[RTEMS 6 v1] Add support for IDLE Thread stack allocator
Thu Oct 7 22:29:21 UTC 2021
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
 cpukit/include/rtems/confdefs/percpu.h        |  18 ++-
 cpukit/include/rtems/confdefs/wkspace.h       |  16 +++
 cpukit/include/rtems/config.h                 |  12 ++
 cpukit/include/rtems/score/stack.h            |  24 ++++
 cpukit/score/src/stackallocatorforidle.c      |  59 ++++++++++
 cpukit/score/src/threadcreateidle.c           |  12 +-
 spec/build/cpukit/librtemscpu.yml             |   1 +
 spec/build/testsuites/sptests/grp.yml         |   4 +
 .../build/testsuites/sptests/spstkalloc03.yml |  19 ++++
 .../build/testsuites/sptests/spstkalloc04.yml |  19 ++++
 testsuites/sptests/spstkalloc03/init.c        | 103 ++++++++++++++++++
 .../sptests/spstkalloc03/spstkalloc03.doc     |  19 ++++
 .../sptests/spstkalloc03/spstkalloc03.scn     |   2 +
 testsuites/sptests/spstkalloc04/init.c        |  82 ++++++++++++++
 .../sptests/spstkalloc04/spstkalloc04.doc     |  20 ++++
 .../sptests/spstkalloc04/spstkalloc04.scn     |   2 +
 16 files changed, 404 insertions(+), 8 deletions(-)
 create mode 100644 cpukit/score/src/stackallocatorforidle.c
 create mode 100644 spec/build/testsuites/sptests/spstkalloc03.yml
 create mode 100644 spec/build/testsuites/sptests/spstkalloc04.yml
 create mode 100644 testsuites/sptests/spstkalloc03/init.c
 create mode 100644 testsuites/sptests/spstkalloc03/spstkalloc03.doc
 create mode 100644 testsuites/sptests/spstkalloc03/spstkalloc03.scn
 create mode 100644 testsuites/sptests/spstkalloc04/init.c
 create mode 100644 testsuites/sptests/spstkalloc04/spstkalloc04.doc
 create mode 100644 testsuites/sptests/spstkalloc04/spstkalloc04.scn
diff --git a/cpukit/include/rtems/confdefs/percpu.h b/cpukit/include/rtems/confdefs/percpu.h
index badb616988..3bea8340cb 100644
--- a/cpukit/include/rtems/confdefs/percpu.h
+++ b/cpukit/include/rtems/confdefs/percpu.h
@@ -134,11 +134,19 @@ RTEMS_DEFINE_GLOBAL_SYMBOL(
 const size_t _Thread_Idle_stack_size = CONFIGURE_IDLE_TASK_STACK_SIZE;
-char _Thread_Idle_stacks[
-  _CONFIGURE_MAXIMUM_PROCESSORS
-    * ( CONFIGURE_IDLE_TASK_STACK_SIZE + CPU_IDLE_TASK_IS_FP * CONTEXT_FP_SIZE )
-] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
-RTEMS_SECTION( ".rtemsstack.idle" );
+ * If the user provides a custom idle stack allocator, then we do not need
+ * memory reserved for the stacks but the symbol is still referenced in
+ * threadcreateidle.c. The code path just never uses it. Make it minimal
+ * size to proceed.
+#ifndef CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
+  char _Thread_Idle_stacks[
+    _CONFIGURE_MAXIMUM_PROCESSORS
+      * ( CONFIGURE_IDLE_TASK_STACK_SIZE + CPU_IDLE_TASK_IS_FP * CONTEXT_FP_SIZE )
+  ] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
+  RTEMS_SECTION( ".rtemsstack.idle" );
+#endif
 #if defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) && \
   !defined(CONFIGURE_IDLE_TASK_BODY)
diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
index 1db4f2d09d..82de8633bf 100644
--- a/cpukit/include/rtems/confdefs/wkspace.h
+++ b/cpukit/include/rtems/confdefs/wkspace.h
@@ -167,12 +167,14 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
   #pragma GCC diagnostic ignored "-Wpragmas"
   #pragma GCC diagnostic ignored "-Wtautological-pointer-compare"
+  /* Custom allocator may or may not use the work space. */
   #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
     const bool _Stack_Allocator_avoids_workspace = true;
   #else
     const bool _Stack_Allocator_avoids_workspace = false;
   #endif
+  /* Custom allocator may or may not need initialization. */
   #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_INIT
     const Stack_Allocator_initialize _Stack_Allocator_initialize =
       _CONFIGURE_ASSERT_NOT_NULL(
@@ -187,6 +189,7 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
   #endif
+  /* Custom allocator must include allocate and free */
   const Stack_Allocator_allocate _Stack_Allocator_allocate =
       Stack_Allocator_allocate,
@@ -200,11 +203,24 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
   #pragma GCC diagnostic pop
+ * Must provide both a custom stack allocator and deallocator
 #elif defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
   || defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
   #error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined"
 #endif
+ * Custom IDLE thread stacks allocator. If this is provided, it is assumed
+ * that the allocator is providing its own memory for these stacks.
+#ifdef CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
+  const Stack_Allocator_allocate_for_idle _Stack_Allocator_allocate_for_idle =
+    CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE;
+#endif
 #ifdef CONFIGURE_DIRTY_MEMORY
   RTEMS_SYSINIT_ITEM(
     _Memory_Dirty_free_areas,
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index afcee4381b..7b15bc34a2 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -368,6 +368,18 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
 #define rtems_configuration_get_stack_free_hook() _Stack_Allocator_free
+ * @ingroup RTEMSAPIConfig
+ * @brief Gets the IDLE thread stack allocator hook configured for this
+ *   application.
+ * @return Returns the IDLE thread stack allocator hook configured for this
+ *   application.
+#define rtems_configuration_get_stack_allocate_for_idle_hook() \
+  (_Stack_Allocator_allocate_for_idle)
 /* Generated from spec:/rtems/config/if/get-stack-space-size */
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index 23421cf7ae..ffa6368ba5 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -80,6 +80,23 @@ typedef void *( *Stack_Allocator_allocate )( size_t stack_size );
 typedef void ( *Stack_Allocator_free )( void *addr );
+ * @brief Stack allocator allocate for idle handler.
+ * The allocate for idle handler is optional even when the user thread stack
+ * allocator and deallocator are configured.
+ * @param cpu Index of the CPU for the IDLE thread using this stack
+ * @param stack_size The size of the stack area to allocate in bytes.
+ * @retval NULL Not enough memory.
+ * @retval other Pointer to begin of stack area.
+typedef void *( *Stack_Allocator_allocate_for_idle )(
+  uint32_t  cpu,
+  size_t    stack_size
  * @brief The minimum stack size.
@@ -130,6 +147,13 @@ extern const Stack_Allocator_free _Stack_Allocator_free;
 void _Stack_Allocator_do_initialize( void );
+ * @brief The stack allocator allocate stack for idle thread handler.
+ * Application provided via <rtems/confdefs.h>.
+extern const Stack_Allocator_allocate_for_idle
+  _Stack_Allocator_allocate_for_idle;
 #ifdef __cplusplus
diff --git a/cpukit/score/src/stackallocatorforidle.c b/cpukit/score/src/stackallocatorforidle.c
new file mode 100644
index 0000000000..7c4fd10c7d
--- /dev/null
+++ b/cpukit/score/src/stackallocatorforidle.c
@@ -0,0 +1,59 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2021 OAR Corporation
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/stack.h>
+#include <rtems/score/thread.h>
+ * @brief Default stack allocator allocate for idle handler.
+ * The default allocator for IDLE thread stacks gets the memory from a
+ * statically allocated area provided via confdefs.h.
+ * @retval NULL Not enough memory (never returned).
+static void *_Stack_Allocator_allocate_for_idle_default(
+  uint32_t  cpu,
+  size_t    stack_size
+  return &_Thread_Idle_stacks[ cpu * stack_size ];
+const Stack_Allocator_allocate_for_idle _Stack_Allocator_allocate_for_idle =
+        _Stack_Allocator_allocate_for_idle_default;
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index f5ffc9bad8..86e117e70f 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -49,9 +49,15 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
   config.is_preemptible = true;
   config.stack_size = _Thread_Idle_stack_size
     + CPU_IDLE_TASK_IS_FP * CONTEXT_FP_SIZE;
-  config.stack_area = &_Thread_Idle_stacks[
-    _Per_CPU_Get_index( cpu ) * config.stack_size
+   * The IDLE thread stacks may be statically allocated or there may be a
+   * custom allocator provided just as with user threads.
+  config.stack_area = (*_Stack_Allocator_allocate_for_idle)(
+    _Per_CPU_Get_index( cpu ),
+    config.stack_size
    *  The entire workspace is zeroed during its initialization.  Thus, all
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index c0f8f6d670..68f3d448cc 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1527,6 +1527,7 @@ source:
 - cpukit/score/src/semaphore.c
 - cpukit/score/src/smpbarrierwait.c
 - cpukit/score/src/stackallocator.c
+- cpukit/score/src/stackallocatorforidle.c
 - cpukit/score/src/stackallocatorfree.c
 - cpukit/score/src/stackallocatorinit.c
 - cpukit/score/src/thread.c
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index d3cd53fb4a..6b16c115ba 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -395,6 +395,10 @@ links:
   uid: spstkalloc
 - role: build-dependency
   uid: spstkalloc02
+- role: build-dependency
+  uid: spstkalloc03
+  uid: spstkalloc04
   uid: spsysinit01
diff --git a/spec/build/testsuites/sptests/spstkalloc03.yml b/spec/build/testsuites/sptests/spstkalloc03.yml
index 0000000000..fbdb91bd6f
--- /dev/null
+++ b/spec/build/testsuites/sptests/spstkalloc03.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2030 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spstkalloc03/init.c
+stlib: []
+target: testsuites/sptests/spstkalloc03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spstkalloc04.yml b/spec/build/testsuites/sptests/spstkalloc04.yml
index 0000000000..64340ed8f7
--- /dev/null
+++ b/spec/build/testsuites/sptests/spstkalloc04.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+- Copyright (C) 2040 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spstkalloc04/init.c
+stlib: []
+target: testsuites/sptests/spstkalloc04.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/spstkalloc03/init.c b/testsuites/sptests/spstkalloc03/init.c
index 0000000000..348afe7328
--- /dev/null
+++ b/testsuites/sptests/spstkalloc03/init.c
@@ -0,0 +1,103 @@
+ *  COPYRIGHT (c) 2021.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <rtems/score/percpu.h>
+const char rtems_test_name[] = "SPSTKALLOC 3";
+static int thread_stacks_count = 0xff;
+static rtems_task Init(
+  rtems_task_argument ignored
+  rtems_print_printer_fprintf_putc(&rtems_test_printer);
+  TEST_BEGIN();
+  rtems_test_assert(thread_stacks_count == 2);
+  TEST_END();
+  rtems_test_exit( 0 );
+static uint8_t stack_memory[RTEMS_MINIMUM_STACK_SIZE * 4];
+static int stack_offset_next;
+static void *allocate_helper(size_t size)
+  size_t  next;
+  void   *alloc;
+  next = stack_offset_next + size;
+  rtems_test_assert( next < sizeof(stack_memory) );
+  alloc = &stack_memory[stack_offset_next];
+  stack_offset_next = next;
+  return alloc;
+static void thread_stacks_initialize(size_t stack_space_size)
+  rtems_test_assert(thread_stacks_count == 0xff);
+  thread_stacks_count = 0;
+static void *thread_stacks_allocate(size_t stack_size)
+  rtems_test_assert(thread_stacks_count == 1);
+  thread_stacks_count++;
+  return allocate_helper(stack_size);
+static void thread_stacks_free(void *addr)
+  rtems_test_assert(false);
+static void *thread_stacks_allocate_for_idle(
+  uint32_t  cpu,
+  size_t    stack_size
+  rtems_test_assert(thread_stacks_count == 0);
+ * Configure the thread stack allocators to not use the workspace. This should
+ * eliminate all uses of the Workspace for most BSPs.
+#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
+#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT thread_stacks_initialize
+#define CONFIGURE_TASK_STACK_ALLOCATOR      thread_stacks_allocate
+#define CONFIGURE_TASK_STACK_DEALLOCATOR    thread_stacks_free
+#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE thread_stacks_allocate_for_idle
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spstkalloc03/spstkalloc03.doc b/testsuites/sptests/spstkalloc03/spstkalloc03.doc
index 0000000000..797716b623
--- /dev/null
+++ b/testsuites/sptests/spstkalloc03/spstkalloc03.doc
@@ -0,0 +1,19 @@
+#  COPYRIGHT (c) 2021.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name:  spstkalloc03
+directives:
+concepts:
++ Ensure that the task stack allocator including IDLE thread
+  stack allocator works.
diff --git a/testsuites/sptests/spstkalloc03/spstkalloc03.scn b/testsuites/sptests/spstkalloc03/spstkalloc03.scn
index 0000000000..45c67ef1fb
--- /dev/null
+++ b/testsuites/sptests/spstkalloc03/spstkalloc03.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPSTKALLOC 3 ***
+*** END OF TEST SPSTKALLOC 3 ***
diff --git a/testsuites/sptests/spstkalloc04/init.c b/testsuites/sptests/spstkalloc04/init.c
index 0000000000..16f4ec65ca
--- /dev/null
+++ b/testsuites/sptests/spstkalloc04/init.c
@@ -0,0 +1,82 @@
+#endif
+#include <rtems.h>
+const char rtems_test_name[] = "SPSTKALLOC 4";
+static int thread_stacks_count = 0;
+  TEST_BEGIN();
+  TEST_END();
+  size_t  next;
+  void   *alloc;
+  return alloc;
+  uint32_t  cpu,
+  size_t    stack_size
+ * Configure the IDLE thread stack allocators. This is a special
+ * case where there is an IDLE thread stack allocator but no custom
+ * allocator set for other threads.
diff --git a/testsuites/sptests/spstkalloc04/spstkalloc04.doc b/testsuites/sptests/spstkalloc04/spstkalloc04.doc
index 0000000000..a1ed5b22cb
--- /dev/null
+++ b/testsuites/sptests/spstkalloc04/spstkalloc04.doc
@@ -0,0 +1,20 @@
+test set name:  spstkalloc04
+directives:
+concepts:
+  stack allocator works when a custom allocator is NOT provided
+  for other threads.
diff --git a/testsuites/sptests/spstkalloc04/spstkalloc04.scn b/testsuites/sptests/spstkalloc04/spstkalloc04.scn
index 0000000000..f0919ec2d4
--- /dev/null
+++ b/testsuites/sptests/spstkalloc04/spstkalloc04.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPSTKALLOC 4 ***
+*** END OF TEST SPSTKALLOC 4 ***
2.24.4
