[PATCH 04/39] testsuites/ada/sptests/sp1*: Change license to BSD-2
Fri Apr 8 14:45:32 UTC 2022
Updates #3053.
 testsuites/ada/sptests/sp11/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp11/sp11.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp11/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp11/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp12/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp12/sp12.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp12/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp12/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp13/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp13/sp13.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp13/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp13/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp14/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp14/sp14.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp14/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp14/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp15/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp15/sp15.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp15/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp15/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp16/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp16/sp16.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp16/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp16/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp17/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp17/sp17.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp17/sptest.adb | 25 ++++++++++++--
 testsuites/ada/sptests/sp17/sptest.ads | 25 ++++++++++++--
 testsuites/ada/sptests/sp19/init.c     | 25 ++++++++++++--
 testsuites/ada/sptests/sp19/sp19.adb   | 25 ++++++++++++--
 testsuites/ada/sptests/sp19/sptest.adb | 48 ++++++++++++++++++++++----
 testsuites/ada/sptests/sp19/sptest.ads | 25 ++++++++++++--
 32 files changed, 724 insertions(+), 99 deletions(-)
diff --git a/testsuites/ada/sptests/sp11/init.c b/testsuites/ada/sptests/sp11/init.c
index edd86bc77e..9f5ddd9132 100644
--- a/testsuites/ada/sptests/sp11/init.c
+++ b/testsuites/ada/sptests/sp11/init.c
@@ -1,3 +1,5 @@
 /*  config.h
  *  This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-2007.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
diff --git a/testsuites/ada/sptests/sp11/sp11.adb b/testsuites/ada/sptests/sp11/sp11.adb
index b39fd4b2be..e0d22c07a7 100644
--- a/testsuites/ada/sptests/sp11/sp11.adb
+++ b/testsuites/ada/sptests/sp11/sp11.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
 --  MAIN / BODY
@@ -12,9 +14,26 @@
 --  COPYRIGHT (c) 1989-2011.
 --  On-Line Applications Research Corporation (OAR).
---  The license and distribution terms for this file may in
---  the file LICENSE in this distribution or at
---  http://www.rtems.org/license/LICENSE.
+--  Redistribution and use in source and binary forms, with or without
+--  modification, are permitted provided that the following conditions
+--  are met:
+--  1. Redistributions of source code must retain the above copyright
+--     notice, this list of conditions and the following disclaimer.
+--  2. Redistributions in binary form must reproduce the above copyright
+--     notice, this list of conditions and the following disclaimer in the
+--     documentation and/or other materials provided with the distribution.
+--  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+--  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+--  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+--  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+--  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+--  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+--  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+--  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+--  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+--  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+--  POSSIBILITY OF SUCH DAMAGE.
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp11/sptest.adb b/testsuites/ada/sptests/sp11/sptest.adb
index fa6e139367..18782675d8 100644
--- a/testsuites/ada/sptests/sp11/sptest.adb
+++ b/testsuites/ada/sptests/sp11/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/sptests/sp11/sptest.ads b/testsuites/ada/sptests/sp11/sptest.ads
index b7f03b8f4c..3cbce1bbf2 100644
--- a/testsuites/ada/sptests/sp11/sptest.ads
+++ b/testsuites/ada/sptests/sp11/sptest.ads
@@ -1,3 +1,5 @@
 --  SPTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp12/init.c b/testsuites/ada/sptests/sp12/init.c
index 4dc8aad2b4..3537e9a8b1 100644
--- a/testsuites/ada/sptests/sp12/init.c
+++ b/testsuites/ada/sptests/sp12/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp12/sp12.adb b/testsuites/ada/sptests/sp12/sp12.adb
index 08a39a869b..ec75d0c98d 100644
--- a/testsuites/ada/sptests/sp12/sp12.adb
+++ b/testsuites/ada/sptests/sp12/sp12.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with Interfaces; use Interfaces;
diff --git a/testsuites/ada/sptests/sp12/sptest.adb b/testsuites/ada/sptests/sp12/sptest.adb
index a1391ab01d..b9826528a3 100644
--- a/testsuites/ada/sptests/sp12/sptest.adb
+++ b/testsuites/ada/sptests/sp12/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
diff --git a/testsuites/ada/sptests/sp12/sptest.ads b/testsuites/ada/sptests/sp12/sptest.ads
index 663faa7686..d7c275544c 100644
--- a/testsuites/ada/sptests/sp12/sptest.ads
+++ b/testsuites/ada/sptests/sp12/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp13/init.c b/testsuites/ada/sptests/sp13/init.c
index 13f9fc2c0f..66de03187f 100644
--- a/testsuites/ada/sptests/sp13/init.c
+++ b/testsuites/ada/sptests/sp13/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp13/sp13.adb b/testsuites/ada/sptests/sp13/sp13.adb
index 503e8fb989..8904d568c2 100644
--- a/testsuites/ada/sptests/sp13/sp13.adb
+++ b/testsuites/ada/sptests/sp13/sp13.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp13/sptest.adb b/testsuites/ada/sptests/sp13/sptest.adb
index 7621af6252..7b73c5caca 100644
--- a/testsuites/ada/sptests/sp13/sptest.adb
+++ b/testsuites/ada/sptests/sp13/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
diff --git a/testsuites/ada/sptests/sp13/sptest.ads b/testsuites/ada/sptests/sp13/sptest.ads
index 9b92b3ba61..938ef1f2c5 100644
--- a/testsuites/ada/sptests/sp13/sptest.ads
+++ b/testsuites/ada/sptests/sp13/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp14/init.c b/testsuites/ada/sptests/sp14/init.c
index 076e3d9763..4ecb75378c 100644
--- a/testsuites/ada/sptests/sp14/init.c
+++ b/testsuites/ada/sptests/sp14/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp14/sp14.adb b/testsuites/ada/sptests/sp14/sp14.adb
index 2149694ecc..4426637396 100644
--- a/testsuites/ada/sptests/sp14/sp14.adb
+++ b/testsuites/ada/sptests/sp14/sp14.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp14/sptest.adb b/testsuites/ada/sptests/sp14/sptest.adb
index 15239e30b4..92c9c74384 100644
--- a/testsuites/ada/sptests/sp14/sptest.adb
+++ b/testsuites/ada/sptests/sp14/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with ADDRESS_IO;
diff --git a/testsuites/ada/sptests/sp14/sptest.ads b/testsuites/ada/sptests/sp14/sptest.ads
index ecf6f93dff..95abe5fb8b 100644
--- a/testsuites/ada/sptests/sp14/sptest.ads
+++ b/testsuites/ada/sptests/sp14/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp15/init.c b/testsuites/ada/sptests/sp15/init.c
index 6b1b1f323b..b5d1670b24 100644
--- a/testsuites/ada/sptests/sp15/init.c
+++ b/testsuites/ada/sptests/sp15/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp15/sp15.adb b/testsuites/ada/sptests/sp15/sp15.adb
index 77e8f27144..54b19b466d 100644
--- a/testsuites/ada/sptests/sp15/sp15.adb
+++ b/testsuites/ada/sptests/sp15/sp15.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp15/sptest.adb b/testsuites/ada/sptests/sp15/sptest.adb
index 8f83defedf..b9c8cd3781 100644
--- a/testsuites/ada/sptests/sp15/sptest.adb
+++ b/testsuites/ada/sptests/sp15/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with TEST_SUPPORT;
diff --git a/testsuites/ada/sptests/sp15/sptest.ads b/testsuites/ada/sptests/sp15/sptest.ads
index 5af0e61503..17b3066580 100644
--- a/testsuites/ada/sptests/sp15/sptest.ads
+++ b/testsuites/ada/sptests/sp15/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp16/init.c b/testsuites/ada/sptests/sp16/init.c
index c0a75da20e..09c46169d8 100644
--- a/testsuites/ada/sptests/sp16/init.c
+++ b/testsuites/ada/sptests/sp16/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp16/sp16.adb b/testsuites/ada/sptests/sp16/sp16.adb
index 4280c67665..2906cf4e30 100644
--- a/testsuites/ada/sptests/sp16/sp16.adb
+++ b/testsuites/ada/sptests/sp16/sp16.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp16/sptest.adb b/testsuites/ada/sptests/sp16/sptest.adb
index 44d65badfc..71df0fe457 100644
--- a/testsuites/ada/sptests/sp16/sptest.adb
+++ b/testsuites/ada/sptests/sp16/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
diff --git a/testsuites/ada/sptests/sp16/sptest.ads b/testsuites/ada/sptests/sp16/sptest.ads
index 7f028a0274..8c8e0719b9 100644
--- a/testsuites/ada/sptests/sp16/sptest.ads
+++ b/testsuites/ada/sptests/sp16/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp17/init.c b/testsuites/ada/sptests/sp17/init.c
index 7dfd620d77..e66e750d0a 100644
--- a/testsuites/ada/sptests/sp17/init.c
+++ b/testsuites/ada/sptests/sp17/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp17/sp17.adb b/testsuites/ada/sptests/sp17/sp17.adb
index 5c06ef0b44..4b8f5a3d9d 100644
--- a/testsuites/ada/sptests/sp17/sp17.adb
+++ b/testsuites/ada/sptests/sp17/sp17.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp17/sptest.adb b/testsuites/ada/sptests/sp17/sptest.adb
index 880f5db4a7..1b0cfcc8bf 100644
--- a/testsuites/ada/sptests/sp17/sptest.adb
+++ b/testsuites/ada/sptests/sp17/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
diff --git a/testsuites/ada/sptests/sp17/sptest.ads b/testsuites/ada/sptests/sp17/sptest.ads
index 428114c9a0..f691507e8e 100644
--- a/testsuites/ada/sptests/sp17/sptest.ads
+++ b/testsuites/ada/sptests/sp17/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp19/init.c b/testsuites/ada/sptests/sp19/init.c
index 2d0d5b39f2..907a9134b9 100644
--- a/testsuites/ada/sptests/sp19/init.c
+++ b/testsuites/ada/sptests/sp19/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp19/sp19.adb b/testsuites/ada/sptests/sp19/sp19.adb
index f2cfddb97a..91f76cf7c5 100644
--- a/testsuites/ada/sptests/sp19/sp19.adb
+++ b/testsuites/ada/sptests/sp19/sp19.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp19/sptest.adb b/testsuites/ada/sptests/sp19/sptest.adb
index 7e508512bd..082438f77f 100644
--- a/testsuites/ada/sptests/sp19/sptest.adb
+++ b/testsuites/ada/sptests/sp19/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -38,9 +40,26 @@ with RTEMS.CLOCK;
 --  COPYRIGHT (c) 1989-1997.
+--  are met:
 -- private definitions for macro use
@@ -73,9 +92,26 @@ with RTEMS.CLOCK;
+--  are met:
diff --git a/testsuites/ada/sptests/sp19/sptest.ads b/testsuites/ada/sptests/sp19/sptest.ads
index 3befd7cc3a..0220e4b19d 100644
--- a/testsuites/ada/sptests/sp19/sptest.ads
+++ b/testsuites/ada/sptests/sp19/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
2.24.4
