[PATCH rtems] bsps/imxrt: Add attribution in file headers
Christian MAUDERER christian.mauderer at embedded-brains.de
Mon Sep 27 08:17:02 UTC 2021
Hello,
if I didn't miss a documentation patch regarding this, the topic is
still open. I delayed it a bit because I didn't had the time back then
and I think Chris was quite busy too at that time. I hope now is the
right time to re-start the discussion.
Am 21.07.21 um 08:58 schrieb Chris Johns:
> On 21/7/21 3:51 pm, Sebastian Huber wrote:
>> On 21/07/2021 02:46, Chris Johns wrote:
>>> I think we need some guidelines. I do not agree with URL links, email addresses,
>>> phone numbers or street addreses appearing in the source. I also think a sponsor
>>> acknowledgement is never updated or changed even if a company changes name. What
>>> I am not sure about is the areas of the source we allow this to happen in, ie
>>> score ...?
>> We could add some text here:
>> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html
> Yes. I will consider this and post an initial approach we can discuss in detail.
> Chris
Chris: I think you already mentioned the most relevant rules in your
post above. Do you want to create a draft for a documentation patch or
should I try to write something?
Best regards
Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
