[PATCH 0/6] Add aarch64/xilinx-versal
Thu Jun 24 14:38:50 UTC 2021
On Wed, Jun 23, 2021 at 7:55 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Looks good. It's odd that we can't step down from EL3->EL2S->EL1S
> and have the timer work on the versal. It'd be nice if we could just flip
> the security bit one way or the other on the way down and share the
> cascade from EL3 to EL1 without skipping parts of it. This might be
> something to look into further in the future.
Thanks. I agree. The problem seems to be that HCR_EL2 is ignored if
(SCR_EL3.EEL2 = 0 && SCR_EL3.NS = 0). So, you either need to set the
non-secure mode, or you need to set EL2 security mode, which then
traps into EL2 on some accesses in Secure EL1. I wasn't able to figure
out if it's possible for EL2 to avoid those traps.
When I did enable SCR_EL3.EEL2 and tried to do the EL2 -> EL1S drop,
the eret comes back to _el2_start instead of _el1_start. I couldn't
figure that one out.
https://developer.arm.com/documentation/ddi0595/2020-12/AArch64-Registers/SCR-EL3--Secure-Configuration-Register?lang=en
Gedare
> Kinsey
> -----Original Message-----
> From: devel <devel-bounces at rtems.org> On Behalf Of Gedare Bloom
> Sent: Tuesday, June 22, 2021 23:30
> To: devel at rtems.org
> Subject: [PATCH 0/6] Add aarch64/xilinx-versal
> This patch series adds support for the Xilinx Versal ACAP
> targeting the qemu emulated support (xlnx-versal-virt) and
> with a config for vck190. The hardware support on vck190 is
> still work-in-progress, and the ilp32 has not been tested.
> The patch set includes non-functional changes to make the
> icspicfgr0/1 an array for better indexing, to add the
> physical secure timer, and a mnemonic to access the group 1
> interrupt enable at EL3. These non-functional changes wound
> up being unnecessary, but were left in case they are useful
> to someone in the future. The virtual and physical secure timers
> do not work with the xilinx_versal_lp64_qemu BSP. Only the
> physical non-secure timer works, and only in EL1 security mode.
> The xlnx-versal-virt direct boots on qemu in EL3. The current
> approach steps down directly to EL1 in Secure Mode. If EL3 is
> instead stepped down to EL2 and then to EL1 non-secure, the
> timer IRQ dispatching does not work properly for some reason.
> So now we have support in place to run in EL1 Secure mode
> or in EL1 Non-Secure mode, controlled by a configuration option.
> The a53 and a72 BSPs can only work in the EL1 Non-Secure mode,
> while the xilinx_zynq_lp64_qemu seems to be able to work with
> both EL1 Secure and Non-Secure modes. The selection is made by
> a new config option, AARCH_IS_NON_SECURE.
> Tester Results for xilinx_versal_lp64_qemu:
> Passed:        549
> Failed:          1
> User Input:      5
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         0
> Test too long:   0
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Total:         558
> Failures:
>  spcpucounter01.exe
> User Input:
>  top.exe
>  fileio.exe
>  capture.exe
>  monitor.exe
>  termios.exe
> Benchmark:
>  dhrystone.exe
>  whetstone.exe
>  linpack.exe
> The failure in spcpucounter01.exe appears to be related to the
> ongoing problem with qemu random failures. Manual testing can
> pass or fail.
> No regressions noted in a53, a72, or zynqmp qemu testing.
> Gedare Bloom (5):
>   aarch64/xilinx-versal: new BSPs for qemu and vck190
>   bsps/dev/irq: make icspicfgr an indexable array
>   bsps/aarch64: add mnemonic for ICC_IGRPEN1_EL3
>   bsps/aarch64: add physical secure timer
>   bsps/aarch64: add non-secure mode and versal support
> Kinsey Moore (1):
>   aarch64: add support to drop EL3 to EL2
>  .../shared/clock/arm-generic-timer-aarch64.c  |   8 +
>  bsps/aarch64/shared/start/start.S             |  38 ++-
>  bsps/aarch64/xilinx-versal/console/console.c  | 134 ++++++++++
>  .../dev/serial/versal-uart-polled.c           | 228 ++++++++++++++++++
>  bsps/aarch64/xilinx-versal/include/bsp.h      |  81 +++++++
>  bsps/aarch64/xilinx-versal/include/bsp/irq.h  |  72 ++++++
>  .../include/dev/serial/versal-uart-regs.h     | 141 +++++++++++
>  .../include/dev/serial/versal-uart.h          |  90 +++++++
>  bsps/aarch64/xilinx-versal/include/tm27.h     |  45 ++++
>  bsps/aarch64/xilinx-versal/start/bspstart.c   |  48 ++++
>  .../xilinx-versal/start/bspstarthooks.c       |  51 ++++
>  .../aarch64/xilinx-versal/start/bspstartmmu.c |  77 ++++++
>  bsps/include/dev/irq/arm-gic-regs.h           |   6 +-
>  bsps/shared/dev/irq/arm-gicv3.c               |  24 +-
>  spec/build/bsps/aarch64/a53/grp.yml           |   2 +
>  spec/build/bsps/aarch64/a72/grp.yml           |   2 +
>  spec/build/bsps/aarch64/optgtuseps.yml        |  17 ++
>  spec/build/bsps/aarch64/optgtusevirt.yml      |  16 ++
>  spec/build/bsps/aarch64/optisns.yml           |  20 ++
>  spec/build/bsps/aarch64/xilinx-versal/abi.yml |  22 ++
>  .../aarch64/xilinx-versal/bspqemuilp32.yml    |  19 ++
>  .../aarch64/xilinx-versal/bspqemulp64.yml     |  19 ++
>  .../aarch64/xilinx-versal/bspvck190ilp32.yml  |  19 ++
>  .../aarch64/xilinx-versal/bspvck190lp64.yml   |  19 ++
>  spec/build/bsps/aarch64/xilinx-versal/grp.yml |  56 +++++
>  .../bsps/aarch64/xilinx-versal/grp_qemu.yml   |  18 ++
>  .../bsps/aarch64/xilinx-versal/grp_vck190.yml |  18 ++
>  .../aarch64/xilinx-versal/linkcmds_ilp32.yml  |  74 ++++++
>  .../aarch64/xilinx-versal/linkcmds_lp64.yml   |  74 ++++++
>  spec/build/bsps/aarch64/xilinx-versal/obj.yml |  44 ++++
>  .../bsps/aarch64/xilinx-versal/optclkuart.yml |  20 ++
>  .../aarch64/xilinx-versal/optconminor.yml     |  16 ++
>  .../bsps/aarch64/xilinx-versal/optloadoff.yml |  22 ++
>  .../aarch64/xilinx-versal/optnocachelen.yml   |  18 ++
>  .../bsps/aarch64/xilinx-versal/optramlen.yml  |  18 ++
>  .../bsps/aarch64/xilinx-versal/optramori.yml  |  22 ++
>  .../bsps/aarch64/xilinx-versal/tstqemu.yml    |  19 ++
>  .../bsps/aarch64/xilinx-versal/tstvck190.yml  |  19 ++
>  spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |   2 +
>  spec/build/bsps/optstartmon.yml               |  16 ++
>  40 files changed, 1647 insertions(+), 7 deletions(-)
>  create mode 100644 bsps/aarch64/xilinx-versal/console/console.c
>  create mode 100644 bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
>  create mode 100644 bsps/aarch64/xilinx-versal/include/bsp.h
>  create mode 100644 bsps/aarch64/xilinx-versal/include/bsp/irq.h
>  create mode 100644 bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h
>  create mode 100644 bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h
>  create mode 100644 bsps/aarch64/xilinx-versal/include/tm27.h
>  create mode 100644 bsps/aarch64/xilinx-versal/start/bspstart.c
>  create mode 100644 bsps/aarch64/xilinx-versal/start/bspstarthooks.c
>  create mode 100644 bsps/aarch64/xilinx-versal/start/bspstartmmu.c
>  create mode 100644 spec/build/bsps/aarch64/optgtuseps.yml
>  create mode 100644 spec/build/bsps/aarch64/optgtusevirt.yml
>  create mode 100644 spec/build/bsps/aarch64/optisns.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/abi.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp_qemu.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/obj.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optconminor.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optramlen.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optramori.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
>  create mode 100644 spec/build/bsps/optstartmon.yml
> 2.25.1
> devel mailing list
> devel at rtems.org
