[PATCH rtems 1/2] telnetd.c: Remove RTEMS_NETWORKING check
Fri May 21 03:57:03 UTC 2021
Well, since you pushed 2/2, you should push 1/2 (unless there are
different patch series?)
We should prefer to review and merge all/none of a series.
On Thu, May 20, 2021 at 9:56 PM Gedare Bloom <gedare at rtems.org> wrote:
> Seems fine by me, but wait until Monday to let anyone complain if they want.
> On Thu, May 20, 2021 at 5:35 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > Hi,
> > On Thu, Apr 22, 2021 at 12:21 PM Gedare Bloom <gedare at rtems.org> wrote:
> > > I guess there's not much else to do here without a network stack API
> > > to manipulate the network task(s).
> > > Is there a ticket to fix the lack of ability to configure and access
> > > network task priorities? I'm guessing libbsd and lwip will both need
> > > to figure out how to do this somehow. The design isn't obvious to me
> > > right now.
> > I somehow missed this before.
> > I raised a ticket: https://devel.rtems.org/ticket/4436
> > Is this ok to be pushed with this ticked number mentioned in the comment?
> > Best regards,
> > Vijay
> > > On Thu, Apr 22, 2021 at 12:07 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > > Ping :)
> > > > On Tue, Apr 13, 2021 at 11:45 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > > > Set the priority manually to make telnetd compatible with the
> > > > >  cpukit/telnetd/telnetd.c | 11 +----------
> > > > >  1 file changed, 1 insertion(+), 10 deletions(-)
> > > > > diff --git a/cpukit/telnetd/telnetd.c b/cpukit/telnetd/telnetd.c
> > > > > index b8adec297a..7dad2f2f92 100644
> > > > > --- a/cpukit/telnetd/telnetd.c
> > > > > +++ b/cpukit/telnetd/telnetd.c
> > > > > @@ -58,10 +58,6 @@
> > > > >  #include <rtems/thread.h>
> > > > >  #include <rtems/userenv.h>
> > > > > -#ifdef RTEMS_NETWORKING
> > > > > -#include <rtems/rtems_bsdnet.h>
> > > > > -#endif
> > > > >  #define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
> > > > >  #define TELNETD_EVENT_ERROR RTEMS_EVENT_1
> > > > > @@ -400,12 +396,7 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
> > > > >    ctx->server_socket = -1;
> > > > >    LIST_INIT(&ctx->free_sessions);
> > > > > -  /* Check priority */
> > > > > -  if (ctx->config.priority == 0) {
> > > > > -    ctx->config.priority = rtems_bsdnet_config.network_task_priority;
> > > > > -#endif
> > > > > +  /* Set priority */
> > > > >      ctx->config.priority = 100;
> > > > > 2.26.2
