[PATCH rtems-net-legacy] bsps: Add remaining networking header files from RTEMS repository
Vijay Kumar Banerjee vijay at rtems.org
Wed Jun 23 19:22:14 UTC 2021
 bsp_drivers.py                                |   1 +
 bsps/include/grlib/greth.h                    | 165 +++++++
 bsps/include/grlib/network_interface_add.h    |  47 ++
 bsps/powerpc/beatnik/include/bsp/if_em_pub.h  |  22 +
 bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h |  30 ++
 bsps/powerpc/beatnik/include/bsp/if_mve_pub.h | 426 ++++++++++++++++++
 6 files changed, 691 insertions(+)
 create mode 100644 bsps/include/grlib/greth.h
 create mode 100644 bsps/include/grlib/network_interface_add.h
 create mode 100644 bsps/powerpc/beatnik/include/bsp/if_em_pub.h
 create mode 100644 bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
 create mode 100644 bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
diff --git a/bsp_drivers.py b/bsp_drivers.py
index bb31789..7d07d3d 100644
--- a/bsp_drivers.py
+++ b/bsp_drivers.py
@@ -72,4 +72,5 @@ def bsp_files(bld):
             if bsp in special_case_sources:
                 source_files[bsp].extend(special_case_sources[bsp])
         include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
+        include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'include'))
     return (include_dirs, source_files)
diff --git a/bsps/include/grlib/greth.h b/bsps/include/grlib/greth.h
new file mode 100644
index 0000000..e7970a7
--- /dev/null
+++ b/bsps/include/grlib/greth.h
@@ -0,0 +1,165 @@
+ * Cobham Gaisler ethernet MAC driver
+ * adapted from Opencores driver by Marko Isomaki
+ * found in found in the file LICENSE in this distribution or at
+#ifndef __GRETH_H__
+#define __GRETH_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Ethernet configuration registers */
+typedef struct _greth_regs {
+   volatile uint32_t ctrl;         /* Ctrl Register */
+   volatile uint32_t status;       /* Status Register */
+   volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
+   volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
+   volatile uint32_t mdio_ctrl;    /* MDIO control and status */
+   volatile uint32_t txdesc;       /* Transmit descriptor pointer */
+   volatile uint32_t rxdesc;       /* Receive descriptor pointer */
+   volatile uint32_t edcl;         /* EDCL IP register */
+   volatile uint32_t ht_msb;       /* Multicast MSB hash */
+   volatile uint32_t ht_lsb;       /* Multicast LSB hash */
+} greth_regs;
+#define GRETH_TOTAL_BD           128
+#define GRETH_MAXBUF_LEN         1520
+/* Tx BD */
+#define GRETH_TXD_ENABLE      0x0800 /* Tx BD Enable */
+#define GRETH_TXD_WRAP        0x1000 /* Tx BD Wrap (last BD) */
+#define GRETH_TXD_IRQ         0x2000 /* Tx BD IRQ Enable */
+#define GRETH_TXD_MORE        0x20000 /* Tx BD More (more descs for packet) */
+#define GRETH_TXD_IPCS        0x40000 /* Tx BD insert ip chksum */
+#define GRETH_TXD_TCPCS       0x80000 /* Tx BD insert tcp chksum */
+#define GRETH_TXD_UDPCS       0x100000 /* Tx BD insert udp chksum */
+#define GRETH_TXD_UNDERRUN    0x4000 /* Tx BD Underrun Status */
+#define GRETH_TXD_RETLIM      0x8000 /* Tx BD Retransmission Limit Status */
+#define GRETH_TXD_LATECOL     0x10000 /* Tx BD Late Collision */
+#define GRETH_TXD_STATS       (GRETH_TXD_UNDERRUN            | \
+                               GRETH_TXD_RETLIM              | \
+                               GRETH_TXD_LATECOL)
+#define GRETH_TXD_CS          (GRETH_TXD_IPCS            | \
+                               GRETH_TXD_TCPCS           | \
+                               GRETH_TXD_UDPCS)
+/* Rx BD */
+#define GRETH_RXD_ENABLE      0x0800 /* Rx BD Enable */
+#define GRETH_RXD_WRAP        0x1000 /* Rx BD Wrap (last BD) */
+#define GRETH_RXD_IRQ         0x2000 /* Rx BD IRQ Enable */
+#define GRETH_RXD_DRIBBLE     0x4000 /* Rx BD Dribble Nibble Status */
+#define GRETH_RXD_TOOLONG     0x8000 /* Rx BD Too Long Status */
+#define GRETH_RXD_CRCERR      0x10000 /* Rx BD CRC Error Status */
+#define GRETH_RXD_OVERRUN     0x20000 /* Rx BD Overrun Status */
+#define GRETH_RXD_LENERR      0x40000 /* Rx BD Length Error */
+#define GRETH_RXD_ID          0x40000 /* Rx BD IP Detected */
+#define GRETH_RXD_IR          0x40000 /* Rx BD IP Chksum Error */
+#define GRETH_RXD_UD          0x40000 /* Rx BD UDP Detected*/
+#define GRETH_RXD_UR          0x40000 /* Rx BD UDP Chksum Error */
+#define GRETH_RXD_TD          0x40000 /* Rx BD TCP Detected */
+#define GRETH_RXD_TR          0x40000 /* Rx BD TCP Chksum Error */
+#define GRETH_RXD_STATS       (GRETH_RXD_OVERRUN             | \
+                               GRETH_RXD_DRIBBLE             | \
+                               GRETH_RXD_TOOLONG             | \
+                               GRETH_RXD_CRCERR)
+/* CTRL Register */
+#define GRETH_CTRL_TXEN         0x00000001 /* Transmit Enable */
+#define GRETH_CTRL_RXEN         0x00000002 /* Receive Enable  */
+#define GRETH_CTRL_TXIRQ        0x00000004 /* Transmit Enable */
+#define GRETH_CTRL_RXIRQ        0x00000008 /* Receive Enable  */
+#define GRETH_CTRL_FULLD        0x00000010 /* Full Duplex */
+#define GRETH_CTRL_PRO          0x00000020 /* Promiscuous (receive all) */
+#define GRETH_CTRL_RST          0x00000040 /* Reset MAC */
+#define GRETH_CTRL_SP           0x00000080 /* 100MBit speed mode */
+#define GRETH_CTRL_GB           0x00000100 /* 1GBit speed mode */
+#define GRETH_CTRL_MCE          0x00000800 /* Multicast Enable */
+#define GRETH_CTRL_DD           0x00001000 /* Disable EDCL Duplex Detection */
+#define GRETH_CTRL_ED           0x00004000 /* EDCL Disable */
+#define GRETH_CTRL_MC           0x02000000 /* Multicast available */
+#define GRETH_CTRL_ME           0x04000000 /* MDIO interrupts enabled */
+#define GRETH_CTRL_GA           0x08000000 /* Gigabit MAC available */
+/* Status Register */
+#define GRETH_STATUS_RXERR      0x00000001 /* Receive Error */
+#define GRETH_STATUS_TXERR      0x00000002 /* Transmit Error IRQ */
+#define GRETH_STATUS_RXIRQ      0x00000004 /* Receive Frame IRQ */
+#define GRETH_STATUS_TXIRQ      0x00000008 /* Transmit Error IRQ */
+#define GRETH_STATUS_RXAHBERR   0x00000010 /* Receiver AHB Error */
+#define GRETH_STATUS_TXAHBERR   0x00000020 /* Transmitter AHB Error */
+#define GRETH_STATUS_NRD        0x0f000000 /* Number of descriptors */
+/* MDIO Control  */
+#define GRETH_MDIO_WRITE        0x00000001 /* MDIO Write */
+#define GRETH_MDIO_READ         0x00000002 /* MDIO Read */
+#define GRETH_MDIO_LINKFAIL     0x00000004 /* MDIO Link failed */
+#define GRETH_MDIO_BUSY         0x00000008 /* MDIO Link Busy */
+#define GRETH_MDIO_REGADR       0x000007C0 /* Register Address */
+#define GRETH_MDIO_PHYADR       0x0000F800 /* PHY address */
+#define GRETH_MDIO_DATA         0xFFFF0000 /* MDIO DATA */
+/* MII registers */
+#define GRETH_MII_EXTADV_1000FD 0x00000200
+#define GRETH_MII_EXTADV_1000HD 0x00000100
+#define GRETH_MII_EXTPRT_1000FD 0x00000800
+#define GRETH_MII_EXTPRT_1000HD 0x00000400
+#define GRETH_MII_100T4         0x00000200
+#define GRETH_MII_100TXFD       0x00000100
+#define GRETH_MII_100TXHD       0x00000080
+#define GRETH_MII_10FD          0x00000040
+#define GRETH_MII_10HD          0x00000020
+/* Attach routine */
+void greth_register_drv(void);
+/* PHY data */
+struct phy_device_info
+   int vendor;
+   int device;
+   int rev;
+   int adv;
+   int part;
+   int extadv;
+   int extpart;
+/* Limit speed modes advertised during auto-negotiation */
+#define GRETH_ADV_10_HD    0x0001
+#define GRETH_ADV_10_FD    0x0002
+#define GRETH_ADV_100_HD   0x0004
+#define GRETH_ADV_100_FD   0x0008
+#define GRETH_ADV_1000_HD  0x0010
+#define GRETH_ADV_1000_FD  0x0020
+#define GRETH_ADV_ALL      0x003f
+#ifdef CPU_U32_FIX
+void ipalign(struct mbuf *m);
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/include/grlib/network_interface_add.h b/bsps/include/grlib/network_interface_add.h
index 0000000..b04a96f
--- /dev/null
+++ b/bsps/include/grlib/network_interface_add.h
@@ -0,0 +1,47 @@
+/*  Network interface register help function
+ *  COPYRIGHT (c) 2008.
+ *  Cobham Gaisler AB.
+ *  This function adds a network interface to the
+ *  rtems_bsdnet_config.ifconfig linked list of interfaces.
+ *  The interface configuration is taken from the user defined
+ *  array interface_configs. This function is useful for PnP
+ *  systems when an unknown number of interfaces are available.
+#ifndef __NETWORK_INTERFACE_ADD_H__
+#define __NETWORK_INTERFACE_ADD_H__
+#include <rtems/rtems_bsdnet.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Interface configuration description */
+struct ethernet_config {
+	char	*ip_addr;	/* IP address */
+	char	*ip_netmask;	/* IP Netmask */
+	char	eth_adr[6];	/* Ethernet hardware MAC address */
+/* Array with configurations for all interfaces in the system
+ * Must be defined by the user.
+extern struct ethernet_config interface_configs[];
+/* Routine adding interface to rtems_bsdnet_config.ifconfig linked
+ * list of interfaces.
+int network_interface_add(struct rtems_bsdnet_ifconfig *interface);
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_NETWORKCONFIG_H_ */
diff --git a/bsps/powerpc/beatnik/include/bsp/if_em_pub.h b/bsps/powerpc/beatnik/include/bsp/if_em_pub.h
index 0000000..eb970e4
--- /dev/null
+++ b/bsps/powerpc/beatnik/include/bsp/if_em_pub.h
@@ -0,0 +1,22 @@
+#ifndef RTEMS_BSDNET_IF_EM_PUBLIC_SYMBOLS_H
+#define RTEMS_BSDNET_IF_EM_PUBLIC_SYMBOLS_H
+#include <rtems.h>
+#include <bsp/early_enet_link_status.h>
+#ifdef __cplusplus
+  extern "C" {
+#endif
+extern int                               rtems_em_attach(struct rtems_bsdnet_ifconfig *, int);
+extern int                               rtems_em_pci_setup(int);
+extern rtems_bsdnet_early_link_check_ops rtems_em_early_link_check_ops;
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h b/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
index 0000000..8ea849e
--- /dev/null
+++ b/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
@@ -0,0 +1,30 @@
+#ifndef RTEMS_BSDNET_IF_GFE_PUBLIC_SYMBOLS_H
+#define RTEMS_BSDNET_IF_GFE_PUBLIC_SYMBOLS_H
+#include <rtems.h>
+#include <net/ethernet.h>
+#ifdef __cplusplus
+  extern "C" {
+#endif
+extern int
+rtems_gfe_attach(struct rtems_bsdnet_ifconfig *, int);
+/* enet_addr must be 6 bytes long */
+int
+rtems_gfe_setup(int unit, char *enet_addr, uint32_t base_addr);
+rtems_gfe_early_link_check_ops;
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h b/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
index 0000000..46cc4cc
--- /dev/null
+++ b/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
@@ -0,0 +1,426 @@
+#ifndef RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
+#define RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
+ * Authorship
+ * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
+ *     created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
+ * 	   Stanford Linear Accelerator Center, Stanford University.
+ * Acknowledgement of sponsorship
+ * The 'beatnik' BSP was produced by
+ *     the Stanford Linear Accelerator Center, Stanford University,
+ * 	   under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * Government disclaimer of liability
+ * Neither the United States nor the United States Department of Energy,
+ * nor any of their employees, makes any warranty, express or implied, or
+ * assumes any legal liability or responsibility for the accuracy,
+ * completeness, or usefulness of any data, apparatus, product, or process
+ * disclosed, or represents that its use would not infringe privately owned
+ * rights.
+ * Stanford disclaimer of liability
+ * Stanford University makes no representations or warranties, express or
+ * implied, nor assumes any liability for the use of this software.
+ * Stanford disclaimer of copyright
+ * Stanford University, owner of the copyright, hereby disclaims its
+ * copyright and all other rights in this software.  Hence, anyone may
+ * freely use it for any purpose without restriction.
+ * Maintenance of notices
+ * In the interest of clarity regarding the origin and status of this
+ * SLAC software, this and all the preceding Stanford University notices
+ * are to remain affixed to any copy or derivative of this software made
+ * or distributed by the recipient and are to be affixed to any copy of
+ * software made or distributed by the recipient that contains a copy or
+ * derivative of this software.
+ * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
+#include <rtems.h>
+#include <stdint.h>
+#ifdef __cplusplus
+  extern "C" {
+#endif
+extern int                               rtems_mve_attach(struct rtems_bsdnet_ifconfig *, int);
+extern rtems_bsdnet_early_link_check_ops rtems_mve_early_link_check_ops;
+/* Low-level Driver API.
+ * This provides driver access to applications that want to use e.g., the second
+ * ethernet interface w/o running the BSD TCP/IP stack.
+/* Opaque handle */
+struct mveth_private;
+/* Direct assignment of MVE flags to user API relies on irqs and x-irqs not overlapping */
+#define BSP_MVE_IRQ_RX		(1<<2)
+#define BSP_MVE_IRQ_TX		(1<<0)
+#define BSP_MVE_IRQ_LINK	(1<<16)
+/* Setup an interface.
+ * Allocates resources for descriptor rings and sets up the driver software structure.
+ * Arguments:
+ *	unit:
+ *		interface # (1..2). The interface must not be attached to BSD.
+ *  driver_tid:
+ *		ISR posts RTEMS event # ('unit' - 1) to task with ID 'driver_tid' and disables interrupts
+ *		from this interface.
+ *	void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred):
+ *		Pointer to user-supplied callback to release a buffer that had been sent
+ *		by BSP_mve_send_buf() earlier. The callback is passed 'cleanup_txbuf_arg'
+ *		and a flag indicating whether the send had been successful.
+ *		The driver no longer accesses 'user_buf' after invoking this callback.
+ *		CONTEXT: This callback is executed either by BSP_mve_swipe_tx() or
+ *		BSP_mve_send_buf(), BSP_mve_init_hw(), BSP_mve_stop_hw() (the latter
+ *		ones calling BSP_mve_swipe_tx()).
+ *	void *cleanup_txbuf_arg:
+ *		Closure argument that is passed on to 'cleanup_txbuf()' callback;
+ *	void *(*alloc_rxbuf)(int *p_size, unsigned long *p_data_addr),
+ *		Pointer to user-supplied callback to allocate a buffer for subsequent
+ *		insertion into the RX ring by the driver.
+ *		RETURNS: opaque handle to the buffer (which may be a more complex object
+ *				 such as an 'mbuf'). The handle is not used by the driver directly
+ *				 but passed back to the 'consume_rxbuf()' callback.
+ *				 Size of the available data area and pointer to buffer's data area
+ *				 in '*psize' and '*p_data_area', respectively.
+ *				 If no buffer is available, this routine should return NULL in which
+ *				 case the driver drops the last packet and re-uses the last buffer
+ *				 instead of handing it out to 'consume_rxbuf()'.
+ *		CONTEXT: Called when initializing the RX ring (BSP_mve_init_hw()) or when
+ *				 swiping it (BSP_mve_swipe_rx()).
+ *	void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len);
+ *		Pointer to user-supplied callback to pass a received buffer back to
+ *		the user. The driver no longer accesses the buffer after invoking this
+ *		callback (with 'len'>0, see below). 'user_buf' is the buffer handle
+ *		previously generated by 'alloc_rxbuf()'.
+ *		The callback is passed 'cleanup_rxbuf_arg' and a 'len'
+ *		argument giving the number of bytes that were received.
+ *		'len' may be <=0 in which case the 'user_buf' argument is NULL.
+ *		'len' == 0 means that the last 'alloc_rxbuf()' had failed,
+ *		'len' < 0 indicates a receiver error. In both cases, the last packet
+ *		was dropped/missed and the last buffer will be re-used by the driver.
+ *		NOTE: the data are 'prefixed' with two bytes, i.e., the ethernet packet header
+ *		      is stored at offset 2 in the buffer's data area. Also, the FCS (4 bytes)
+ *		      is appended. 'len' accounts for both.
+ *		CONTEXT: Called from BSP_mve_swipe_rx().
+ *	void *cleanup_rxbuf_arg:
+ *		Closure argument that is passed on to 'consume_rxbuf()' callback;
+ *  rx_ring_size, tx_ring_size:
+ *		How many big to make the RX and TX descriptor rings. Note that the sizes
+ *		may be 0 in which case a reasonable default will be used.
+ *		If either ring size is < 0 then the RX or TX will be disabled.
+ *		Note that it is illegal in this case to use BSP_mve_swipe_rx() or
+ *		BSP_mve_swipe_tx(), respectively.
+ *  irq_mask:
+ *		Interrupts to enable. OR of flags from above.
+struct mveth_private *
+BSP_mve_setup(
+	int		 unit,
+	rtems_id driver_tid,
+	void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
+	void *cleanup_txbuf_arg,
+	void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
+	void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len),
+	void *consume_rxbuf_arg,
+	int		rx_ring_size,
+	int		tx_ring_size,
+	int		irq_mask
+ * Alternate 'setup' routine allowing the user to install an ISR rather
+ * than a task ID.
+ * All parameters (other than 'isr' / 'isr_arg') and the return value
+ * are identical to the BSP_mve_setup() entry point.
+BSP_mve_setup_1(
+	int		 unit,
+	void     (*isr)(void *isr_arg),
+	void     *isr_arg,
+	int		rx_ring_size,
+	int		tx_ring_size,
+	int		irq_mask
+ * Initialize interface hardware
+ * 'mp'			handle obtained by from BSP_mve_setup().
+ * 'promisc'	whether to set promiscuous flag.
+ * 'enaddr'		pointer to six bytes with MAC address. Read
+ *				from the device if NULL.
+ * Note:        Multicast filters are cleared by this routine.
+ *              However, in promiscuous mode the mcast filters
+ *              are programmed to accept all multicast frames.
+void
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
+ * Clear multicast hash filter. No multicast frames are accepted
+ * after executing this routine (unless the hardware was initialized
+ * in 'promiscuous' mode).
+void
+BSP_mve_mcast_filter_clear(struct mveth_private *mp);
+ * Program multicast filter to accept all multicast frames
+void
+BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
+ * Add a MAC address to the multicast filter.
+ * Existing entries are not changed but note that
+ * the filter is imperfect, i.e., multiple MAC addresses
+ * may alias to a single filter entry. Hence software
+ * filtering must still be performed.
+ * If a higher-level driver implements IP multicasting
+ * then multiple IP addresses may alias to the same MAC
+ * address. This driver maintains a 'reference-count'
+ * which is incremented every time the same MAC-address
+ * is passed to this routine; the address is only removed
+ * from the filter if BSP_mve_mcast_filter_accept_del()
+ * is called the same number of times (or by BSP_mve_mcast_filter_clear).
+void
+BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
+ * Remove a MAC address from the multicast filter.
+ * This routine decrements the reference count of the given
+ * MAC-address and removes it from the filter once the
+ * count reaches zero.
+void
+BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
+ * Shutdown hardware and clean out the rings
+void
+BSP_mve_stop_hw(struct mveth_private *mp);
+/* calls BSP_mve_stop_hw(), releases all resources and marks the interface
+ * as unused.
+ * RETURNS 0 on success, nonzero on failure.
+ * NOTE:   the handle MUST NOT be used after successful execution of this
+ *         routine.
+int
+BSP_mve_detach(struct mveth_private *mp);
+int
+BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len,
+    void *data_p, int d_len);
+ * Enqueue a mbuf chain or a raw data buffer for transmission;
+ * RETURN: #bytes sent or -1 if there are not enough free descriptors
+ * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
+ * OTOH, a raw data packet (or a different type of buffer)
+ * may be send (non-BSD driver) by pointing data_p to the start of
+ * the data and passing 'len' > 0.
+ * 'm_head' is passed back to the 'cleanup_txbuf()' callback.
+ * Comments: software cache-flushing incurs a penalty if the
+ *           packet cannot be queued since it is flushed anyways.
+ *           The algorithm is slightly more efficient in the normal
+ *			 case, though.
+ * RETURNS: # bytes enqueued to device for transmission or -1 if no
+ *          space in the TX ring was available.
+int
+BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len);
+/* Descriptor scavenger; cleanup the TX ring, passing all buffers
+ * that have been sent to the cleanup_tx() callback.
+ * This routine is called from BSP_mve_send_buf(), BSP_mve_init_hw(),
+ * BSP_mve_stop_hw().
+ * RETURNS: number of buffers processed.
+int
+BSP_mve_swipe_tx(struct mveth_private *mp);
+/* Retrieve all received buffers from the RX ring, replacing them
+ * by fresh ones (obtained from the alloc_rxbuf() callback). The
+ * received buffers are passed to consume_rxbuf().
+int
+BSP_mve_swipe_rx(struct mveth_private *mp);
+/* read ethernet address from hw to buffer */
+void
+BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *eaddr);
+/* read/write media word.
+ *   'cmd': can be SIOCGIFMEDIA, SIOCSIFMEDIA, 0 or 1. The latter
+ *          are aliased to the former for convenience.
+ *  'parg': pointer to media word.
+ * RETURNS: 0 on success, nonzero on error
+ * NOTE:    This routine is thread-safe.
+int
+BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg);
+/* Interrupt related routines */
+/* Note: the BSP_mve_enable/disable/ack_irqs() entry points
+ *       are deprecated.
+ *       The newer API where the user passes a mask allows
+ *       for more selective control.
+/* Enable all supported interrupts at device */
+void
+BSP_mve_enable_irqs(struct mveth_private *mp);
+/* Disable all supported interrupts at device */
+void
+BSP_mve_disable_irqs(struct mveth_private *mp);
+/* Acknowledge (and clear) all supported interrupts.
+ * RETURNS: interrupts that were raised.
+uint32_t
+BSP_mve_ack_irqs(struct mveth_private *mp);
+/* Enable interrupts included in 'mask' (leaving
+ * already enabled interrupts on). If the mask
+ * includes bits that were not passed to the 'setup'
+ * routine then the behavior is undefined.
+void
+BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
+/* Disable interrupts included in 'mask' (leaving
+ * other ones that are currently enabled on). If the
+ * mask includes bits that were not passed to the 'setup'
+ * RETURNS: Bitmask of interrupts that were enabled upon entry
+ *          into this routine. This can be used to restore the
+ *          previous state.
+uint32_t
+BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
+/* Acknowledge and clear selected interrupts.
+ * RETURNS: All pending interrupts.
+ * NOTE:    Only pending interrupts contained in 'mask'
+ *          are cleared. Others are left pending.
+ *          This routine can be used to check for pending
+ *          interrupts (pass mask ==  0) or to clear all
+ *          interrupts (pass mask == -1).
+uint32_t
+BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
+/* If the PHY link status changes then some
+ * internal settings in the ethernet controller's
+ * serial port need to be updated to match the
+ * PHY settings. Use this routine to perform the
+ * necessary steps after a link change has been
+ * detected.
+ * RETURNS: 0 on success, -1 if the PHY state
+ *          could not be determined.
+ *          The current state of the media as read
+ *          by BSP_mve_media_ioctl() is returned in
+ *          *pmedia.
+ * NOTE:    This routine calls BSP_mve_media_ioctl().
+int
+BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia);
+/* Retrieve the driver daemon TID that was passed to
+ * BSP_mve_setup().
+rtems_id
+BSP_mve_get_tid(struct mveth_private *mp);
+/* Dump statistics to file (stdout if NULL)
+ * NOTE: this routine is not thread safe
+void
+BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
+ * Example driver task loop (note: no synchronization of
+ * buffer access shown!).
+ * RTEMS_EVENTx = 0,1 or 2 depending on IF unit.
+ *    / * setup (obtain handle) and initialize hw here * /
+ *    do {
+ *      / * ISR disables IRQs and posts event * /
+ *		rtems_event_receive( RTEMS_EVENTx, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
+ *		irqs = BSP_mve_ack_irqs(handle);
+ *      if ( irqs & BSP_MVE_IRQ_TX ) {
+ *			BSP_mve_swipe_tx(handle); / * cleanup_txbuf() callback executed * /
+ *      if ( irqs & BSP_MVE_IRQ_RX ) {
+ *			BSP_mve_swipe_rx(handle); / * alloc_rxbuf() and consume_rxbuf() executed * /
+ *		if ( irqs & BSP_MVE_IRQ_LINK ) {
+ *          / * update serial port settings from current link status * /
+ *          BSP_mve_ack_link_chg(handle, 0);
+ *		BSP_mve_enable_irqs(handle);
+ *    } while (1);
+#ifdef __cplusplus
+#endif
+#endif
2.26.2
