BBB hello does not run...
Wed Jun 23 04:52:20 UTC 2021
Hi,
hello.exe is not running. Any hints?
master at ...
https://git.rtems.org/rtems/commit/?id=b47dbbc5f7c8518634c7c5fccd57d78c65444f2d
config.ini:
[DEFAULT]
BUILD_TESTS = False
RTEMS_DEBUG = True
RTEMS_POSIX_API = True
[arm/beagleboneblack]
BUILD_TESTS = True
output:
RTEMS Beagleboard: am335x-based
        ARM Debug: 0x4b141000
*** FATAL ***
fatal source: 1 (INTERNAL_ERROR_RTEMS_API)
fatal code: 22 (0x00000016)
RTEMS version: 6.0.0.4977dc74c60e75b90fe8dd72e4dedafd55d70c73
RTEMS tools: 10.3.1 20210409 (RTEMS 6, RSB
4e6dc6431435821a534da6307e72ecbd7e42b82a, Newlib 0c0f3df)
executing thread ID: 0x089010001
executing thread name: IDLE
