *	for SYSV, mimic BSD routines to use most of the existing timing code
+ * Modified by Steve Miller of the University of Maryland, College Park
+ *	-b sets the socket buffer size (SO_SNDBUF/SO_RCVBUF)
+ * Modified Sept. 1989 at Silicon Graphics, Inc.
+ *	restored -s sense at request of tcs at brl
+ * Modified Oct. 1991 at Silicon Graphics, Inc.
+ *	use getopt(3) for option processing, add -f and -T options.
+ *	SGI IRIX 3.3 and 4.0 releases don't need #define SYSV.
+ * Distribution Status -
+ *      Public Domain.  Distribution Unlimited.
+#ifndef lint
+static char RCSid[] = "ttcp.c $Revision$";
+#endif
+#define BSD43
+/* #define BSD42 */
+/* #define BSD41a */
+/* #define SYSV */	/* required on SGI IRIX releases before 3.3 */
+#include <stdio.h>
+#include <signal.h>
+#include <ctype.h>
+#include <errno.h>
+#include <sys/types.h>
+#include <sys/socket.h>
+#include <netinet/in.h>
+#include <netinet/tcp.h>
+#include <arpa/inet.h>
+#include <netdb.h>
+#include <sys/time.h>		/* struct timeval */
+#if defined(SYSV)
+#include <sys/times.h>
+#include <sys/param.h>
+struct rusage {
+    struct timeval ru_utime, ru_stime;
+#define RUSAGE_SELF 0
+#else
+#include <sys/resource.h>
+#endif
+struct sockaddr_in sinme;
+struct sockaddr_in sinhim;
+struct sockaddr_in frominet;
+int domain, fromlen;
+int fd;				/* fd of network socket */
+int buflen = 8 * 1024;		/* length of buffer */
+char *buf;			/* ptr to dynamic buffer */
+int nbuf = 2 * 1024;		/* number of buffers to send in sinkmode */
+int bufoffset = 0;		/* align buffer to this */
+int bufalign = 16*1024;		/* modulo this */
+int udp = 0;			/* 0 = tcp, !0 = udp */
+int options = 0;		/* socket options */
+int one = 1;                    /* for 4.3 BSD style setsockopt() */
+short port = 5001;		/* TCP port number */
+char *host;			/* ptr to name of host */
+int trans;			/* 0=receive, !0=transmit mode */
+int sinkmode = 0;		/* 0=normal I/O, !0=sink/source mode */
+int verbose = 0;		/* 0=print basic info, 1=print cpu rate, proc
+				 * resource usage. */
+int nodelay = 0;		/* set TCP_NODELAY socket option */
+int b_flag = 0;			/* use mread() */
+int sockbufsize = 0;		/* socket buffer size to use */
+char fmt = 'K';			/* output format: k = kilobits, K = kilobytes,
+				 *  m = megabits, M = megabytes,
+				 *  g = gigabits, G = gigabytes */
+int touchdata = 0;		/* access data after reading */
+struct hostent *addr;
+extern int errno;
+extern int optind;
+extern char *optarg;
+char Usage[] = "\
+Usage: ttcp -t [-options] host [ < in ]\n\
+       ttcp -r [-options > out]\n\
+Common options:\n\
+	-l ##	length of bufs read from or written to network (default 8192)\n\
+	-u	use UDP instead of TCP\n\
+	-p ##	port number to send to or listen at (default 5001)\n\
+	-s	-t: source a pattern to network\n\
+		-r: sink (discard) all data from network\n\
+	-A	align the start of buffers to this modulus (default 16384)\n\
+	-O	start buffers at this offset from the modulus (default 0)\n\
+	-v	verbose: print more statistics\n\
+	-d	set SO_DEBUG socket option\n\
+	-b ##	set socket buffer size (if supported)\n\
+	-f X	format for rate: k,K = kilo{bit,byte}; m,M = mega; g,G = giga\n\
+Options specific to -t:\n\
+	-n##	number of source bufs written to network (default 2048)\n\
+	-D	don't buffer TCP writes (sets TCP_NODELAY socket option)\n\
+Options specific to -r:\n\
+	-B	for -s, only output full blocks as specified by -l (for TAR)\n\
+	-T	\"touch\": access each byte as it's read\n\
+char stats[128];
+double nbytes;			/* bytes on net */
+unsigned long numCalls;		/* # of I/O system calls */
+double cput, realt;		/* user, real time (seconds) */
+void err();
+void mes();
+int pattern();
+void prep_timer();
+double read_timer();
+int Nread();
+int Nwrite();
+void delay();
+int mread();
+char *outfmt();
+void
+sigpipe()
+main(argc,argv)
+int argc;
+char **argv;
+	unsigned long addr_tmp;
+	int c;
+	if (argc < 2) goto usage;
+	while ((c = getopt(argc, argv, "drstuvBDTb:f:l:n:p:A:O:")) != -1) {
+		switch (c) {
+		case 'B':
+			b_flag = 1;
+			break;
+		case 't':
+			trans = 1;
+			break;
+		case 'r':
+			trans = 0;
+			break;
+		case 'd':
+			options |= SO_DEBUG;
+			break;
+		case 'D':
+#ifdef TCP_NODELAY
+			nodelay = 1;
+#else
+			fprintf(stderr,
+	"ttcp: -D option ignored: TCP_NODELAY socket option not supported\n");
+#endif
+			break;
+		case 'n':
+			nbuf = atoi(optarg);
+			break;
+		case 'l':
+			buflen = atoi(optarg);
+			break;
+		case 's':
+			sinkmode = !sinkmode;
+			break;
+		case 'p':
+			port = atoi(optarg);
+			break;
+		case 'u':
+			udp = 1;
+			break;
+		case 'v':
+			verbose = 1;
+			break;
+		case 'A':
+			bufalign = atoi(optarg);
+			break;
+		case 'O':
+			bufoffset = atoi(optarg);
+			break;
+		case 'b':
+#if defined(SO_SNDBUF) || defined(SO_RCVBUF)
+			sockbufsize = atoi(optarg);
+#else
+			fprintf(stderr,
+"ttcp: -b option ignored: SO_SNDBUF/SO_RCVBUF socket options not supported\n");
+#endif
+			break;
+		case 'f':
+			fmt = *optarg;
+			break;
+		case 'T':
+			touchdata = 1;
+			break;
+		default:
+			goto usage;
+	if(trans)  {
+		/* xmitr */
+		if (optind == argc)
+			goto usage;
+		bzero((char *)&sinhim, sizeof(sinhim));
+		host = argv[optind];
+		if (atoi(host) > 0 )  {
+			/* Numeric */
+			sinhim.sin_family = AF_INET;
+#if defined(cray)
+			addr_tmp = inet_addr(host);
+			sinhim.sin_addr = addr_tmp;
+#else
+			sinhim.sin_addr.s_addr = inet_addr(host);
+#endif
+		} else {
+			if ((addr=gethostbyname(host)) == NULL)
+				err("bad hostname");
+			sinhim.sin_family = addr->h_addrtype;
+			bcopy(addr->h_addr,(char*)&addr_tmp, addr->h_length);
+#if defined(cray)
+#else
+			sinhim.sin_addr.s_addr = addr_tmp;
+#endif /* cray */
+		sinhim.sin_port = htons(port);
+		sinme.sin_port = 0;		/* free choice */
+	} else {
+		/* rcvr */
+		sinme.sin_port =  htons(port);
+	if (udp && buflen < 5) {
+	    buflen = 5;		/* send more than the sentinel size */
+	if ( (buf = (char *)malloc(buflen+bufalign)) == (char *)NULL)
+		err("malloc");
+	if (bufalign != 0)
+		buf +=(bufalign - ((int)buf % bufalign) + bufoffset) % bufalign;
+	if (trans) {
+	    fprintf(stdout,
+	    "ttcp-t: buflen=%d, nbuf=%d, align=%d/%d, port=%d",
+		buflen, nbuf, bufalign, bufoffset, port);
+ 	    if (sockbufsize)
+ 		fprintf(stdout, ", sockbufsize=%d", sockbufsize);
+ 	    fprintf(stdout, "  %s  -> %s\n", udp?"udp":"tcp", host);
+	} else {
+	    fprintf(stdout,
+ 	    "ttcp-r: buflen=%d, nbuf=%d, align=%d/%d, port=%d",
+ 	    if (sockbufsize)
+ 	    fprintf(stdout, "  %s\n", udp?"udp":"tcp");
+	if ((fd = socket(AF_INET, udp?SOCK_DGRAM:SOCK_STREAM, 0)) < 0)
+		err("socket");
+	mes("socket");
+	if (bind(fd, &sinme, sizeof(sinme)) < 0)
+		err("bind");
+	if (sockbufsize) {
+	    if (trans) {
+		if (setsockopt(fd, SOL_SOCKET, SO_SNDBUF, &sockbufsize,
+		    sizeof sockbufsize) < 0)
+			err("setsockopt: sndbuf");
+		mes("sndbuf");
+	    } else {
+		if (setsockopt(fd, SOL_SOCKET, SO_RCVBUF, &sockbufsize,
+			err("setsockopt: rcvbuf");
+		mes("rcvbuf");
+#endif
+	if (!udp)  {
+	    signal(SIGPIPE, sigpipe);
+	    if (trans) {
+		/* We are the client if transmitting */
+		if (options)  {
+#if defined(BSD42)
+			if( setsockopt(fd, SOL_SOCKET, options, 0, 0) < 0)
+#else /* BSD43 */
+			if( setsockopt(fd, SOL_SOCKET, options, &one, sizeof(one)) < 0)
+#endif
+				err("setsockopt");
+#ifdef TCP_NODELAY
+		if (nodelay) {
+			struct protoent *p;
+			p = getprotobyname("tcp");
+			if( p && setsockopt(fd, p->p_proto, TCP_NODELAY,
+			    &one, sizeof(one)) < 0)
+				err("setsockopt: nodelay");
+			mes("nodelay");
+#endif
+		if(connect(fd, &sinhim, sizeof(sinhim) ) < 0)
+			err("connect");
+		mes("connect");
+	    } else {
+		/* otherwise, we are the server and
+	         * should listen for the connections
+#if defined(ultrix) || defined(sgi)
+		listen(fd,1);   /* workaround for alleged u4.2 bug */
+#else
+		listen(fd,0);   /* allow a queue of 0 */
+#endif
+		if(options)  {
+#if defined(BSD42)
+#else /* BSD43 */
+#endif
+		fromlen = sizeof(frominet);
+		domain = AF_INET;
+		if((fd=accept(fd, &frominet, &fromlen) ) < 0)
+			err("accept");
+		{ struct sockaddr_in peer;
+		  int peerlen = sizeof(peer);
+		  if (getpeername(fd, (struct sockaddr_in *) &peer,
+				&peerlen) < 0) {
+			err("getpeername");
+		  fprintf(stderr,"ttcp-r: accept from %s\n",
+			inet_ntoa(peer.sin_addr));
+	prep_timer();
+	errno = 0;
+	if (sinkmode) {
+		register int cnt;
+		if (trans)  {
+			pattern( buf, buflen );
+			if(udp)  (void)Nwrite( fd, buf, 4 ); /* rcvr start */
+			while (nbuf-- && Nwrite(fd,buf,buflen) == buflen)
+				nbytes += buflen;
+			if(udp)  (void)Nwrite( fd, buf, 4 ); /* rcvr end */
+		} else {
+			if (udp) {
+			    while ((cnt=Nread(fd,buf,buflen)) > 0)  {
+				    static int going = 0;
+				    if( cnt <= 4 )  {
+					    if( going )
+						    break;	/* "EOF" */
+					    going = 1;
+					    prep_timer();
+				    } else {
+					    nbytes += cnt;
+			} else {
+				    nbytes += cnt;
+	} else {
+		register int cnt;
+		if (trans)  {
+			while((cnt=read(0,buf,buflen)) > 0 &&
+			    Nwrite(fd,buf,cnt) == cnt)
+				nbytes += cnt;
+		}  else  {
+			while((cnt=Nread(fd,buf,buflen)) > 0 &&
+			    write(1,buf,cnt) == cnt)
+				nbytes += cnt;
+	if(errno) err("IO");
+	(void)read_timer(stats,sizeof(stats));
+	if(udp&&trans)  {
+		(void)Nwrite( fd, buf, 4 ); /* rcvr end */
+	if( cput <= 0.0 )  cput = 0.001;
+	if( realt <= 0.0 )  realt = 0.001;
+	fprintf(stdout,
+		"ttcp%s: %.0f bytes in %.2f real seconds = %s/sec +++\n",
+		trans?"-t":"-r",
+		nbytes, realt, outfmt(nbytes/realt));
+	if (verbose) {
+	    fprintf(stdout,
+		"ttcp%s: %.0f bytes in %.2f CPU seconds = %s/cpu sec\n",
+		trans?"-t":"-r",
+		nbytes, cput, outfmt(nbytes/cput));
+	fprintf(stdout,
+		"ttcp%s: %d I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
+		trans?"-t":"-r",
+		numCalls,
+		1024.0 * realt/((double)numCalls),
+		((double)numCalls)/realt);
+	fprintf(stdout,"ttcp%s: %s\n", trans?"-t":"-r", stats);
+	if (verbose) {
+	    fprintf(stdout,
+		"ttcp%s: buffer address %#x\n",
+		trans?"-t":"-r",
+		buf);
+	exit(0);
+usage:
+	fprintf(stderr,Usage);
+	exit(1);
+void
+err(s)
+char *s;
+	fprintf(stderr,"ttcp%s: ", trans?"-t":"-r");
+	perror(s);
+	fprintf(stderr,"errno=%d\n",errno);
+	exit(1);
+void
+mes(s)
+char *s;
+	fprintf(stderr,"ttcp%s: %s\n", trans?"-t":"-r", s);
+pattern( cp, cnt )
+register char *cp;
+register int cnt;
+	register char c;
+	c = 0;
+	while( cnt-- > 0 )  {
+		while( !isprint((c&0x7F)) )  c++;
+		*cp++ = (c++&0x7F);
+char *
+outfmt(b)
+double b;
+    static char obuf[50];
+    switch (fmt) {
+	case 'G':
+	    sprintf(obuf, "%.2f GB", b / 1024.0 / 1024.0 / 1024.0);
+	    break;
+	default:
+	case 'K':
+	    sprintf(obuf, "%.2f KB", b / 1024.0);
+	    break;
+	case 'M':
+	    sprintf(obuf, "%.2f MB", b / 1024.0 / 1024.0);
+	    break;
+	case 'g':
+	    sprintf(obuf, "%.2f Gbit", b * 8.0 / 1024.0 / 1024.0 / 1024.0);
+	    break;
+	case 'k':
+	    sprintf(obuf, "%.2f Kbit", b * 8.0 / 1024.0);
+	    break;
+	case 'm':
+	    sprintf(obuf, "%.2f Mbit", b * 8.0 / 1024.0 / 1024.0);
+	    break;
+    return obuf;
+static struct	timeval time0;	/* Time at which timing started */
+static struct	rusage ru0;	/* Resource utilization at the start */
+static void prusage();
+static void tvadd();
+static void tvsub();
+static void psecs();
+#if defined(SYSV)
+/*ARGSUSED*/
+static
+getrusage(ignored, ru)
+    int ignored;
+    register struct rusage *ru;
+    struct tms buf;
+    times(&buf);
+    /* Assumption: HZ <= 2147 (LONG_MAX/1000000) */
+    ru->ru_stime.tv_sec  = buf.tms_stime / HZ;
+    ru->ru_stime.tv_usec = ((buf.tms_stime % HZ) * 1000000) / HZ;
+    ru->ru_utime.tv_sec  = buf.tms_utime / HZ;
+    ru->ru_utime.tv_usec = ((buf.tms_utime % HZ) * 1000000) / HZ;
+/*ARGSUSED*/
+static
+gettimeofday(tp, zp)
+    struct timeval *tp;
+    struct timezone *zp;
+    tp->tv_sec = time(0);
+    tp->tv_usec = 0;
+#endif /* SYSV */
+ *			P R E P _ T I M E R
+void
+prep_timer()
+	gettimeofday(&time0, (struct timezone *)0);
+	getrusage(RUSAGE_SELF, &ru0);
+ *			R E A D _ T I M E R
+double
+read_timer(str,len)
+char *str;
+	struct timeval timedol;
+	struct rusage ru1;
+	struct timeval td;
+	struct timeval tend, tstart;
+	char line[132];
+	getrusage(RUSAGE_SELF, &ru1);
+	gettimeofday(&timedol, (struct timezone *)0);
+	prusage(&ru0, &ru1, &timedol, &time0, line);
+	(void)strncpy( str, line, len );
+	/* Get real time */
+	tvsub( &td, &timedol, &time0 );
+	realt = td.tv_sec + ((double)td.tv_usec) / 1000000;
+	/* Get CPU time (user+sys) */
+	tvadd( &tend, &ru1.ru_utime, &ru1.ru_stime );
+	tvadd( &tstart, &ru0.ru_utime, &ru0.ru_stime );
+	tvsub( &td, &tend, &tstart );
+	cput = td.tv_sec + ((double)td.tv_usec) / 1000000;
+	if( cput < 0.00001 )  cput = 0.00001;
+	return( cput );
+static void
+prusage(r0, r1, e, b, outp)
+	register struct rusage *r0, *r1;
+	struct timeval *e, *b;
+	char *outp;
+	struct timeval tdiff;
+	register time_t t;
+	register char *cp;
+	register int i;
+	int ms;
+	t = (r1->ru_utime.tv_sec-r0->ru_utime.tv_sec)*100+
+	    (r1->ru_utime.tv_usec-r0->ru_utime.tv_usec)/10000+
+	    (r1->ru_stime.tv_sec-r0->ru_stime.tv_sec)*100+
+	    (r1->ru_stime.tv_usec-r0->ru_stime.tv_usec)/10000;
+	ms =  (e->tv_sec-b->tv_sec)*100 + (e->tv_usec-b->tv_usec)/10000;
+#define END(x)	{while(*x) x++;}
+#if defined(SYSV)
+	cp = "%Uuser %Ssys %Ereal %P";
+#else
+#if defined(sgi)		/* IRIX 3.3 will show 0 for %M,%F,%R,%C */
+	cp = "%Uuser %Ssys %Ereal %P %Mmaxrss %F+%Rpf %Ccsw";
+#else
+	cp = "%Uuser %Ssys %Ereal %P %Xi+%Dd %Mmaxrss %F+%Rpf %Ccsw";
+#endif
+#endif
+	for (; *cp; cp++)  {
+		if (*cp != '%')
+			*outp++ = *cp;
+		else if (cp[1]) switch(*++cp) {
+		case 'U':
+			tvsub(&tdiff, &r1->ru_utime, &r0->ru_utime);
+			sprintf(outp,"%d.%01d", tdiff.tv_sec, tdiff.tv_usec/100000);
+			END(outp);
+			break;
+		case 'S':
+			tvsub(&tdiff, &r1->ru_stime, &r0->ru_stime);
+			END(outp);
+			break;
+		case 'E':
+			psecs(ms / 100, outp);
+			END(outp);
+			break;
+		case 'P':
+			sprintf(outp,"%d%%", (int) (t*100 / ((ms ? ms : 1))));
+			END(outp);
+			break;
+#if !defined(SYSV)
+		case 'W':
+			i = r1->ru_nswap - r0->ru_nswap;
+			sprintf(outp,"%d", i);
+			END(outp);
+			break;
+		case 'X':
+			sprintf(outp,"%d", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
+			END(outp);
+			break;
+		case 'D':
+			    (r1->ru_idrss+r1->ru_isrss-(r0->ru_idrss+r0->ru_isrss))/t);
+			END(outp);
+			break;
+		case 'K':
+			    ((r1->ru_ixrss+r1->ru_isrss+r1->ru_idrss) -
+			    (r0->ru_ixrss+r0->ru_idrss+r0->ru_isrss))/t);
+			END(outp);
+			break;
+		case 'M':
+			sprintf(outp,"%d", r1->ru_maxrss/2);
+			END(outp);
+			break;
+		case 'F':
+			sprintf(outp,"%d", r1->ru_majflt-r0->ru_majflt);
+			END(outp);
+			break;
+		case 'R':
+			sprintf(outp,"%d", r1->ru_minflt-r0->ru_minflt);
+			END(outp);
+			break;
+		case 'I':
+			sprintf(outp,"%d", r1->ru_inblock-r0->ru_inblock);
+			END(outp);
+			break;
+		case 'O':
+			sprintf(outp,"%d", r1->ru_oublock-r0->ru_oublock);
+			END(outp);
+			break;
+		case 'C':
+			sprintf(outp,"%d+%d", r1->ru_nvcsw-r0->ru_nvcsw,
+				r1->ru_nivcsw-r0->ru_nivcsw );
+			END(outp);
+			break;
+#endif /* !SYSV */
+	*outp = '\0';
+static void
+tvadd(tsum, t0, t1)
+	struct timeval *tsum, *t0, *t1;
+	tsum->tv_sec = t0->tv_sec + t1->tv_sec;
+	tsum->tv_usec = t0->tv_usec + t1->tv_usec;
+	if (tsum->tv_usec > 1000000)
+		tsum->tv_sec++, tsum->tv_usec -= 1000000;
+static void
+tvsub(tdiff, t1, t0)
+	struct timeval *tdiff, *t1, *t0;
+	tdiff->tv_sec = t1->tv_sec - t0->tv_sec;
+	tdiff->tv_usec = t1->tv_usec - t0->tv_usec;
+	if (tdiff->tv_usec < 0)
+		tdiff->tv_sec--, tdiff->tv_usec += 1000000;
+static void
+psecs(l,cp)
+long l;
+register char *cp;
+	register int i;
+	i = l / 3600;
+	if (i) {
+		sprintf(cp,"%d:", i);
+		END(cp);
+		i = l % 3600;
+		sprintf(cp,"%d%d", (i/60) / 10, (i/60) % 10);
+		END(cp);
+	} else {
+		i = l;
+		sprintf(cp,"%d", i / 60);
+		END(cp);
+	i %= 60;
+	*cp++ = ':';
+	sprintf(cp,"%d%d", i / 10, i % 10);
+ *			N R E A D
+Nread( fd, buf, count )
+int fd;
+void *buf;
+int count;
+	struct sockaddr_in from;
+	int len = sizeof(from);
+	register int cnt;
+	if( udp )  {
+		cnt = recvfrom( fd, buf, count, 0, &from, &len );
+		numCalls++;
+	} else {
+		if( b_flag )
+			cnt = mread( fd, buf, count );	/* fill buf */
+		else {
+			cnt = read( fd, buf, count );
+			numCalls++;
+		if (touchdata && cnt > 0) {
+			register int c = cnt, sum;
+			register char *b = buf;
+			while (c--)
+				sum += *b++;
+	return(cnt);
+ *			N W R I T E
+Nwrite( fd, buf, count )
+int fd;
+void *buf;
+int count;
+	register int cnt;
+	if( udp )  {
+again:
+		cnt = sendto( fd, buf, count, 0, &sinhim, sizeof(sinhim) );
+		numCalls++;
+		if( cnt<0 && errno == ENOBUFS )  {
+			delay(18000);
+			errno = 0;
+			goto again;
+	} else {
+		cnt = write( fd, buf, count );
+		numCalls++;
+	return(cnt);
+void
+delay(us)
+	struct timeval tv;
+	tv.tv_sec = 0;
+	tv.tv_usec = us;
+	(void)select( 1, (char *)0, (char *)0, (char *)0, &tv );
+ *			M R E A D
+ * This function performs the function of a read(II) but will
+ * call read(II) multiple times in order to get the requested
+ * number of characters.  This can be necessary because
+ * network connections don't deliver data with the same
+ * grouping as it is written with.  Written by Robert S. Miles, BRL.
+int
+mread(fd, bufp, n)
+int fd;
+register char	*bufp;
+unsigned	n;
+	register unsigned	count = 0;
+	register int		nread;
+	do {
+		nread = read(fd, bufp, n-count);
+		numCalls++;
+		if(nread < 0)  {
+			perror("ttcp_mread");
+			return(-1);
+		if(nread == 0)
+			return((int)count);
+		count += (unsigned)nread;
+		bufp += nread;
+	 } while(count < n);
2.27.0
