[PATCH 18/39] testsuites/libtests/[a-l]*: Change license to BSD-2
Fri Apr 8 14:45:46 UTC 2022
Updates #3053.
 testsuites/libtests/block01/block01.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block02/block02.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block03/block03.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block04/block04.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block05/block05.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block06/block06.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block07/block07.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test1_1.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test1_2.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test1_3.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test1_4.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test1_5.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test2_1.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test2_2.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test3_1.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test3_2.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test3_3.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test4_1.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test4_2.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_test4_3.c   | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_tests.c     | 25 ++++++++++++++++---
 testsuites/libtests/block08/bdbuf_tests.h     | 25 ++++++++++++++++---
 testsuites/libtests/block08/init.c            | 25 ++++++++++++++++---
 testsuites/libtests/block08/system.h          | 25 ++++++++++++++++---
 testsuites/libtests/block08/test_disk.c       | 25 ++++++++++++++++---
 testsuites/libtests/block09/block09.doc       | 25 ++++++++++++++++---
 testsuites/libtests/block10/block10.doc       | 25 ++++++++++++++++---
 .../libtests/bspcmdline01/bspcmdline01.doc    | 25 ++++++++++++++++---
 testsuites/libtests/capture01/capture01.doc   | 25 ++++++++++++++++---
 testsuites/libtests/capture01/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/capture01/system.h        | 25 ++++++++++++++++---
 testsuites/libtests/capture01/test1.c         | 25 ++++++++++++++++---
 testsuites/libtests/complex/complex.doc       | 25 ++++++++++++++++---
 testsuites/libtests/debugger01/debugger01.doc | 25 ++++++++++++++++---
 testsuites/libtests/devfs01/devfs01.doc       | 25 ++++++++++++++++---
 testsuites/libtests/devfs04/devfs04.doc       | 25 ++++++++++++++++---
 testsuites/libtests/deviceio01/deviceio01.doc | 25 ++++++++++++++++---
 .../devnullfatal01/devnullfatal01.doc         | 25 ++++++++++++++++---
 testsuites/libtests/dl01/dl01.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl02/dl02.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl03/dl03.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl04/dl04.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl05/dl05.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl06/dl06.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl07/dl07.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl08/dl08.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl09/dl09.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dl10/dl10.doc             | 25 ++++++++++++++++---
 testsuites/libtests/dumpbuf01/dumpbuf01.doc   | 25 ++++++++++++++++---
 .../libtests/flashdisk01/flashdisk01.doc      | 25 ++++++++++++++++---
 50 files changed, 1100 insertions(+), 150 deletions(-)
diff --git a/testsuites/libtests/block01/block01.doc b/testsuites/libtests/block01/block01.doc
index 781244053c..66fca83ea4 100644
--- a/testsuites/libtests/block01/block01.doc
+++ b/testsuites/libtests/block01/block01.doc
@@ -1,8 +1,27 @@
+# SPDX-License-Identifier: BSD-2-Clause
 # Copyright (c) 2009 embedded brains GmbH.  All rights reserved.
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/libtests/block02/block02.doc b/testsuites/libtests/block02/block02.doc
index c8c7d15c40..97f9de2e28 100644
--- a/testsuites/libtests/block02/block02.doc
+++ b/testsuites/libtests/block02/block02.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/block03/block03.doc b/testsuites/libtests/block03/block03.doc
index 3ada8a2614..7c31c06765 100644
--- a/testsuites/libtests/block03/block03.doc
+++ b/testsuites/libtests/block03/block03.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/block04/block04.doc b/testsuites/libtests/block04/block04.doc
index a7c59939f7..744c4be5be 100644
--- a/testsuites/libtests/block04/block04.doc
+++ b/testsuites/libtests/block04/block04.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/block05/block05.doc b/testsuites/libtests/block05/block05.doc
index cb34ab672d..4c739d41ee 100644
--- a/testsuites/libtests/block05/block05.doc
+++ b/testsuites/libtests/block05/block05.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2009, 2010 embedded brains GmbH.  All rights reserved.
+# are met:
diff --git a/testsuites/libtests/block06/block06.doc b/testsuites/libtests/block06/block06.doc
index 3a09a59799..00efa32507 100644
--- a/testsuites/libtests/block06/block06.doc
+++ b/testsuites/libtests/block06/block06.doc
@@ -1,8 +1,27 @@
 # Copyright 2008-2014 Chris Johns (chrisj at rtems.org)
+# are met:
diff --git a/testsuites/libtests/block07/block07.doc b/testsuites/libtests/block07/block07.doc
index 7b39c08090..7643cb8630 100644
--- a/testsuites/libtests/block07/block07.doc
+++ b/testsuites/libtests/block07/block07.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/block08/bdbuf_test1_1.c b/testsuites/libtests/block08/bdbuf_test1_1.c
index 2c768c4194..4f0f6aeea4 100644
--- a/testsuites/libtests/block08/bdbuf_test1_1.c
+++ b/testsuites/libtests/block08/bdbuf_test1_1.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check the behaviour of rtems_bdbuf_read() function
  * with different reports from disk device driver.
@@ -21,9 +23,26 @@
  * Copyright (C) 2010 OKTET Labs, St.-Petersburg, Russia
  * Author: Oleg Kravtsov <Oleg.Kravtsov at oktetlabs.ru>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/libtests/block08/bdbuf_test1_2.c b/testsuites/libtests/block08/bdbuf_test1_2.c
index f0b8d8f666..498da4c9f1 100644
--- a/testsuites/libtests/block08/bdbuf_test1_2.c
+++ b/testsuites/libtests/block08/bdbuf_test1_2.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check how rtems_bdbuf_read() handles two readers waiting
  * for a buffer with the same block number in cases when disk device
@@ -23,9 +25,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test1_3.c b/testsuites/libtests/block08/bdbuf_test1_3.c
index 95d7047d4a..a6d393fcaa 100644
--- a/testsuites/libtests/block08/bdbuf_test1_3.c
+++ b/testsuites/libtests/block08/bdbuf_test1_3.c
@@ -1,3 +1,5 @@
 /*! @file
@@ -24,9 +26,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test1_4.c b/testsuites/libtests/block08/bdbuf_test1_4.c
index 232316fca3..1428321948 100644
--- a/testsuites/libtests/block08/bdbuf_test1_4.c
+++ b/testsuites/libtests/block08/bdbuf_test1_4.c
@@ -1,3 +1,5 @@
 /*! @file
@@ -21,9 +23,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test1_5.c b/testsuites/libtests/block08/bdbuf_test1_5.c
index 947ce0ca7c..edb7c12beb 100644
--- a/testsuites/libtests/block08/bdbuf_test1_5.c
+++ b/testsuites/libtests/block08/bdbuf_test1_5.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check how rtems_bdbuf_read() handles read request
  * for a buffer that is owned by an application.
@@ -20,9 +22,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test2_1.c b/testsuites/libtests/block08/bdbuf_test2_1.c
index 748e3d3b15..571f63b559 100644
--- a/testsuites/libtests/block08/bdbuf_test2_1.c
+++ b/testsuites/libtests/block08/bdbuf_test2_1.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check how rtems_bdbuf_read() and rtems_bdbuf_release_modified()
  * coexist. rtems_bdbuf_read() is blocked when required buffer is being
@@ -23,9 +25,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test2_2.c b/testsuites/libtests/block08/bdbuf_test2_2.c
index 997bd490bb..8ee84f016e 100644
--- a/testsuites/libtests/block08/bdbuf_test2_2.c
+++ b/testsuites/libtests/block08/bdbuf_test2_2.c
@@ -1,3 +1,5 @@
 /*! @file
@@ -26,9 +28,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test3_1.c b/testsuites/libtests/block08/bdbuf_test3_1.c
index efe74b62ba..eaa8d757be 100644
--- a/testsuites/libtests/block08/bdbuf_test3_1.c
+++ b/testsuites/libtests/block08/bdbuf_test3_1.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check how read/release work in case of only one buffer in ready list.
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test3_2.c b/testsuites/libtests/block08/bdbuf_test3_2.c
index 35e6dc8527..f411e957fe 100644
--- a/testsuites/libtests/block08/bdbuf_test3_2.c
+++ b/testsuites/libtests/block08/bdbuf_test3_2.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check that when there are some tasks waiting for an available
  * buffer only one of them get a buffer after some other task releases one.
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test3_3.c b/testsuites/libtests/block08/bdbuf_test3_3.c
index 3445b15723..0273b3cd45 100644
--- a/testsuites/libtests/block08/bdbuf_test3_3.c
+++ b/testsuites/libtests/block08/bdbuf_test3_3.c
@@ -1,3 +1,5 @@
 /*! @file
@@ -20,9 +22,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test4_1.c b/testsuites/libtests/block08/bdbuf_test4_1.c
index ac1805da84..3dc36909c2 100644
--- a/testsuites/libtests/block08/bdbuf_test4_1.c
+++ b/testsuites/libtests/block08/bdbuf_test4_1.c
@@ -1,3 +1,5 @@
 /*! @file
  * @brief Check how rtems_bdbuf_sync() works.
@@ -16,9 +18,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test4_2.c b/testsuites/libtests/block08/bdbuf_test4_2.c
index 122eb7ab56..6c94740793 100644
--- a/testsuites/libtests/block08/bdbuf_test4_2.c
+++ b/testsuites/libtests/block08/bdbuf_test4_2.c
@@ -1,3 +1,5 @@
 /*! @file
@@ -17,9 +19,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_test4_3.c b/testsuites/libtests/block08/bdbuf_test4_3.c
index 0c2dd68769..4d15c69b4b 100644
--- a/testsuites/libtests/block08/bdbuf_test4_3.c
+++ b/testsuites/libtests/block08/bdbuf_test4_3.c
@@ -1,3 +1,5 @@
 /*! @file
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_tests.c b/testsuites/libtests/block08/bdbuf_tests.c
index 8cf0111dbc..549246b034 100644
--- a/testsuites/libtests/block08/bdbuf_tests.c
+++ b/testsuites/libtests/block08/bdbuf_tests.c
@@ -1,12 +1,31 @@
 /*! @file
  * @brief Implementation of auxiliary functions of bdbuf tests.
+ * are met:
diff --git a/testsuites/libtests/block08/bdbuf_tests.h b/testsuites/libtests/block08/bdbuf_tests.h
index eea2661480..626c60001a 100644
--- a/testsuites/libtests/block08/bdbuf_tests.h
+++ b/testsuites/libtests/block08/bdbuf_tests.h
@@ -1,12 +1,31 @@
 /*! @file
  * @brief Common declarations of bdbuf tests.
+ * are met:
 #ifndef BDBUF_TESTS_H
diff --git a/testsuites/libtests/block08/init.c b/testsuites/libtests/block08/init.c
index 83eaf6d534..5d4b39ac02 100644
--- a/testsuites/libtests/block08/init.c
+++ b/testsuites/libtests/block08/init.c
@@ -1,3 +1,5 @@
 /*  Init
  *  This routine is the initialization task for this test program.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/system.h b/testsuites/libtests/block08/system.h
index 91227539dd..155f93ef20 100644
--- a/testsuites/libtests/block08/system.h
+++ b/testsuites/libtests/block08/system.h
@@ -1,3 +1,5 @@
 /*  system.h
  *  This include file contains information that is included in every
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/block08/test_disk.c b/testsuites/libtests/block08/test_disk.c
index 27aea17d27..64d42acd91 100644
--- a/testsuites/libtests/block08/test_disk.c
+++ b/testsuites/libtests/block08/test_disk.c
@@ -1,12 +1,31 @@
 /*! @file
  *  @brief Test disk block device implementation.
+ * are met:
diff --git a/testsuites/libtests/block09/block09.doc b/testsuites/libtests/block09/block09.doc
index bb015a6dc5..9522de911a 100644
--- a/testsuites/libtests/block09/block09.doc
+++ b/testsuites/libtests/block09/block09.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
+# are met:
diff --git a/testsuites/libtests/block10/block10.doc b/testsuites/libtests/block10/block10.doc
index 90b2b3f864..46ad5c808c 100644
--- a/testsuites/libtests/block10/block10.doc
+++ b/testsuites/libtests/block10/block10.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/bspcmdline01/bspcmdline01.doc b/testsuites/libtests/bspcmdline01/bspcmdline01.doc
index 51e747cf67..9cc3eed704 100644
--- a/testsuites/libtests/bspcmdline01/bspcmdline01.doc
+++ b/testsuites/libtests/bspcmdline01/bspcmdline01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2009.
 #  On-Line Applications Research Corporation (OAR).
+# are met:
diff --git a/testsuites/libtests/capture01/capture01.doc b/testsuites/libtests/capture01/capture01.doc
index c3d2e566d8..b42dab2757 100644
--- a/testsuites/libtests/capture01/capture01.doc
+++ b/testsuites/libtests/capture01/capture01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-1999.
+# are met:
 This is a non-ineractive test of the capture engine.  This test is based
diff --git a/testsuites/libtests/capture01/init.c b/testsuites/libtests/capture01/init.c
index 5c6a092ef2..3191ab62eb 100644
--- a/testsuites/libtests/capture01/init.c
+++ b/testsuites/libtests/capture01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2012.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
+ * are met:
 #define CONFIGURE_INIT
diff --git a/testsuites/libtests/capture01/system.h b/testsuites/libtests/capture01/system.h
index 620b7b477f..48e1f525fb 100644
--- a/testsuites/libtests/capture01/system.h
+++ b/testsuites/libtests/capture01/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-1997.
+ * are met:
diff --git a/testsuites/libtests/capture01/test1.c b/testsuites/libtests/capture01/test1.c
index f1a2133d6b..a0098fa183 100644
--- a/testsuites/libtests/capture01/test1.c
+++ b/testsuites/libtests/capture01/test1.c
@@ -1,3 +1,5 @@
 /*  Test1
  *  This test uses creates a number of tasks so the capture engine
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/libtests/complex/complex.doc b/testsuites/libtests/complex/complex.doc
index 1de63d0981..815d86cadf 100644
--- a/testsuites/libtests/complex/complex.doc
+++ b/testsuites/libtests/complex/complex.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 2014.
 #  Cynthia Rempel <cynthia at rtems.org>
+# are met:
diff --git a/testsuites/libtests/debugger01/debugger01.doc b/testsuites/libtests/debugger01/debugger01.doc
index 2cdd48bf4d..0313882564 100644
--- a/testsuites/libtests/debugger01/debugger01.doc
+++ b/testsuites/libtests/debugger01/debugger01.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
+# are met:
diff --git a/testsuites/libtests/devfs01/devfs01.doc b/testsuites/libtests/devfs01/devfs01.doc
index 9503ce1056..dd5a48fdf3 100644
--- a/testsuites/libtests/devfs01/devfs01.doc
+++ b/testsuites/libtests/devfs01/devfs01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2010.
+# are met:
diff --git a/testsuites/libtests/devfs04/devfs04.doc b/testsuites/libtests/devfs04/devfs04.doc
index abd578de47..2f512e50e1 100644
--- a/testsuites/libtests/devfs04/devfs04.doc
+++ b/testsuites/libtests/devfs04/devfs04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/deviceio01/deviceio01.doc b/testsuites/libtests/deviceio01/deviceio01.doc
index ed7f622ca9..0ca7b4395d 100644
--- a/testsuites/libtests/deviceio01/deviceio01.doc
+++ b/testsuites/libtests/deviceio01/deviceio01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/devnullfatal01/devnullfatal01.doc b/testsuites/libtests/devnullfatal01/devnullfatal01.doc
index cc51421cbb..18f52caa45 100644
--- a/testsuites/libtests/devnullfatal01/devnullfatal01.doc
+++ b/testsuites/libtests/devnullfatal01/devnullfatal01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/dl01/dl01.doc b/testsuites/libtests/dl01/dl01.doc
index a1099287d4..5e20cdf650 100644
--- a/testsuites/libtests/dl01/dl01.doc
+++ b/testsuites/libtests/dl01/dl01.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2014 Chris Johns <chrisj at rtems.org>
+# are met:
diff --git a/testsuites/libtests/dl02/dl02.doc b/testsuites/libtests/dl02/dl02.doc
index 4a325de9cc..d7e29c75eb 100644
--- a/testsuites/libtests/dl02/dl02.doc
+++ b/testsuites/libtests/dl02/dl02.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dl03/dl03.doc b/testsuites/libtests/dl03/dl03.doc
--- a/testsuites/libtests/dl03/dl03.doc
+++ b/testsuites/libtests/dl03/dl03.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dl04/dl04.doc b/testsuites/libtests/dl04/dl04.doc
index f36dc7b07f..b728efe22c 100644
--- a/testsuites/libtests/dl04/dl04.doc
+++ b/testsuites/libtests/dl04/dl04.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dl05/dl05.doc b/testsuites/libtests/dl05/dl05.doc
index 58d4d95fa1..42855852b8 100644
--- a/testsuites/libtests/dl05/dl05.doc
+++ b/testsuites/libtests/dl05/dl05.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dl06/dl06.doc b/testsuites/libtests/dl06/dl06.doc
index 8487385b04..bd50220c8b 100644
--- a/testsuites/libtests/dl06/dl06.doc
+++ b/testsuites/libtests/dl06/dl06.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2018 Chris Johns <chrisj at rtems.org>
+# are met:
diff --git a/testsuites/libtests/dl07/dl07.doc b/testsuites/libtests/dl07/dl07.doc
index 9a06de16fc..9535ded722 100644
--- a/testsuites/libtests/dl07/dl07.doc
+++ b/testsuites/libtests/dl07/dl07.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dl08/dl08.doc b/testsuites/libtests/dl08/dl08.doc
index 29819bbc83..85f69f2582 100644
--- a/testsuites/libtests/dl08/dl08.doc
+++ b/testsuites/libtests/dl08/dl08.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dl09/dl09.doc b/testsuites/libtests/dl09/dl09.doc
index f9df9a276d..c820424d14 100644
--- a/testsuites/libtests/dl09/dl09.doc
+++ b/testsuites/libtests/dl09/dl09.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2019 Chris Johns <chrisj at rtems.org>
+# are met:
diff --git a/testsuites/libtests/dl10/dl10.doc b/testsuites/libtests/dl10/dl10.doc
index 82469da593..bee13b1c2a 100644
--- a/testsuites/libtests/dl10/dl10.doc
+++ b/testsuites/libtests/dl10/dl10.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/libtests/dumpbuf01/dumpbuf01.doc b/testsuites/libtests/dumpbuf01/dumpbuf01.doc
index 5249321e8e..1269733c47 100644
--- a/testsuites/libtests/dumpbuf01/dumpbuf01.doc
+++ b/testsuites/libtests/dumpbuf01/dumpbuf01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/flashdisk01/flashdisk01.doc b/testsuites/libtests/flashdisk01/flashdisk01.doc
index 9c2e8b594a..a3c4906784 100644
--- a/testsuites/libtests/flashdisk01/flashdisk01.doc
+++ b/testsuites/libtests/flashdisk01/flashdisk01.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
