[PATCH 33/39] testsuites/psxtests/psxhdrs/sys/mman/*: Change license to BSD-2
Fri Apr 8 14:46:01 UTC 2022
Updates #3053.
 testsuites/psxtests/psxhdrs/sys/mman/mlock.c  | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/mlockall.c      | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/sys/mman/mmap.c   | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/mprotect.c      | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/sys/mman/msync.c  | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/munlock.c       | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/munlockall.c    | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/sys/mman/munmap.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/posix_madvise.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/shm_open.c      | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/mman/shm_unlink.c    | 25 ++++++++++++++++---
 11 files changed, 242 insertions(+), 33 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/mlock.c b/testsuites/psxtests/psxhdrs/sys/mman/mlock.c
index 04c392ee80..52beb4edaa 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/mlock.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/mlock.c
@@ -1,3 +1,5 @@
  * This test file is used to verify that the header files associated with
  * invoking this function are correct.
@@ -6,9 +8,26 @@
  *  Copyright (c) 2016 Gedare Bloom.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/mlockall.c b/testsuites/psxtests/psxhdrs/sys/mman/mlockall.c
index 12dbd83ab8..f8bea96b6c 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/mlockall.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/mlockall.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/mmap.c b/testsuites/psxtests/psxhdrs/sys/mman/mmap.c
index 8426b12855..0ae29467c4 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/mmap.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/mmap.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/mprotect.c b/testsuites/psxtests/psxhdrs/sys/mman/mprotect.c
index 5503c94bd2..4c0e29673e 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/mprotect.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/mprotect.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/msync.c b/testsuites/psxtests/psxhdrs/sys/mman/msync.c
index 4cd239a2b8..80dac614a6 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/msync.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/msync.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/munlock.c b/testsuites/psxtests/psxhdrs/sys/mman/munlock.c
index 42af198fa9..8e0cacd443 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/munlock.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/munlock.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/munlockall.c b/testsuites/psxtests/psxhdrs/sys/mman/munlockall.c
index 4b8294302d..b2d2434c54 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/munlockall.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/munlockall.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/munmap.c b/testsuites/psxtests/psxhdrs/sys/mman/munmap.c
index 1c42973a9f..d3260af09e 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/munmap.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/munmap.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/posix_madvise.c b/testsuites/psxtests/psxhdrs/sys/mman/posix_madvise.c
index 3457973a3e..9afca5a600 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/posix_madvise.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/posix_madvise.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/shm_open.c b/testsuites/psxtests/psxhdrs/sys/mman/shm_open.c
index c44ded4abd..4f9b160ef8 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/shm_open.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/shm_open.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/mman/shm_unlink.c b/testsuites/psxtests/psxhdrs/sys/mman/shm_unlink.c
index 3d1b9bb463..5bb38bea8c 100644
--- a/testsuites/psxtests/psxhdrs/sys/mman/shm_unlink.c
+++ b/testsuites/psxtests/psxhdrs/sys/mman/shm_unlink.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
2.24.4
