[PATCH 2/7] score: Remove TOD_TICKS_PER_SECOND_method()
Fri Sep 3 13:33:19 UTC 2021
Use _Watchdog_Ticks_per_second instead.
 cpukit/Makefile.am                    |  1 -
 cpukit/include/rtems/score/todimpl.h  | 20 ++----------------
 cpukit/score/src/coretodtickspersec.c | 30 ---------------------------
 spec/build/cpukit/librtemscpu.yml     |  1 -
 4 files changed, 2 insertions(+), 50 deletions(-)
 delete mode 100644 cpukit/score/src/coretodtickspersec.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 1afac8f7dc..cc6bd48a9b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1004,7 +1004,6 @@ librtemscpu_a_SOURCES += score/src/timespecdividebyinteger.c
 librtemscpu_a_SOURCES += score/src/timespecgetasnanoseconds.c
 librtemscpu_a_SOURCES += score/src/coretod.c
 librtemscpu_a_SOURCES += score/src/coretodset.c
-librtemscpu_a_SOURCES += score/src/coretodtickspersec.c
 librtemscpu_a_SOURCES += score/src/coretodadjust.c
 librtemscpu_a_SOURCES += score/src/watchdoginsert.c
 librtemscpu_a_SOURCES += score/src/coretodhookdata.c
diff --git a/cpukit/include/rtems/score/todimpl.h b/cpukit/include/rtems/score/todimpl.h
index 02a7fb1092..5346f12e53 100644
--- a/cpukit/include/rtems/score/todimpl.h
+++ b/cpukit/include/rtems/score/todimpl.h
@@ -24,6 +24,7 @@
 #include <rtems/score/timestamp.h>
 #include <rtems/score/timecounterimpl.h>
+#include <rtems/score/watchdogticks.h>
 #include <sys/time.h>
 #include <time.h>
@@ -295,27 +296,10 @@ static inline uint32_t _TOD_Seconds_since_epoch( void )
   return (uint32_t) _Timecounter_Time_second;
- * @brief Gets number of ticks in a second.
- * This method returns the number of ticks in a second.
- * @note If the clock tick value does not multiply evenly into a second
- *       then this number of ticks will be slightly shorter than a second.
- * @return The number of ticks in a second.
-uint32_t TOD_TICKS_PER_SECOND_method(void);
- *  This method exists to hide the fact that TOD_TICKS_PER_SECOND can not
- *  be implemented as a macro in a .h file due to visibility issues.
- *  The Configuration Table is not available to SuperCore .h files but
- *  is available to their .c files.
-#define TOD_TICKS_PER_SECOND TOD_TICKS_PER_SECOND_method()
+#define TOD_TICKS_PER_SECOND _Watchdog_Ticks_per_second
  * @brief This routine returns a timeval based upon the internal timespec
diff --git a/cpukit/score/src/coretodtickspersec.c b/cpukit/score/src/coretodtickspersec.c
deleted file mode 100644
index f4860975bc..0000000000
--- a/cpukit/score/src/coretodtickspersec.c
+++ /dev/null
@@ -1,30 +0,0 @@
- * @file
- * @ingroup RTEMSScoreTOD
- * @brief This source file contains the implementation of
- *   TOD_TICKS_PER_SECOND_method().
-/*  COPYRIGHT (c) 1989-2014.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/todimpl.h>
-#include <rtems/config.h>
-  return (TOD_MICROSECONDS_PER_SECOND /
-      rtems_configuration_get_microseconds_per_tick());
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 48266d408b..80fba92483 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1395,7 +1395,6 @@ source:
 - cpukit/score/src/coretodhookrun.c
 - cpukit/score/src/coretodhookunregister.c
 - cpukit/score/src/coretodset.c
-- cpukit/score/src/coretodtickspersec.c
 - cpukit/score/src/debugisthreaddispatchingallowed.c
 - cpukit/score/src/freechain.c
 - cpukit/score/src/futex.c
2.26.2
