[PATCH] rtems: Generate <rtems/rtems/cache.h>
Wed Sep 8 17:58:46 UTC 2021
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
 cpukit/include/rtems/rtems/cache.h | 688 ++++++++++++++++++++++-------
 1 file changed, 532 insertions(+), 156 deletions(-)
diff --git a/cpukit/include/rtems/rtems/cache.h b/cpukit/include/rtems/rtems/cache.h
index dfcb8f64d1..843d1ef99a 100644
--- a/cpukit/include/rtems/rtems/cache.h
+++ b/cpukit/include/rtems/rtems/cache.h
@@ -1,294 +1,670 @@
  * @file
- * @ingroup ClassicCache
+ * @brief This header file defines the Cache Manager API.
+ * Copyright (C) 2016 Pavel Pisa
+ * Copyright (C) 2014, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2000, 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
-/* COPYRIGHT (c) 1989-2013.
- * On-Line Applications Research Corporation (OAR).
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+/* Generated from spec:/rtems/cache/if/header */
 #ifndef _RTEMS_RTEMS_CACHE_H
 #define _RTEMS_RTEMS_CACHE_H
-#include <rtems/score/basedefs.h>
-#if defined( RTEMS_SMP )
-#include <sys/cpuset.h>
-#endif
+#include <stddef.h>
+#include <stdint.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
+/* Generated from spec:/rtems/cache/if/group */
- * @defgroup ClassicCache Cache
+ * @defgroup RTEMSAPIClassicCache Cache Manager
  * @ingroup RTEMSAPIClassic
  * @brief The Cache Manager provides functions to perform maintenance
- * operations for data and instruction caches.
+ *   operations for data and instruction caches.
  * The actual actions of the Cache Manager operations depend on the hardware
  * and the implementation provided by the CPU architecture port or a board
  * support package.  Cache implementations tend to be highly hardware
  * dependent.
+/* Generated from spec:/rtems/cache/if/aligned-malloc */
- * @brief Returns the data cache line size in bytes.
+ * @ingroup RTEMSAPIClassicCache
- * For multi-level caches this is the maximum of the cache line sizes of all
- * levels.
+ * @brief Allocates memory from the C Program Heap which begins at a cache line
+ *   boundary.
- * @retval 0 No data cache is present.
- * @retval positive The data cache line size in bytes.
-size_t rtems_cache_get_data_line_size( void );
- * @brief Returns the instruction cache line size in bytes.
+ * @param size is the size in bytes of the memory area to allocate.
+ * @retval NULL There is not enough memory available to satisfy the allocation
+ *   request.
+ * @return Returns the begin address of the allocated memory.  The begin
+ *   address is on a cache line boundary.
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
- * levels.
+ * * The directive may be called from within device driver initialization
+ *   context.
- * @retval 0 No instruction cache is present.
- * @retval positive The instruction cache line size in bytes.
+ * * The directive may be called from within task context.
+ * * The directive may obtain and release the object allocator mutex.  This may
+ *   cause the calling task to be preempted.
+ * @endparblock
-size_t rtems_cache_get_instruction_line_size( void );
+void *rtems_cache_aligned_malloc( size_t size );
+/* Generated from spec:/rtems/cache/if/coherent-add-area */
- * @brief Returns the maximal cache line size of all cache kinds in bytes.
- * Returns computed or obtained maximal cache line size of all
- * all caches in the system.
+ * @brief Adds a cache coherent memory area to the cache coherent allocator.
+ * @param begin is the begin address of the cache coherent memory area to add.
+ * @param size is the size in bytes of the cache coherent memory area to add.
+ * @parblock
- * @retval 0 No cache is present
- * @retval positive The maximal cache line size in bytes.
+ *   context.
+ * @endparblock
-size_t rtems_cache_get_maximal_line_size( void );
+void rtems_cache_coherent_add_area( void *begin, uintptr_t size );
+/* Generated from spec:/rtems/cache/if/coherent-allocate */
- * @brief Returns the data cache size in bytes.
+ * @brief Allocates a memory area from cache coherent memory.
+ * @param size is the requested size in bytes of the memory area to allocate.
+ * @param alignment is the requested alignment in bytes of the memory area to
+ *   allocate.  If the alignment parameter is not equal to zero, the allocated
+ *   memory area will begin at an address aligned by this value.
+ * @param boundary is the requested boundary in bytes of the memory area to
+ *   allocate.  If the boundary parameter is not equal to zero, the allocated
+ *   memory area will comply with a boundary constraint.  The boundary value
+ *   specifies the set of addresses which are aligned by the boundary value.
+ *   The interior of the allocated memory area will not contain an element of
+ *   this set.  The begin or end address of the area may be a member of the
+ *   set.
+ *   request.
+ * @par Notes
+ * @parblock
+ * A size value of zero will return a unique address which may be freed with
+ * rtems_cache_coherent_free().
+ * The memory allocated by the directive may be released with a call to
+ * By default the C Program Heap allocator is used.  In case special memory
+ * areas must be used, then the BSP or the application should add cache
+ * coherent memory areas for the allocator via rtems_cache_coherent_add_area().
+ * @endparblock
+ * @parblock
- * @param[in] level The cache level of interest.  The cache level zero
- * specifies the entire data cache.
+ *   context.
- * @returns The data cache size in bytes of the specified level.
+ * @endparblock
-size_t rtems_cache_get_data_cache_size( uint32_t level );
+void *rtems_cache_coherent_allocate(
+  size_t    size,
+  uintptr_t alignment,
+  uintptr_t boundary
+/* Generated from spec:/rtems/cache/if/coherent-free */
- * @brief Returns the instruction cache size in bytes.
- * specifies the entire instruction cache.
+ * @brief Frees memory allocated by rtems_cache_coherent_allocate().
+ * @param ptr is a pointer returned by rtems_cache_coherent_allocate().
+ * @parblock
+ *   context.
- * @returns The instruction cache size in bytes of the specified level.
+ * @endparblock
-size_t rtems_cache_get_instruction_cache_size( uint32_t level );
+void rtems_cache_coherent_free( void *ptr );
+/* Generated from spec:/rtems/cache/if/disable-data */
- * @brief Flushes multiple data cache lines.
+ * @brief Disables the data cache.
- * Dirty cache lines covering the area are transfered to memory.  Depending on
- * the cache implementation this may mark the lines as invalid.
+ * @parblock
- * @param[in] addr The start address of the area to flush.
- * @param[in] size The size in bytes of the area to flush.
+ * * The directive may be called from within any runtime context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
-void rtems_cache_flush_multiple_data_lines( const void *addr, size_t size );
+void rtems_cache_disable_data( void );
+/* Generated from spec:/rtems/cache/if/disable-instruction */
- * @brief Invalidates multiple data cache lines.
- * The cache lines covering the area are marked as invalid.  A later read
- * access in the area will load the data from memory.
+ * @brief Disables the instruction cache.
- * In case the area is not aligned on cache line boundaries, then this
- * operation may destroy unrelated data.
+ * @parblock
- * @param[in] addr The start address of the area to invalidate.
- * @param[in] size The size in bytes of the area to invalidate.
+ * @endparblock
-void rtems_cache_invalidate_multiple_data_lines(
-  const void *addr,
-  size_t size
+void rtems_cache_disable_instruction( void );
+/* Generated from spec:/rtems/cache/if/enable-data */
- * @brief Invalidates multiple instruction cache lines.
- * instruction fetch from the area will result in a load from memory.
- * In SMP mode, on processors without instruction cache snooping, this
- * operation will invalidate the instruction cache lines on all processors.
- * It should not be called from interrupt context in such case.
+ * @brief Enables the data cache.
+ * @parblock
+ * @endparblock
-void rtems_cache_invalidate_multiple_instruction_lines(
-  const void *addr,
-  size_t size
+void rtems_cache_enable_data( void );
+/* Generated from spec:/rtems/cache/if/enable-instruction */
- * @brief Ensure necessary synchronization required after code changes
- * When code is loaded or modified then many Harvard cache equipped
- * systems require synchronization of main memory and or updated
- * code in data cache to ensure visibility of change in all
- * connected CPUs instruction memory view. This operation
- * should be used by run time loader for example.
+ * @brief Enables the instruction cache.
+ * @parblock
+ * @endparblock
-void rtems_cache_instruction_sync_after_code_change(
-  const void * code_addr,
-  size_t n_bytes
+void rtems_cache_enable_instruction( void );
+/* Generated from spec:/rtems/cache/if/flush-entire-data */
  * @brief Flushes the entire data cache.
- * @see rtems_cache_flush_multiple_data_lines().
+ * @parblock
+ * @endparblock
 void rtems_cache_flush_entire_data( void );
+/* Generated from spec:/rtems/cache/if/flush-multiple-data-lines */
- * @brief Invalidates the entire instruction cache.
+ * @brief Flushes the data cache lines covering the memory area.
+ * @param begin is the begin address of the memory area to flush.
+ * @param size is the size in bytes of the memory area to flush.
- * @see rtems_cache_invalidate_multiple_instruction_lines().
+ * Dirty data cache lines covering the area are transfered to memory.
+ * Depending on the cache implementation this may mark the lines as invalid.
+ * @parblock
+ * @endparblock
-void rtems_cache_invalidate_entire_instruction( void );
+void rtems_cache_flush_multiple_data_lines( const void *begin, size_t size );
+/* Generated from spec:/rtems/cache/if/freeze-data */
- * This function is responsible for performing a data cache
- * invalidate. It invalidates the entire cache.
+ * @brief Freezes the data caches.
+ * @parblock
+ * @endparblock
-void rtems_cache_invalidate_entire_data( void );
+void rtems_cache_freeze_data( void );
+/* Generated from spec:/rtems/cache/if/freeze-instruction */
- * This function freezes the data cache.
+ * @brief Freezes the instruction caches.
+ * @parblock
+ * @endparblock
-void rtems_cache_freeze_data( void );
+void rtems_cache_freeze_instruction( void );
+/* Generated from spec:/rtems/cache/if/get-data-line-size */
- * This function unfreezes the data cache.
+ * @brief Gets the data cache line size in bytes.
+ * @retval 0 There is no data cache present.
+ * @return Returns the data cache line size in bytes.  For multi-level caches
+ *   this is the maximum of the cache line sizes of all levels.
+ * @parblock
+ * @endparblock
-void rtems_cache_unfreeze_data( void );
+size_t rtems_cache_get_data_line_size( void );
+/* Generated from spec:/rtems/cache/if/get-data-size */
- * This function enables the data cache.
+ * @brief Gets the data cache size in bytes for the cache level.
+ * @param level is the requested data cache level.  The cache level zero
+ *   specifies the entire data cache.
+ * @retval 0 There is no data cache present at the requested cache level.
+ * @return Returns the data cache size in bytes of the requested cache level.
+ * @parblock
+ * @endparblock
-void rtems_cache_enable_data( void );
+size_t rtems_cache_get_data_cache_size( uint32_t level );
+/* Generated from spec:/rtems/cache/if/get-instruction-line-size */
- * This function disables the data cache.
+ * @brief Gets the instruction cache line size in bytes.
+ * @retval 0 There is no instruction cache present.
+ * @return Returns the instruction cache line size in bytes.  For multi-level
+ *   caches this is the maximum of the cache line sizes of all levels.
+ * @parblock
+ * @endparblock
-void rtems_cache_disable_data( void );
+size_t rtems_cache_get_instruction_line_size( void );
+/* Generated from spec:/rtems/cache/if/get-instruction-size */
- * This function freezes the instruction cache.
+ * @brief Gets the instruction cache size in bytes for the cache level.
+ * @param level is the requested instruction cache level.  The cache level zero
+ *   specifies the entire instruction cache.
+ * @retval 0 There is no instruction cache present at the requested cache
+ *   level.
+ * @return Returns the instruction cache size in bytes of the requested cache
+ *   level.
+ * @parblock
+ * @endparblock
-void rtems_cache_freeze_instruction( void );
+size_t rtems_cache_get_instruction_cache_size( uint32_t level );
+/* Generated from spec:/rtems/cache/if/get-maximal-line-size */
- * This function unfreezes the instruction cache.
+ * @brief Gets the maximal cache line size in bytes of all caches (data,
+ *   instruction, or unified).
+ * @retval 0 There is no cache present.
+ * @return Returns the maximal cache line size in bytes of all caches (data,
+ * @parblock
+ * @endparblock
-void rtems_cache_unfreeze_instruction( void );
+size_t rtems_cache_get_maximal_line_size( void );
+/* Generated from spec:/rtems/cache/if/instruction-sync-after-code-change */
- * This function enables the instruction cache.
+ * @brief Ensures necessary synchronization required after code changes.
+ * @param begin is the begin address of the code area to synchronize.
+ * @param size is the size in bytes of the code area to synchronize.
+ * @par Notes
+ * When code is loaded or modified, then most systems require synchronization
+ * instructions to update the instruction caches so that the loaded or modified
+ * code is fetched.  For example, systems with separate data and instruction
+ * caches or systems without instruction cache snooping.  The directives should
+ * be used by run time loader for example.
+ * @parblock
+ * @endparblock
-void rtems_cache_enable_instruction( void );
+void rtems_cache_instruction_sync_after_code_change(
+  const void *begin,
+  size_t      size
+/* Generated from spec:/rtems/cache/if/invalidate-entire-data */
- * This function disables the instruction cache.
+ * @brief Invalidates the entire data cache.
+ * @parblock
+ * @endparblock
-void rtems_cache_disable_instruction( void );
+void rtems_cache_invalidate_entire_data( void );
+/* Generated from spec:/rtems/cache/if/invalidate-entire-instruction */
- *  This function is used to allocate storage that spans an
- *  integral number of cache blocks.
+ * @brief Invalidates the entire instruction cache.
+ * @parblock
+ * @endparblock
-void *rtems_cache_aligned_malloc ( size_t nbytes );
+void rtems_cache_invalidate_entire_instruction( void );
+/* Generated from spec:/rtems/cache/if/invalidate-multiple-data-lines */
- * @brief Allocates a memory area of size @a size bytes from cache coherent
- * memory.
- * A size value of zero will return a unique address which may be freed with
- * rtems_cache_coherent_free().
+ * @brief Invalidates the data cache lines covering the memory area.
- * The memory allocated by this function can be released with a call to
+ * @param begin is the begin address of the memory area to invalidate.
+ * @param size is the size in bytes of the memory area to invalidate.
+ * The cache lines covering the area are marked as invalid.  A later read
+ * access in the area will load the data from memory.
- * By default the C program heap allocator is used.  In case special memory
- * areas must be used, then the BSP or the application must add cache coherent
- * memory areas for the allocator via rtems_cache_coherent_add_area().
+ * @par Notes
+ * @parblock
+ * In case the area is not aligned on cache line boundaries, then this
+ * operation may destroy unrelated data.
- * This function must be called from driver initialization or task context
- * only.
+ * On some systems, the cache lines may be flushed before they are invalidated.
+ * @endparblock
- * @param[in] alignment If the alignment parameter is not equal to zero, the
- *   allocated memory area will begin at an address aligned by this value.
- * @param[in] boundary If the boundary parameter is not equal to zero, the
- *   allocated memory area will comply with a boundary constraint.  The
- *   boundary value specifies the set of addresses which are aligned by the
- *   boundary value.  The interior of the allocated memory area will not
- *   contain an element of this set.  The begin or end address of the area may
- *   be a member of the set.
+ * @parblock
- * @retval NULL If no memory is available or the parameters are inconsistent.
- * @retval other A pointer to the begin of the allocated memory area.
+ * @endparblock
-void *rtems_cache_coherent_allocate(
-  size_t size,
-  uintptr_t alignment,
-  uintptr_t boundary
+void rtems_cache_invalidate_multiple_data_lines(
+  size_t      size
+/* Generated from spec:/rtems/cache/if/invalidate-multiple-instruction-lines */
- * @brief Frees memory allocated by rtems_cache_coherent_allocate().
+ * @brief Invalidates the instruction cache lines covering the memory area.
+ * instruction fetch from the area will result in a load from memory.
+ * @par Notes
+ * In SMP configurations, on processors without instruction cache snooping,
+ * this operation will invalidate the instruction cache lines on all
+ * processors.
- * only.
+ * @parblock
- * @param[in] ptr A pointer returned by rtems_cache_coherent_allocate().
+ * @endparblock
-void rtems_cache_coherent_free( void *ptr );
+void rtems_cache_invalidate_multiple_instruction_lines(
+  size_t      size
+/* Generated from spec:/rtems/cache/if/unfreeze-data */
- * @brief Adds a cache coherent memory area to the cache coherent allocator.
+ * @brief Unfreezes the data cache.
- * This function must be called from BSP initialization, driver initialization
- * or task context only.
+ * @parblock
- * @param[in] area_begin The area begin address.
- * @param[in] area_size The area size in bytes.
- * @see rtems_cache_coherent_allocate().
+ * @endparblock
-void rtems_cache_coherent_add_area(
-  void *area_begin,
-  uintptr_t area_size
+void rtems_cache_unfreeze_data( void );
+/* Generated from spec:/rtems/cache/if/unfreeze-instruction */
+ * @brief Unfreezes the instruction cache.
+ * @parblock
+ * @endparblock
+void rtems_cache_unfreeze_instruction( void );
 #ifdef __cplusplus
 #endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_RTEMS_CACHE_H */
2.31.1
