[PATCH rtems-libbsd 2/3] testsuite/media01: Add pattern test.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 25 08:35:40 UTC 2021
 libbsd.py                        |   2 +-
 testsuite/media01/pattern-test.c | 337 +++++++++++++++++++++++++++++++
 testsuite/media01/pattern-test.h |  44 ++++
 testsuite/media01/test_main.c    |   5 +-
 4 files changed, 386 insertions(+), 2 deletions(-)
 create mode 100644 testsuite/media01/pattern-test.c
 create mode 100644 testsuite/media01/pattern-test.h
diff --git a/libbsd.py b/libbsd.py
index a2056f364..f8a35e6c6 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5402,7 +5402,7 @@ class tests(builder.Module):
                                           runTest = False, netTest = True,
                                           extraLibs = ['telnetd']))
         self.addTest(mm.generator['test']('smp01', ['test_main'], extraLibs = ['rtemstest']))
-        self.addTest(mm.generator['test']('media01', ['test_main'],
+        self.addTest(mm.generator['test']('media01', ['test_main', 'pattern-test'],
                                           runTest = False,
                                           extraLibs = ['ftpd', 'telnetd']))
         self.addTest(mm.generator['test']('mcast01', ['test_main']))
diff --git a/testsuite/media01/pattern-test.c b/testsuite/media01/pattern-test.c
new file mode 100644
index 000000000..4b00cb736
--- /dev/null
+++ b/testsuite/media01/pattern-test.c
@@ -0,0 +1,337 @@
+ * @file
+ * @brief Command to fill a file with a pattern.
+ * The written pattern is a simple 32 bit counter which makes it easy to find
+ * problems where buffers are not written to the correct location or where some
+ * blocks are missing.
+ * This file can be either compiled as part of RTEMS or as a stand alone Linux
+ * or (most likely) FreeBSD application. To compile it as stand alone, just use
+ * "gcc pattern-test.c"
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH.
+ * are met:
+#ifdef __rtems__
+#include "pattern-test.h"
+#endif /* __rtems__ */
+#include <arpa/inet.h>
+#include <err.h>
+#include <fcntl.h>
+#include <stdbool.h>
+#include <stdint.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/stat.h>
+#include <unistd.h>
+#define MIN(X, Y) (((X) < (Y)) ? (X) : (Y))
+static const char * const usage =
+	"Fill a file or a device file with a simple incrementing 32 bit pattern.\n"
+	"Use with:\n"
+	"    pattern [fill|check] <file> <size> <block_size> [<start_value> [<output>]]\n"
+	"Arguments:\n"
+	"    All numbers can be decimal (e.g. 256) or hex (e.g. 0x100)\n"
+	"    <size> and <block_size> is in bytes\n"
+	"    <start_value> start with this counter value\n"
+	"    <output>: Only relevant for check. Can be: \n"
+	"              <nr>: print the first <nr> errors\n"
+	"              \"short\": Print all errors but short form\n";
+static int
+check_and_process_params(
+	int argc,
+	char *argv[],
+	int open_flags,
+	int *fd,
+	size_t *size,
+	size_t *block_size,
+	uint8_t **block,
+	uint8_t **read_block,
+	int *max_errors,
+	bool *short_output,
+	uint32_t *start_value
+	if (argc < 4) {
+		printf(usage);
+		return -1;
+	if (argc > 4) {
+		*start_value = strtoul(argv[4], NULL, 0);
+	} else {
+		*start_value = 0;
+	if (short_output != NULL && max_errors != NULL) {
+		*short_output = false;
+		*max_errors = 1;
+		if (argc > 5) {
+			if (strcmp("short", argv[5]) == 0) {
+				*max_errors = -1;
+				*short_output = true;
+			} else {
+				*max_errors = strtol(argv[5], NULL, 0);
+				if (*max_errors <= 0) {
+					warn("Can't use <output> parameter.");
+					return -1;
+	*size = strtoul(argv[2], NULL, 0);
+	if (size == 0) {
+		warn("Couldn't convert size or size set to 0");
+		return -1;
+	*block_size = strtoul(argv[3], NULL, 0);
+	if (block_size == 0) {
+		warn("Couldn't convert block_size or block_size set to 0");
+		return -1;
+	if (block != NULL) {
+		*block = malloc(*block_size);
+		if (*block == NULL) {
+			warn("Couldn't allocate block");
+			return -1;
+	if (read_block != NULL) {
+		*read_block = malloc(*block_size);
+		if (*read_block == NULL) {
+			warn("Couldn't allocate read_block");
+				free(*block);
+			return -1;
+	*fd = open(argv[1], open_flags, 0666);
+	if (*fd < 0) {
+		warn("Couldn't open file");
+			free(*block);
+			free(*read_block);
+		return -1;
+	printf("File: %s\nSize: 0x%x\nBlock size: 0x%x\n",
+	    argv[1], *size, *block_size);
+	return 0;
+/* Write addresses to the block. Keep word boundaries intact. */
+static void
+fill_block(uint8_t *block, size_t size, uint32_t start)
+	uint32_t pattern_size = sizeof(start);
+	uint32_t start_offset = start % pattern_size;
+	uint32_t value_h = start & ~(pattern_size - 1);
+	uint32_t value_n = htonl(value_h);
+	uint8_t *val = (uint8_t *) &value_n;
+	if (start_offset != 0) {
+		size_t to_write = MIN(pattern_size - start_offset, size);
+		memcpy(block, val + start_offset, to_write);
+		block += to_write;
+		size -= to_write;
+		value_h += pattern_size;
+		value_n = htonl(value_h);
+	while (size >= pattern_size) {
+		memcpy(block, val, pattern_size);
+		block += pattern_size;
+		size -= pattern_size;
+	if (size > 0) {
+		memcpy(block, val, size);
+static int
+command_pattern_fill(int argc, char *argv[])
+	int fd;
+	size_t size;
+	size_t block_size;
+	uint8_t *block;
+	uint32_t start_value;
+	int rv;
+	rv = check_and_process_params(argc, argv, O_WRONLY | O_CREAT,
+	    &fd, &size, &block_size, &block, NULL, NULL, NULL, &start_value);
+	if (rv != 0) {
+		warnx("Error while processing parameters.\n");
+		return rv;
+	for (size_t current = start_value;
+	    current < start_value + size;
+	    current += block_size) {
+		size_t write_size = MIN(block_size, size-current);
+		ssize_t written;
+		fill_block(block, write_size, current);
+		written = write(fd, block, write_size);
+		if (written != (ssize_t)write_size) {
+			warn("Writing failed on block at 0x%x", current);
+			break;
+	free(block);
+	close(fd);
+	return 0;
+static void
+print_block(uint8_t *block, size_t size)
+	for (size_t i = 0; i < size; ++i) {
+		if (i > 0 && i % 0x10 == 0) {
+			printf("\n");
+		printf("%02x ", block[i]);
+	printf("\n");
+static int
+command_pattern_check(int argc, char *argv[])
+	int fd;
+	size_t size;
+	uint8_t *block;
+	uint8_t *read_block;
+	int rv;
+	int errors = 0;
+	int max_errors;
+	bool short_output;
+	bool last_was_error = false;
+	rv = check_and_process_params(argc, argv, O_RDONLY,
+	    &fd, &size, &block_size, &block, &read_block,
+	    &max_errors, &short_output, &start_value);
+	if (rv != 0) {
+		return rv;
+	    current < size + start_value;
+		size_t read_size = MIN(block_size, size-current);
+		ssize_t received;
+		fill_block(block, read_size, current);
+		received = read(fd, read_block, read_size);
+		if (received != (ssize_t)read_size) {
+			warn("Reading failed on block at 0x%x", current);
+			break;
+		rv = memcmp(block, read_block, read_size);
+		if (short_output) {
+			bool is_error = (rv != 0);
+			if (last_was_error != is_error) {
+				warnx("%s: 0x%x",
+				    is_error ? "ERR" : "OK ",
+				    current);
+			last_was_error = is_error;
+		} else if (rv != 0) {
+			warnx("Pattern wrong in block at 0x%x", current);
+			warnx("Expected:");
+			print_block(block, read_size);
+			warnx("Got:");
+			print_block(read_block, read_size);
+			++errors;
+			if (errors >= max_errors) {
+				warnx("Too many errors. Refusing to continue.");
+				break;
+	free(read_block);
+	free(block);
+	close(fd);
+	return 0;
+static int
+command_pattern(int argc, char *argv[])
+	if (argc < 2) {
+		printf(usage);
+		return -1;
+	} else if (strcmp(argv[1], "fill") == 0) {
+		return command_pattern_fill(argc-1, &argv[1]);
+	} else if (strcmp(argv[1], "check") == 0) {
+		return command_pattern_check(argc-1, &argv[1]);
+	} else {
+		printf(usage);
+		return -1;
+#ifdef __rtems__
+rtems_shell_cmd_t shell_PATTERN_Command = {
+	.name = "pattern",
+	.usage = usage,
+	.topic = "files",
+	.command = command_pattern,
+#else /* __rtems__ */
+int
+main(int argc, char *argv[])
+	return command_pattern(argc, argv);
diff --git a/testsuite/media01/pattern-test.h b/testsuite/media01/pattern-test.h
index 000000000..5d89e16ca
--- /dev/null
+++ b/testsuite/media01/pattern-test.h
@@ -0,0 +1,44 @@
+ * are met:
+#ifndef TESTSUITE_PATTERN_H
+#define TESTSUITE_PATTERN_H
+#include <rtems.h>
+#include <rtems/shell.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+extern rtems_shell_cmd_t shell_PATTERN_Command;
+#ifdef __cplusplus
+#endif /* TESTSUITE_PATTERN_H */
diff --git a/testsuite/media01/test_main.c b/testsuite/media01/test_main.c
index 9c05fc077..2a1c9aae7 100644
--- a/testsuite/media01/test_main.c
+++ b/testsuite/media01/test_main.c
@@ -53,6 +53,8 @@
 #include <rtems/telnetd.h>
 #define TEST_NAME "LIBBSD MEDIA 1"
 #define TEST_STATE_USER_INPUT 1
@@ -241,7 +243,8 @@ early_initialization(void)
   &rtems_shell_SYSCTL_Command, \
   &rtems_shell_IFCONFIG_Command, \
   &rtems_shell_IFMCSTAT_Command, \
-  &rtems_shell_VMSTAT_Command
+  &rtems_shell_VMSTAT_Command, \
+  &shell_PATTERN_Command
 #define CONFIGURE_SHELL_COMMAND_CPUINFO
 #define CONFIGURE_SHELL_COMMAND_CPUUSE
2.26.2
