RSB
Mon Sep 13 23:54:42 UTC 2021
On 13/9/21 11:20 pm, Joel Sherrill wrote:
> Hi
> If building a bset tar file, does it matter if the installation prefix
> is writable?
> ../source-builder/sb-set-builder --bset-tar-file --log=l-i386.txt
> --prefix=/rtems/tools 5/rtems-i386
> RTEMS Source Builder - Set Builder, 5 (c7870f6e6199)
> error: prefix is not writable: /rtems/tools
> It does if you are planning to immediately install but if building for
> later installation, I don't think it matters.
> Thoughts?
What happens if you add --no-install?
If this does help the question moves to if making a bset is packaging around an
install or is it the only output option?
