[PATCH rtems-lwip] lwip: Split sources into origin directories
Thu Apr 14 22:26:11 UTC 2022
I'm ok with it. Just wondering what's left on the list before moving this
to a community shared area? :)
--joel
On Thu, Apr 14, 2022 at 3:08 PM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> Hi Kinsey,
> Thank you for sorting this out. I will merge it on Monday if no one
> objects.
> Best regards,
> Vijay
> On Thu, Apr 14, 2022 at 11:33 AM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
> > Moving forward, each origin directory should have its own top-level
> > COPYING.origin file to describe its license as well as a ORIGIN.origin
> > file to describe where the code is sourced from.
> >  COPYING.lwip                                  | 25 ++++++++++++++
> >  COPYING.uLan                                  | 33 +++++++++++++++++++
> >  ORIGIN.lwip                                   |  2 ++
> >  ORIGIN.uLan                                   |  2 ++
> >  README                                        | 14 ++++++++
> >  lwip.py                                       | 10 +++---
> >  .../ports/driver/tms570_emac}/eth_lwip.c      |  0
> >  .../ports/driver/tms570_emac}/eth_lwip.h      |  0
> >  .../driver/tms570_emac}/eth_lwip_default.h    |  0
> >  .../ports/driver/tms570_emac}/phy_dp83848h.c  |  0
> >  .../ports/driver/tms570_emac}/phy_dp83848h.h  |  0
> >  .../ports/driver/tms570_emac}/ti_drv_emac.h   |  0
> >  .../ports/driver/tms570_emac}/ti_drv_mdio.h   |  0
> >  .../ports/driver/tms570_emac}/tms570_emac.h   |  0
> >  .../ports/driver/tms570_emac}/tms570_netif.c  |  0
> >  .../ports/driver/tms570_emac}/tms570_netif.h  |  0
> >  {lwip => uLan}/ports/os/lwipopts.h            |  0
> >  {lwip => uLan}/ports/os/rtems/arch/cc.h       |  0
> >  {lwip => uLan}/ports/os/rtems/arch/perf.h     |  0
> >  {lwip => uLan}/ports/os/rtems/arch/sys_arch.c |  0
> >  {lwip => uLan}/ports/os/rtems/arch/sys_arch.h |  0
> >  21 files changed, 81 insertions(+), 5 deletions(-)
> >  create mode 100644 COPYING.lwip
> >  create mode 100644 COPYING.uLan
> >  create mode 100644 ORIGIN.lwip
> >  create mode 100644 ORIGIN.uLan
> >  create mode 100644 README
> >  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip.c
> (100%)
> >  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip.h
> (100%)
> uLan/ports/driver/tms570_emac}/eth_lwip_default.h (100%)
> uLan/ports/driver/tms570_emac}/phy_dp83848h.c (100%)
> uLan/ports/driver/tms570_emac}/phy_dp83848h.h (100%)
> uLan/ports/driver/tms570_emac}/ti_drv_emac.h (100%)
> uLan/ports/driver/tms570_emac}/ti_drv_mdio.h (100%)
> uLan/ports/driver/tms570_emac}/tms570_emac.h (100%)
> uLan/ports/driver/tms570_emac}/tms570_netif.c (100%)
> uLan/ports/driver/tms570_emac}/tms570_netif.h (100%)
> >  rename {lwip => uLan}/ports/os/lwipopts.h (100%)
> >  rename {lwip => uLan}/ports/os/rtems/arch/cc.h (100%)
> >  rename {lwip => uLan}/ports/os/rtems/arch/perf.h (100%)
> >  rename {lwip => uLan}/ports/os/rtems/arch/sys_arch.c (100%)
> >  rename {lwip => uLan}/ports/os/rtems/arch/sys_arch.h (100%)
> > diff --git a/COPYING.lwip b/COPYING.lwip
> > new file mode 100644
> > index 0000000..90465f5
> > --- /dev/null
> > +++ b/COPYING.lwip
> > @@ -0,0 +1,25 @@
> > +Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
> > +All rights reserved.
> > +Redistribution and use in source and binary forms, with or without
> modification,
> > +are permitted provided that the following conditions are met:
> > +1. Redistributions of source code must retain the above copyright
> notice,
> > +   this list of conditions and the following disclaimer.
> > +2. Redistributions in binary form must reproduce the above copyright
> notice,
> > +   this list of conditions and the following disclaimer in the
> documentation
> > +   and/or other materials provided with the distribution.
> > +3. The name of the author may not be used to endorse or promote products
> > +   derived from this software without specific prior written permission.
> > +THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
> IMPLIED
> > +WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> > +MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
> NO EVENT
> > +SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> SPECIAL,
> > +EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT
> > +OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> > +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> ARISING
> > +IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY
> > +OF SUCH DAMAGE.
> > diff --git a/COPYING.uLan b/COPYING.uLan
> > index 0000000..e23898b
> > --- /dev/null
> > +++ b/COPYING.uLan
> > @@ -0,0 +1,33 @@
> > + * Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
> > + * All rights reserved.
> > + * Redistribution and use in source and binary forms, with or without
> modification,
> > + * are permitted provided that the following conditions are met:
> > + * 1. Redistributions of source code must retain the above copyright
> notice,
> > + *    this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> notice,
> > + *    this list of conditions and the following disclaimer in the
> documentation
> > + *    and/or other materials provided with the distribution.
> > + * 3. The name of the author may not be used to endorse or promote
> products
> > + *    derived from this software without specific prior written
> permission.
> > + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
> IMPLIED
> > + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> > + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
> IN NO EVENT
> > + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> SPECIAL,
> > + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT
> > + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE) ARISING
> > + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY
> > + * OF SUCH DAMAGE.
> > + * This file is part of the lwIP TCP/IP stack.
> > + * Author: Adam Dunkels <adam at sics.se>
> > diff --git a/ORIGIN.lwip b/ORIGIN.lwip
> > index 0000000..c77755e
> > --- /dev/null
> > +++ b/ORIGIN.lwip
> > @@ -0,0 +1,2 @@
> > +The files under the lwip/ directory are sourced from:
> > +git://git.savannah.gnu.org/lwip.git
> > diff --git a/ORIGIN.uLan b/ORIGIN.uLan
> > index 0000000..8111d3d
> > --- /dev/null
> > +++ b/ORIGIN.uLan
> > @@ -0,0 +1,2 @@
> > +The files under the uLan/ directory are sourced from:
> > +git://git.code.sf.net/p/ulan/lwip-omk ulan-lwip-omk
> > diff --git a/README b/README
> > index 0000000..91e42ae
> > --- /dev/null
> > +++ b/README
> > @@ -0,0 +1,14 @@
> > +Overview
> > +The rtems-lwip repository serves as a central location to manage
> integration of
> > +lwIP with RTEMS in a more user-accessible manner and to provide a
> repository of
> > +network drivers for RTEMS BSPs.
> > +File Origins
> > +The sources presented here originate in one of several locations
> described by
> > +the ORIGIN.* files and whose license is described by the COPYING.*
> files.
> > +Commits adding such files should include the hash of the target
> repository if
> > +applicable.
> > diff --git a/lwip.py b/lwip.py
> > index a3eb7cb..848ff16 100644
> > --- a/lwip.py
> > +++ b/lwip.py
> > @@ -42,10 +42,10 @@ def build(bld):
> >              if f[-2:] == '.c':
> >                  source_files.append(os.path.join('./lwip', f))
> > -        for f in os.listdir('./lwip/ports/drivers'):
> > +        for f in os.listdir('./uLan/ports/driver/tms570_emac'):
> >              if f[-2:] == '.c':
> driver_source.append(os.path.join('./lwip/ports/drivers', f))
> > -    source_files.append('./lwip/ports/os/rtems/arch/sys_arch.c')
> driver_source.append(os.path.join('./uLan/ports/driver/tms570_emac', f))
> > +    source_files.append('./uLan/ports/os/rtems/arch/sys_arch.c')
> >      #source_files.append('./lwip/ports/port/sys_arch.c')
> >      #source_files.append('./lwip/ports/port/perf.c')
> > @@ -57,7 +57,7 @@ def build(bld):
> >      bld(features ='c',
> >          target='lwip_obj',
> > -        includes='./include ./lwip/src/include lwip/ports/port/include
> ./lwip/ports/os ./lwip/ports/drivers ./lwip/ports/os/rtems',
> > +        includes='./include ./lwip/src/include ./uLan/ports/os
> ./uLan/ports/driver/tms570_emac ./uLan/ports/os/rtems',
> >          source=source_files,
> >  #    bld(features ='c',
> > @@ -74,4 +74,4 @@ def build(bld):
> >                  source='./lwip/test/sample_app.c',
> >                  use='lwip',
> >                  lib=['rtemscpu', 'rtemsbsp', 'rtemstest', 'lwip'],
> > -                includes='./include ./lwip/ports/os/rtems
> ./lwip/ports/os ./lwip/src/include ./lwip/ports/os/rtems ./lwip/test/' +
> os.path.relpath(os.path.join(arch_lib_path,'include')))
> > +                includes='./include ./uLan/ports/os/rtems
> ./uLan/ports/os ./lwip/src/include ./uLan/ports/os/rtems ./lwip/test/' +
> > diff --git a/lwip/ports/drivers/eth_lwip.c
> b/uLan/ports/driver/tms570_emac/eth_lwip.c
> > similarity index 100%
> > rename from lwip/ports/drivers/eth_lwip.c
> > rename to uLan/ports/driver/tms570_emac/eth_lwip.c
> > diff --git a/lwip/ports/drivers/eth_lwip.h
> b/uLan/ports/driver/tms570_emac/eth_lwip.h
> > rename from lwip/ports/drivers/eth_lwip.h
> > rename to uLan/ports/driver/tms570_emac/eth_lwip.h
> > diff --git a/lwip/ports/drivers/eth_lwip_default.h
> b/uLan/ports/driver/tms570_emac/eth_lwip_default.h
> > rename from lwip/ports/drivers/eth_lwip_default.h
> > rename to uLan/ports/driver/tms570_emac/eth_lwip_default.h
> > diff --git a/lwip/ports/drivers/phy_dp83848h.c
> b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
> > rename from lwip/ports/drivers/phy_dp83848h.c
> > rename to uLan/ports/driver/tms570_emac/phy_dp83848h.c
> > diff --git a/lwip/ports/drivers/phy_dp83848h.h
> b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
> > rename from lwip/ports/drivers/phy_dp83848h.h
> > rename to uLan/ports/driver/tms570_emac/phy_dp83848h.h
> > diff --git a/lwip/ports/drivers/ti_drv_emac.h
> b/uLan/ports/driver/tms570_emac/ti_drv_emac.h
> > rename from lwip/ports/drivers/ti_drv_emac.h
> > rename to uLan/ports/driver/tms570_emac/ti_drv_emac.h
> > diff --git a/lwip/ports/drivers/ti_drv_mdio.h
> b/uLan/ports/driver/tms570_emac/ti_drv_mdio.h
> > rename from lwip/ports/drivers/ti_drv_mdio.h
> > rename to uLan/ports/driver/tms570_emac/ti_drv_mdio.h
> > diff --git a/lwip/ports/drivers/tms570_emac.h
> b/uLan/ports/driver/tms570_emac/tms570_emac.h
> > rename from lwip/ports/drivers/tms570_emac.h
> > rename to uLan/ports/driver/tms570_emac/tms570_emac.h
> > diff --git a/lwip/ports/drivers/tms570_netif.c
> b/uLan/ports/driver/tms570_emac/tms570_netif.c
> > rename from lwip/ports/drivers/tms570_netif.c
> > rename to uLan/ports/driver/tms570_emac/tms570_netif.c
> > diff --git a/lwip/ports/drivers/tms570_netif.h
> b/uLan/ports/driver/tms570_emac/tms570_netif.h
> > rename from lwip/ports/drivers/tms570_netif.h
> > rename to uLan/ports/driver/tms570_emac/tms570_netif.h
> > diff --git a/lwip/ports/os/lwipopts.h b/uLan/ports/os/lwipopts.h
> > rename from lwip/ports/os/lwipopts.h
> > rename to uLan/ports/os/lwipopts.h
> > diff --git a/lwip/ports/os/rtems/arch/cc.h
> b/uLan/ports/os/rtems/arch/cc.h
> > rename from lwip/ports/os/rtems/arch/cc.h
> > rename to uLan/ports/os/rtems/arch/cc.h
> > diff --git a/lwip/ports/os/rtems/arch/perf.h
> b/uLan/ports/os/rtems/arch/perf.h
> > rename from lwip/ports/os/rtems/arch/perf.h
> > rename to uLan/ports/os/rtems/arch/perf.h
> > diff --git a/lwip/ports/os/rtems/arch/sys_arch.c
> b/uLan/ports/os/rtems/arch/sys_arch.c
> > rename from lwip/ports/os/rtems/arch/sys_arch.c
> > rename to uLan/ports/os/rtems/arch/sys_arch.c
> > diff --git a/lwip/ports/os/rtems/arch/sys_arch.h
> b/uLan/ports/os/rtems/arch/sys_arch.h
> > rename from lwip/ports/os/rtems/arch/sys_arch.h
> > rename to uLan/ports/os/rtems/arch/sys_arch.h
> > 2.30.2
> > devel mailing list
> > devel at rtems.org
